Installation OpenFOAM-1.7.x with wmakeScheduler
Like Tree2Likes
Old   October 24, 2010, 16:13
Default Installation OpenFOAM-1.7.x with wmakeScheduler
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hey I am Tobi and a new community member,
first of all. Hello everybody.
I am working with Ubuntu 10.04 an had installed OpenFoam 1.7.1 with the Ubuntu/Debian Pack without problems.
So a good CFD - eng said, that the only version is up to date is the git responsitory.
I had downloaded everything and did all steps in the introductions.
Got so much mistakes and issues with compiling OpenFoam, but hope i have fixed it now. The only thing i can 't fix until now is using wmakeScheduler for compiling OF with my two cores :/
-> export WM_SCHEDULER=wmakeScheduler
-> export WM_HOSTS="shorty:2"
-> export WM_NCOMPPROCS=$($WM_SCHEDULER -count)
after typing echo $WM_NCOMPPROCS I got --> 2
After starting ./Allwmake it will stop at the beginning of line
"SOURCE=..."
"SOURCE=..."
what did i wrong? Sorry but i am new on Ubuntu - Distributions and so on.
Hope someone can help me. Couse i need the new Solver added in the new update.
Thanks
Tobi
Tobi is offline   Reply With Quote
Old   October 24, 2010, 16:28
Retired Super Moderator
Bruno Santos
Greetings Tobi and welcome to the forum!
Mmm, they should really put up a warning that for single machines, the wmakeScheduler isn't necessary. You can simply just do:
export WM_NCOMPPROCS=2
Or equal to the number of cores that your machine has. The other two variables aren't necessary.
edit: Wait... but WM_NCOMPPROCS did get set properly, since you said that 'export WM_HOSTS="shorty:2"' !! There was nothing wrong there, as far as I can tell!
Additionally, there are a few packages that you'll need to install to ensure that OpenFOAM will build: Building OpenFOAM1.7.0 from source post #4 and onward
In that thread you'll find the packages needed for building OpenFOAM and the code documentation (a few posts down).
Finally, to keep a log of the building process, run Allwmake like this:
./Allwmake > make.log 2>&1
You might need it after it's done, since something could go wrong
Best regards and good luck!
Bruno
Old   October 24, 2010, 17:47
Tobi's Avatar
Tobias Holzmann
Hi Bruno,
I have read your thread that you have linked above a hour befor and added all the packages. Think that was my real problem to compile it without issues.
Just, i compile with 1 core :/ although i set WM_NCOMPPROS=2
Don 't know why it don' t work.
Will install OF on my new computer in three day's (6 cores)
I will test it with your Code
Thx for answering
Couse i need the chtMultiRegionLiquidFoam solver
Tobi
Old   October 24, 2010, 18:13
Bruno Santos
Hi Tobi,
Ooooo, so close... but if you really used that name, it's no wonder it didn't work It's:
You missed a C before the last S
If you want a more self-adapting code for setting that variable, you can use this:
Originally Posted by $WM_THIRD_PARTY_DIR/tools/makeThirdPartyFunctions
    if [ -r /proc/cpuinfo ]
    then
        WM_NCOMPPROCS=$(egrep "^processor" /proc/cpuinfo | wc -l)
        [ $WM_NCOMPPROCS -le 8 ] || WM_NCOMPPROCS=8
    else
        WM_NCOMPPROCS=1
    fi
    echo "Building on $WM_NCOMPPROCS cores"
Add it to OpenFOAM's bashrc file, or to your own "~/.bashrc" file
Best regards,
Bruno
Old   October 24, 2010, 18:19
Tobi's Avatar
Tobias Holzmann
no I got the right var. Why it don 't work - don 't know.
Will try your last post and set it into my .bashrc.
Thx. Will make an answer how it work.
Old   October 25, 2010, 03:44
Tobi's Avatar
Tobias Holzmann
Okay
OpenFoam-1.7.x (git) is now working (jehaaa) (:
if i install it on my new machine i will try to set the "WM_HOSTS" variable to
export WM_HOSTS="localhost:6"
Maybe this will work.
Greetings Tobi
Old   October 25, 2010, 06:41
Tobi's Avatar
Tobias Holzmann
Hey again,
included your code to my ~/.bashrc
shorty@shorty:~/OpenFOAM/OpenFOAM-1.7.x$ . $HOME/.bashrc
Building on 2 cores
shorty@shorty:~/OpenFOAM/OpenFOAM-1.7.x$ ./Allwmake
But he worked just with 1 core. Don 't understand why.
Got Ubuntu 10.04. A CFD-eng. said today, that the compiling with more cores doen 't work. He has linux and there it works but on his ubuntu don 't work the Scheduler.
I tested everything. If i build on 2 cores he is working until that code end
Done ThirdParty Allwmake
+ wmakePrintBuild -check
same version as previous build
+ wmakeLnInclude OpenFOAM
+ wmakeLnInclude OSspecific/POSIX
+ Pstream/Allwmake
+ wmake libso dummy
'/home/shorty/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/dummy/libPstream.so' is up to date.
+ set +x
Note: ignore spurious warnings about missing mpicxx.h headers
+ WM_OPTIONS=linux64GccDPOptOPENMPI
+ wmake libso mpi
'/home/shorty/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/openmpi-1.4.1/libPstream.so' is up to date.
+ wmake libo OSspecific/POSIX
'/home/shorty/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOSspecific.o' is up to date.
+ wmake libso OpenFOAM
SOURCE=meshes/primitiveMesh/primitiveMesh.C ; wmakeScheduler g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-40 -I/home/shorty/OpenFOAM/ThirdParty-1.7.x/zlib-1.2.3 -IlnInclude -I. -I/home/shorty/OpenFOAM/OpenFOAM-1.7.x/src/OpenFOAM/lnInclude -I/home/shorty/OpenFOAM/OpenFOAM-1.7.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/primitiveMesh.o
Hmm :/
Any ideas ?
Can make a log if this will help.
Tobi
Old   October 25, 2010, 07:08
Bruno Santos
Hi Tobi,
Only when building libscotch and OpenMPI, it will only use a single core (the people at OpenCFD forgot about it ).
What does this output:
Additionally, are you building in a real or virtual machine?
-------------------- EDIT:
I think I figured it out - run this:
echo $HOST
If nothing outputs, then that is the problem! wmakeScheduler assumes that this variable exists, but apparently it depends on the Linux distribution used.
Try running this before you run Allwmake:
export HOST=$HOSTNAME
And use:
export WM_HOSTS="$HOSTNAME:6"
Instead of localhost!
Otherwise, you will have to make your ssh sessions passwordless. For example: How to connect with ssh without using a password
EDIT2: Ironically, this has already been fixed a few days ago in OpenFOAM 1.7.x.
Best regards,
Bruno
Last edited by wyldckat; October 25, 2010 at 18:36. Reason: see "Edit:" and "Edit2:"
Old   October 26, 2010, 04:10
Tobi's Avatar
Tobias Holzmann
Hi Bruno,
first of all. Thx for your help.
I 'll got a new mainboard etc. so I have to wait until all is received.
And then I install everything new.
Question: Ubuntu 10.04 or CAE Linux Ubuntu 10.04?
After the installation i will check out your commands and post the output here.
Your question, if i build in a real or virtual machine, i think a real but I am not sure what you mean.
Build on my personal computer so i think its real.
Hope my english skills aren 't as bad as i think
Best reguards.
Tobi
PS: Think i will start compiling at saturdays.
Old   October 26, 2010, 17:53
Bruno Santos
Hi Tobi,
You're welcome and I'm glad I could be of help to you! Although this is almost as far as I can help when it comes to OpenFOAM itself, because I still don't have much experience with CFD and OpenFOAM+CFD
Personally I've never used CAE Linux, but it can save you several hours in trying to install all of those applications that already comes with it! But if you only need one or two of them, maybe you're better off using the standard Ubuntu 10.04. But it depends very much on what tools you will need!
If you don't know, then it's the real machine Here is an example of a virtual machine: Install Windows XP inside ubuntu using Virtualbox
Mmm, perhaps you were still sleepy?
With a bit of practice, with 6 cores you can let it compile while you lunch! Or while you have a snack Or go for a jog. My AMD 1055T built yesterday OpenFOAM 1.5-dev in about 36 minutes. So with 1.7.x should do it in roughly 40min.
Best regards,
Bruno
Old   October 27, 2010, 04:04
Tobi's Avatar
Tobias Holzmann
hihi, but only if you can build on 2 - 3 - 4 - 6 cores etc.
You build OF - 1.5 dev on Linux or Ubuntu?
A friend told me that if you use Linux, its very easy to build with more cores couse you just have to type the WM_HOSTS compared with ubuntu.
I hope it will work with more cores in a few days
Tobi
Old   October 27, 2010, 07:00
Bruno Santos
Hi Tobi,
Ubuntu is a Linux distribution! What happened is like I wrote in another post: OpenFOAM's 1.7.1 wmakeScheduler has a bug which is already fixed in 1.7.x. And if you only do:
export WM_NCOMPPROCS=6
it will build with multiple cores!
Best regards,
Bruno
Old   October 28, 2010, 10:30
Tobi's Avatar
Tobias Holzmann
Hey Bruno,
i know that Ubuntu is a distribution of Linux (:
So far. I will get the latest OpenFoam Version with git and hope that you are right (but i know that you are right (: )
But one problem still exists.
I am still waiting for my new mainbaord and cpu :/
But tomorrow - yea tomorrow it will be mine
Thx a lot.
If any errors occur i ll post it.
Tobi
Old   October 28, 2010, 10:42
Tobi's Avatar
Tobias Holzmann
Wrong entry
Sorry for that post.
Old   October 29, 2010, 20:55
Tobi's Avatar
Tobias Holzmann
Hi Bruno,
Hi Tobi,
Output: 6
run this:
echo $HOST
without "export HOST="..." " there is no output like you said.
After setting HOST the variable exists and the output is: "shorty" (my computer name) but you said, that it is fixed now. I ll see.
I will try it now and if it doesn 't work i ll try it with SSH
Bye Tobi
Old   October 29, 2010, 21:12
Tobi's Avatar
Tobias Holzmann
Hey Bruno,
its me Tobi. It 's working with all 6 cores. Nice - very nice.
So last question. Is a process that is in background faster than a process which is shown on the terminal?
Tobi
Old   October 30, 2010, 07:06
Bruno Santos
Hi Tobi,
I'm glad it's finally working
I've never timed that in Linux I know that in Windows 95 in a 486, it was better to output to a file or simply hide the command window. Nowadays, I'm not certain.
In theory, outputting to the screen will require additional processing, so it will depend if it's the graphics card job to fully interpret what needs to be shown, therefore done in parallel, without holding back the CPU. If that's done properly, it should not weight very much. Otherwise, you're better off outputting to a file, since it will only require CPU+memory operations, some of which already necessary, and then the occasional flush to the hard drive.
I know that psychologically, I always feel that outputting to a file is faster
Best regards,
Bruno
Old   May 15, 2012, 17:25
Shaun
socon009 is on a distinguished road
Bruno
I have followed numerous threads here on this topic.
Bruno, thank you for all of your input - it's been very helpful for me.
Currently, I am installing in RHEL 6.2 on multiple cores using the following command:
It has suppressed the output that I usually see while installing OpenFOAM.
Could you please offer an explanation of the command above?
In particular,
> make.log 2>&1
How does bash interpret this?
Lastly, where is the log file written to?
Thank you,
Shaun
socon009 is offline   Reply With Quote
Old   May 15, 2012, 17:33
Bruno Santos
Greetings Shaun and welcome to the forum!
The "make.log" file is placed in the same folder where you ran Allwmake.
  • The first ">" redirects the output from Allwmake to "make.log"
  • The "2>&1" specifies that the stderr (2) output is to be redirected to stdout (1). In other words, both the errors and normal output are sent to the same file. If this isn't used, only the normal output is sent to the log file, while the errors would be shown on screen.
Best regards,
Bruno
Old   May 15, 2012, 17:59
Shaun
Ok thanks! Great explanation.
Unfortunately, the log file created indicates that the installation process flopped.
I would like to figure out what is going on, but I am not sure how I should go about seeking help.
- Should I start another thread so as not to hi-jack this one?
- How can I use this log file to figure out what went wrong?
(All I can tell right now is that there are a heck of a lot of "undefined references" and nearly every one has something to do with one of a myriad of libraries.)
Thanks for any thoughts and suggestions ,
Shaun
wmakescheduler
OpenFOAM 1.6.x, 1.7.0 and 1.7.x are not fully prepared to work with gcc-4.5.x wyldckat OpenFOAM Bugs 18 October 21, 2010 05:51
Critical errors during OpenFoam installation in OpenSuse 11.0 amscosta OpenFOAM 5 May 1, 2009 14:06
Problem installing OpenFOAM 1.5 installation on RHEL 4. vwsj84 OpenFOAM Installation 4 April 23, 2009 04:48
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
