Problem trying to install the third-party paraview
Old   July 15, 2014, 05:12
Default Problem trying to install the third-party paraview
micheldup is on a distinguished road
I am trying to install Paraview from the pack ThirdParty-2.3.0 2.3.0
on a Ubuntu 14.04 platform.
Following instructions I executed the script ./makeParaView4.
Everything was going fine untill the installation process froze.
At that point in the xterm I had:
[ 86%] Building CXX object Qt/Core/CMakeFiles/pqCore.dir/moc_pqXMLEventObserver.cxx.o
[ 86%] Building CXX object Qt/Core/CMakeFiles/pqCore.dir/moc_pqXMLEventSource.cxx.o
[ 86%] Building CXX object Qt/Core/CMakeFiles/pqCore.dir/moc_pqXYBarChartView.cxx.o
[ 86%] Building CXX object Qt/Core/CMakeFiles/pqCore.dir/moc_pqXYChartView.cxx.o
Linking CXX shared library ../../lib/libvtkpqCore-pv4.1.so
[ 86%] Built target pqCore
[ 86%] CS Wrapping - generating vtkStreamingParticlesRepresentationClientServer.cxx
[ 86%] CS Wrapping - generating vtkStreamingParticlesPriorityQueueClientServer.cxx
[ 86%] Generating vtkSMXML_StreamingParticles.h
-- Generate module: StreamingParticles
[ 86%] Generating Documentation HTMLs from xmls
micheldup is offline   Reply With Quote
Old   July 15, 2014, 08:29
It worked after I installed qt4-dev-tools.
[OpenFOAM] Paraview 3.12 memory allocation problem while saving animation jgomez ParaView 17 September 14, 2013 17:03
[General] Paraview problem while launching Tobi ParaView 3 May 11, 2013 15:25
LINUX newbie with paraView installation problem kenya0514 OpenFOAM Installation 4 January 16, 2013 17:51
Problem with 3rd Party SW installation klausb OpenFOAM 2 January 4, 2011 03:43
[OpenFOAM] problem with ParaView 3.8 Chrisi1984 ParaView 6 July 15, 2010 06:47
