[OpenFOAM.org] OpenFOAM Installation on Centos 6.4 |
December 3, 2014, 01:45 |
Colin
Hi There
I'm trying to install OpenFOAM 2.3 on a 5 node cluster running Centos 6.4. I've followed the guide at https://openfoamwiki.net/index.php/I...CentOS_SL_RHEL based on Centos 6.5, but I've adjusted my $HOME to point to /opt. The reason for doing this is that the /opt directory is a network shared directory --- the plan is to install OpenFOAM once on a single node and then to simply run it from the others. I have however run into errors that I can not resolve. See attached make.log file. Any help would be appreciated. |
December 5, 2014, 08:06 |
Fixed
Colin
Hi Elvis
I managed to get OpenFOAM running properly in the NFS folder by first installing it in my home directory and then moving the OpenFOAM folder to the desired place. I followed wyldckat's instructions from #5 found here http://www.cfd-online.com/Forums/ope...tml#post361663. On an unrelated note: when I ran my simulation I kept running into this error: Code:
Setting up information for layer truncation ... new cannot satisfy memory request. This does not necessarily mean you have run out of virtual memory. It could be due to a stack violation caused by e.g. bad use of pointers or an out of date shared library new cannot satisfy memory request. I think this may have been caused by the NFS folder only being on a 50GB partition... :P Unfortunately I can't run my simulation again. See log file for details. bmw_snappy.log.tar.gz |
December 14, 2014, 08:44 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
@Colin: I'm sorry to say that the error message was due to a rookie mistake: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.3.0-f5222ca19ce6 Exec : snappyHexMesh -overwrite The result was that you had X processes, all trying to create the same mesh, requiring X*N memory in total, instead of just N for the whole parallel mesh generation. Best regards, Bruno
centos 6.4, cluster computing, network file system, openfoam 2.3.0, parallel computation |
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 5, 2016 03:18 |
[OpenFOAM.org] OpenFOAM 2.3.0 Installation Problem on CentOS 6.6 | shenzhou1987 | OpenFOAM Installation | 1 | December 14, 2014 13:34 |
OpenFOAM 1.6.x - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 68 | April 22, 2013 11:03 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
