[OpenFOAM.org] paraview and python install problem |
June 19, 2013, 21:31 |
laurentL
Rep Power: 14 |
hi all,
sorry for asking such a simple problem but i really face it since 2 days! i want to run paraview in batch mode or just get a pic with a python script. and i am not a expert !!! so i compile paraFoam with makeParaView setup withPYTHON=true PYTHON_LIBRARY="/usr/lib/libpython3.2mu.so.1.0" # PYTHON_LIBRARY="/usr/lib64/libpython2.6.so.1.0" # MESA graphics support: withMESA=false MESA_INCLUDE="/usr/include/GL" MESA_LIBRARY="/usr/lib64/libOSMesa.so" # extra QT gui support (useful for some third party apps) withQT=true # Set the path to the Qt-4.5 (or later) qmake if the system Qt is older QMAKE_PATH="" # Set the path to cmake CMAKE_PATH="" i add in the .bachrc file export PYTHONPATH=$PYTHONPATH:/home/laurent/OpenFOAM/ThirdParty-2.2.0/build/linuxGcc/paraview-3.12.0/Utilities/VTKPythonWrapping/site-packages #fixes "no module named paraview" export PYTHONPATH=$PYTHONPATH:/home/laurent/OpenFOAM/ThirdParty-2.2.0/platforms/linuxGcc/paraview-3.12.0/bin #fixes "ImportError: No module named libvtkCommonPython" and when i run idle3 python i have this message. Python 3.2.1 (default, Jul 18 2011, 16:24:40) [GCC] on linux2 Type "copyright", "credits" or "license()" for more information. >>> import paraview >>> from paraview.simple import * Traceback (most recent call last): File "<pyshell#1>", line 1, in <module> from paraview.simple import * File "/home/laurent/OpenFOAM/ThirdParty-2.2.0/build/linuxGcc/paraview-3.12.0/Utilities/VTKPythonWrapping/site-packages/paraview/simple.py", line 134 raise RuntimeError, "File not readable: %s " % first_file ^ SyntaxError: invalid syntax any help will ve very welcome because i am going mad!!! thank by advance LL |
June 20, 2013, 15:54 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings laurent98,
I'm not sure if ParaView 3.12.0 can handle Python 3.2. Any chance you can indicate which Linux Distribution you are using? This way I could try and reproduce the problem. Best regards, Bruno
June 20, 2013, 19:15 |
laurentL
Rep Power: 14 |
hi Bruno,
thanks a lot for your help. i am using opensuse 12.1 i had try also with python 2.7 still not running but this different message came from idle interpretor; Python 2.7.2 (default, Aug 19 2011, 20:41:43) [GCC] on linux2 Type "copyright", "credits" or "license()" for more information. >>> import paraview >>> from paraview.simple import * Traceback (most recent call last): File "<pyshell#1>", line 1, in <module> from paraview.simple import * File "/home/laurent/OpenFOAM/ThirdParty-2.2.0/build/linuxGcc/paraview-3.12.0/Utilities/VTKPythonWrapping/site-packages/paraview/simple.py", line 40, in <module> import servermanager File "/home/laurent/OpenFOAM/ThirdParty-2.2.0/build/linuxGcc/paraview-3.12.0/Utilities/VTKPythonWrapping/site-packages/paraview/servermanager.py", line 43, in <module> import paraview, re, os, os.path, new, sys, vtk File "/home/laurent/OpenFOAM/ThirdParty-2.2.0/build/linuxGcc/paraview-3.12.0/Utilities/VTKPythonWrapping/site-packages/paraview/vtk/__init__.py", line 1, in <module> from vtkCommonPython import * ImportError: No module named vtkCommonPython >>> i really don t know what to do??? best regards LL |
June 23, 2013, 06:46 |
Christoph Kratzsch
Rep Power: 14 |
Hi folks,
i have exactly the same problem. I have exported the paths as this page says: http://paraview.org/Wiki/ParaView/Py....simple_Module but it doesn't work. My LD_LIBRARY_PATH links to the folder where the vtkCommonCorePython.so should be. I mentioned if it is a 64Bit .so so i do a file-command. This gives me: Code:
file vtkCommonCorePython.so vtkCommonCorePython.so: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=b20cbc6de288730f94f5d4301cfc661ba9d2ac44, stripped System Specifications: Manjaro 0.8.6 python 2.7.5 and python 3.3.2 paraview 4.0.1 LD_LIBRARY_PATH: :/opt/opencascade/lib:/usr/lib/python2.7:/usr/lib PYTHONPATH: :/usr/lib/python2.7/site-packages/:/usr/lib/paraview-4.0/site-packages/ I am using Python just for scripting and evaluation and plotting of my results, but i think this can be used more powerful, if i can couple paraview to that. So laurent98, if you have found a solution to this, please share . Best Regards, Christoph |
June 23, 2013, 13:05 |
Bruno Santos
Rep Power: 128 |
Greetings to all!
OK, to address first laurent98's problem, I've done the following steps in a virtual machine with openSUSE 12.1 64bit (x86_64). laurent98 has got 32bit, but I'll try to keep the instructions generic enough. @Christoph: Try the instructions below, but only starting from the section for the python shell and beyond. For installing, I followed the instructions from here: http://openfoamwiki.net/index.php/In...#openSUSE_12.2 - but I made some changes in the following steps:
source /home/user/OpenFOAM/OpenFOAM-2.2.0/etc/bashrc WM_NCOMPPROCS=4 WM_MPLIB=SYSTEMOPENMPI #added these lines export PYTHONPATH=$PYTHONPATH:/usr/lib/python2.7/site-packages export PYTHONPATH=$PYTHONPATH:$ParaView_DIR/lib/paraview-3.12/site-packages Start a new shell terminal. Then run python: Code:
python Now, within the python shell, run: Code:
import paraview import vtk from paraview.simple import * And that's it! Now, there is one important detail: pvpython is the advised application for interacting with Python + ParaView. To run it, simply run: Code:
pvpython Best regards,Bruno
June 23, 2013, 13:31 |
Christoph Kratzsch
Rep Power: 14 |
Hi Bruno,
thank you for your quick reply. Unfortunately it still doesn't work . Same error as before: As you said i start with: Code:
import paraview import vtk from paraview.simple import * Code:
Error: Could not import vtkCommonComputationalGeometryPython --------------------------------------------------------------------------- ImportError Traceback (most recent call last) <ipython-input-7-fd18706122a4> in <module>() ----> 1 from paraview.simple import * /usr/lib/paraview-4.0/site-packages/paraview/simple.py in <module>() 39 paraview.compatibility.major = 3 40 paraview.compatibility.minor = 5 ---> 41 import servermanager 42 43 #============================================================================== /usr/lib/paraview-4.0/site-packages/paraview/servermanager.py in <module>() 46 # 47 #============================================================================== ---> 48 import paraview, re, os, os.path, new, sys, atexit, vtk 49 50 if not paraview.compatibility.major: /usr/lib/paraview-4.0/site-packages/paraview/vtk/__init__.py in <module>() 5 except ImportError: 6 paraview.print_error("Error: Could not import vtkCommonComputationalGeometryPython") ----> 7 from vtkCommonCorePython import * 8 from vtkCommonDataModelPython import * 9 from vtkCommonExecutionModelPython import * ImportError: No module named vtkCommonCorePython Do you have an idea? Should i start from scratch and compile paraview by myself? Best regards, Christoph |
June 23, 2013, 13:33 |
Bruno Santos
Rep Power: 128 |
Hi Christoph,
Without knowing which Linux Distribution you're using and how you installed ParaView, it's very complicated to figure out what the solution is. Nonetheless, as I indicated in the last few lines of the previous post, pvpython is advised for interacting with ParaView. Best regards, Bruno
June 23, 2013, 14:52 |
Christoph Kratzsch
Rep Power: 14 |
I'm using an ArchLinux-based distro called Manjaro. So i access the Arch User Repository in which the paraview package is. A tool compiles the whole Paraview.
I think i will start compiling it by myself and then go to the next step with pvpython. Thanks up to this point. I will report if i've found a solution. Best regards, Christoph |
June 26, 2013, 17:12 |
#9 |
laurentL
Rep Power: 14 |
hi Bruno,
thank you very much for your help, it is very nice of you. i made some progress in the installation. it seems that python -devel qt4-x11-tools ... was missing. i still have some problemes; after makeparaview -python the tail of terminal log is; ... /home/laurent/OpenFOAM/ThirdParty-2.2.0/ParaView-3.12.0/VTK/Wrapping/Python/vtkPythonArgs.cxx:117:28: error: ‘PyInt_AsLong’ was not declared in this scope make[2]: *** [VTK/Wrapping/Python/CMakeFiles/vtkPythonCore.dir/vtkPythonArgs.cxx.o] Error 1 make[1]: *** [VTK/Wrapping/Python/CMakeFiles/vtkPythonCore.dir/all] Error 2 make: *** [all] Error 2 --- Installation complete for paraview-3.12.0 Set environment variables: export ParaView_DIR=/home/laurent/OpenFOAM/ThirdParty-2.2.0/platforms/linuxGcc/paraview-3.12.0 export PATH=$ParaView_DIR/bin:$PATH export PV_PLUGIN_PATH=$FOAM_LIBBIN/paraview-3.12 --- Done looks like there is a problem with vtk because there is no files vtk*.so here the message after the cp comand; linux-juf1:/home/laurent/OpenFOAM/ThirdParty-2.2.0 # cp $WM_THIRD_PARTY_DIR/build/$WM_ARCH$WM_COMPILER/paraview-$ParaView_VERSION/bin/vtk*.so $ParaView_DIR/lib/paraview-$ParaView_MAJOR/ cp: cannot stat `/home/laurent/OpenFOAM/ThirdParty-2.2.0/build/linuxGcc/paraview-3.12.0/bin/vtk*.so': No such file or directory i have look inside the directory$WM_THIRD_PARTY_DIR/build/$WM_ARCH$WM_COMPILER/paraview-$ParaView_VERSION/bin/ there is some libvtk*.so or others *vtk*.so but nothink like vtk*.so ??? finally in the python interpreter i get; >>> from QVTKPython import * RuntimeError: the sip module implements API v8.0 to v8.1 but the vtk.QVTKPython module requires API v10.0 >>> in which direction should i go??? thanks you again, best regards LL |
June 27, 2013, 17:28 |
#10 |
Bruno Santos
Rep Power: 128 |
Hi Laurent,
I think I know what the problem is. You probably have the two python versions installed: 2.7 and 3.2. But the makeParaView script is having trouble figuring out which Python version should be used. If I'm not mistaken, it's possibly picking up the python application version 3.2 and the include folder only exists for 2.7. But first, confirm if the following command gives you anything: Code:
ls -l /usr/include/python2.7 Then check which Python version it is picking up, by running: Code:
python --version Best regards, Bruno
June 28, 2013, 11:25 |
#11 |
laurentL
Rep Power: 14 |
P { margin-bottom: 0.21cm; } Dear Bruno,
thanks you SO much! It is great, very nice of you to help people as you are doing! You were perfectly right, the problem came from the 2 versions installed of python. So, before to makeParaview I just put in the makeparaview files; withPYTHON=true PYTHON_LIBRARY="/usr/lib/libpython2.7.so.1.0" now , laurent@linux-juf1:~> pvpython Python 2.7.2 (default, Aug 19 2011, 20:41:43) [GCC] on linux2 Type "help", "copyright", "credits" or "license" for more information. >>> import paraview >>> from paraview.simple import * paraview version 3.12.0, Date: 2011-07-26 >>> run ok still import vtk have this problem >>> import vtk Traceback (most recent call last): File "<stdin>", line 1, in <module> File "/usr/lib/python2.7/site-packages/vtk/__init__.py", line 127, in <module> from qvtk import * File "/usr/lib/python2.7/site-packages/vtk/qvtk.py", line 8, in <module> from QVTKPython import * RuntimeError: the sip module implements API v8.0 to v8.1 but the vtk.QVTKPython module requires API v10.0 >>> but I don't know if it is important, I have to play now with python script to do what I went! hope this can help others person, thanks again to Bruno! best regards LL |
February 6, 2014, 09:13 |
#12 |
Luca Franceschini
Rep Power: 13 |
i have some problems on this too. First makeParaView does not recognize my python, so i did: Code:
withPYTHON=true PYTHON_LIBRARY="/usr/lib/libpython2.7.so.1.0" Code:
QSqlDatabase: QSQLITE driver not loaded QSqlDatabase: available drivers: Cannot open data base file /home/flucci/OpenFOAM/ThirdParty-2.2.x/build/linux64Gcc/paraview-3.12.0/Documentation/paraview.qch! make[2]: *** [Documentation/paraview.qch] Error 255 make[1]: *** [Documentation/CMakeFiles/ParaViewOnlineHelp.dir/all] Error 2 make: *** [all] Error 2 --- Installation complete for paraview-3.12.0 Set environment variables: export ParaView_DIR=/home/flucci/OpenFOAM/ThirdParty-2.2.x/platforms/linux64Gcc/paraview-3.12.0 export PATH=$ParaView_DIR/bin:$PATH export PV_PLUGIN_PATH=$FOAM_LIBBIN/paraview-3.12 --- Done I tried to update the PYTHONPATH but both :/usr/lib/python2.7/ and :$ParaView_DIR/lib/paraview-3.12/ do not have the site-packages subdirectories. Moreover if i do : Code:
:~/OpenFOAM/ThirdParty-2.2.x$ python Python 2.7.3 (default, Sep 26 2013, 20:03:06) [GCC 4.6.3] on linux2 Type "help", "copyright", "credits" or "license" for more information. >>> import paraview >>> import vtk Traceback (most recent call last): File "<stdin>", line 1, in <module> File "/usr/lib/pymodules/python2.7/vtk/__init__.py", line 41, in <module> from vtkCommonPython import * ImportError: /home/flucci/Programs/visit/2.6.2/linux-x86_64/lib/libvtkPythonCore.so.5.8: undefined symbol: PyUnicodeUCS2_DecodeUTF8 >>> from paraview.simple import * Segmentation fault (core dumped) few more inputs: i use Ubuntu, OF 2.2.X if i run pvpython i also have : Code:
:~/OpenFOAM/ThirdParty-2.2.x$ pvpython Error converting executable file "/usr/bin/../lib/paraview/pvpython" to real path: No such file or directory THANK YOU A LOT |
February 6, 2014, 17:00 |
#13 |
Bruno Santos
Rep Power: 128 |
Greetings Luca,
Can you specify which version of Ubuntu you are using, so that I can try and replicate the same problem? Best regards, Bruno
February 7, 2014, 03:33 |
#14 |
Luca Franceschini
Rep Power: 13 |
Hi Bruno,
Thank you a lot ( again) for your help. I have the 12.04 LTS. If this procedure is too long is it possible to link paraFoam to a later paraview installtion? (i have an executable of the paraview 4.1 already with the python included..) thank you a lot |
February 15, 2014, 10:53 |
#15 |
Bruno Santos
Rep Power: 128 |
Hi Luca,
Sorry for the late reply. I had a better, yet quick read, of the two posts you've written and the diagnosis is that VisIt is getting in the way. You should make sure that you start with a clean shell environment and then activate only OpenFOAM's shell environment. Then proceed on to building ParaView. If you're not familiar with the shell environment, have a look into this wiki page: http://openfoamwiki.net/index.php/In...with_the_Shell If after using a clean shell environment, without interference from VisIt, you still have problems, let us know! As for using a pre-built ParaView 4.1.0:
Best regards, Bruno
December 12, 2014, 19:33 |
#16 |
luigi
Dear all;
Thank for your previous post. I am still not able to use the "Python Shell" in paraview. Unfortunatly I still have this error when I try to start trace: >>> from paraview.simple import * Traceback (most recent call last): File "<string>", line 4, in <module> File "/opt/paraviewopenfoam3120/lib/paraview-3.12/site-packages/paraview/servermanager.py", line 43, in <module> import paraview, re, os, os.path, new, sys, vtk File "/opt/paraviewopenfoam3120/lib/paraview-3.12/site-packages/paraview/vtk/__init__.py", line 1, in <module> from vtkCommonPython import * ImportError: No module named vtkCommonPython I am using ubuntu 12.04 with OF 2.2.1 and paraview 3.12.0 It seems like vtkCommonPython is not existing on my pc. Do you have any idea how to solve my problem? thank you very much! Luigi |
December 13, 2014, 15:12 |
#17 |
Bruno Santos
Rep Power: 128 |
Greetings Luigi and welcome to posting on the forum!
The error message you're seeing looks familiar to me... have a look at this bug report, which has a solution for this: http://www.openfoam.org/mantisbt/view.php?id=969 More specifically, this solution: http://www.cfd-online.com/Forums/ope...tml#post446490 post #17 Best regards, Bruno
[OpenFOAM.org] ParaView Installation: Python problem | KateEisenhower | OpenFOAM Installation | 5 | August 24, 2017 05:27 |
[General] Determining number of cores and/or paraview executable via python | aerogt3 | ParaView | 0 | December 9, 2014 05:54 |
[OpenFOAM] paraview v4 - building with python - OF2.3.0, PVv4, Python 2.7 | aylalisa | ParaView | 4 | June 13, 2014 08:52 |
How to get Python Shell into ParaView 3.8.1? | blaise | OpenFOAM Installation | 3 | July 24, 2012 04:58 |
ParaView installation problem on Suse 11.4 | victorz | OpenFOAM Installation | 4 | February 6, 2012 17:26 |
