December 5, 2014, 17:32 |
OpenFOAM 2.3.0 on CentOS 6.6
Dennis
Hi all,
I'm trying to install OpenFOAM 2.3.0 on CentOS 6.6 according to the guide on OpenFOAM's wiki: https://openfoamwiki.net/index.php/I...HEL#CentOS_6.5 I've followed all the steps but when trying to build ParaView, it complaints about an Intel library that does not exist since I'm not using Intel compiler of any kind. The error I'm getting: Code:
/opt/OpenFOAM/ThirdParty-2.3.0/platforms/linux64/gcc-4.8.1/lib/gcc/x86_64-unknown-linux-gnu/4.8.1/../../../../x86_64-unknown-linux-gnu/bin/ld: warning: libimf.so, needed by /usr/local/lib/libz.so, not found (try using -rpath or -rpath-link) /opt/OpenFOAM/ThirdParty-2.3.0/platforms/linux64/gcc-4.8.1/lib/gcc/x86_64-unknown-linux-gnu/4.8.1/../../../../x86_64-unknown-linux-gnu/bin/ld: warning: libsvml.so, needed by /usr/local/lib/libz.so, not found (try using -rpath or -rpath-link) /opt/OpenFOAM/ThirdParty-2.3.0/platforms/linux64/gcc-4.8.1/lib/gcc/x86_64-unknown-linux-gnu/4.8.1/../../../../x86_64-unknown-linux-gnu/bin/ld: warning: libirng.so, needed by /usr/local/lib/libz.so, not found (try using -rpath or -rpath-link) /opt/OpenFOAM/ThirdParty-2.3.0/platforms/linux64/gcc-4.8.1/lib/gcc/x86_64-unknown-linux-gnu/4.8.1/../../../../x86_64-unknown-linux-gnu/bin/ld: warning: libintlc.so.5, needed by /usr/local/lib/libz.so, not found (try using -rpath or -rpath-link) Code:
cd $FOAM_UTILITIES/postProcessing/graphics/PV4Readers wmSET $FOAM_SETTINGS ./Allwclean ./Allwmake Code:
ERROR: ParaView not found in /opt/OpenFOAM/ThirdParty-2.3.0/platforms/linux64Gcc48/ParaView-4.1.0 |
December 8, 2014, 17:12 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Dennis,
According to your previous post, you once tried out the Xeon Phi co-processor and that apparently left a mark on your system. More specifically, the file: Code:
/usr/local/lib/libz.so The way I see it, you have at least two choices:
Bruno
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 5, 2016 03:18 |
[OpenFOAM.org] OpenFOAM 2.3.1 installation error on CentOS 6.6 | Naresh yathuru | OpenFOAM Installation | 2 | February 16, 2015 13:14 |
[OpenFOAM.org] OpenFOAM 2.3.0 Installation Problem on CentOS 6.6 | shenzhou1987 | OpenFOAM Installation | 1 | December 14, 2014 13:34 |
Unable to run a case with OpenFOAM 1.6-ext that works with OpenFOAM 2.3.0 | Jiricbeng | OpenFOAM Running, Solving & CFD | 15 | May 21, 2014 03:52 |
