OpenFoam 2.3.0 installation on SUSE Linux Enterprise Server 11
Old   July 2, 2014, 11:56
Default OpenFoam 2.3.0 installation on SUSE Linux Enterprise Server 11
AI
sherif35 is on a distinguished road
Can anyone provide a list of instructions on installing OpenFoam 2.3.0 on a cluster running SUSE Linux Enterprise Server 11 (x86_64) operating system?
We tried the instructions for OpenSUSE listed on OpenFoam.org, but it was unable to build OpenFOAM executables. Updating the operating system is not an option at this point.
Thank you in advance for your help.
sherif35 is offline   Reply With Quote
Old   July 2, 2014, 16:31
Derek Mitchell
derekm is on a distinguished road
And then there is getting a compatible Openmpi (and Infiniband?)
are you using gcc 4.7? thats a requirement for 2.3
A CHEERING BAND OF FRIENDLY ELVES CARRY THE CONQUERING ADVENTURER OFF INTO THE SUNSET
derekm is offline   Reply With Quote
Old   July 2, 2014, 17:21
AI
I don't have full control of the cluster, I'm just being allowed to use it.
Its currently running gcc (SUSE Linux) 4.3.4. If it is going to be doable with gcc 4.7, I'll try to update it. Is this my main problem?
I appreciate any help on this issue. Thanks.
Old   July 6, 2014, 06:15
Retired Super Moderator
Bruno Santos
Greetings to all!
A compatibility matrix on GCC to OpenFOAM versions is being kept here: http://openfoamwiki.net/index.php/In...ibility_Matrix
@sherif35: Yes, GCC 4.3.4 is too old for OpenFOAM 2.3. Either you will need to ask the system administrator to install a more recent GCC version or try following these instructions: http://openfoamwiki.net/index.php/In...EL#CentOS_5.10 - they are meant for CentOS 5.10, so try starting at the step #5.
Best regards,
Bruno
Old   July 7, 2014, 12:22
AI
Thank you Bruno, I'll give it a try.
[OpenFOAM.com] OpenFOAM 1.7.1 installation on LINUX UBUNTU 10.10 electrosin OpenFOAM Installation 40 May 31, 2016 05:11
How to install OpenFOAM 2.3.0 into a cluster based on centOS linux eddykendo OpenFOAM Installation 1 June 16, 2014 08:52
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
Dual Boot Windows and Linux and Go Open Source andyj Main CFD Forum 2 October 21, 2010 16:49
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 7 January 19, 2010 15:39
