[IHFOAM] IHFOAM--Dynamic Linking of the Boundary Conditions
Like Tree1Likes
  • 1 Post By wyldckat
Old   January 18, 2015, 00:27
Default IHFOAM--Dynamic Linking of the Boundary Conditions
Chun-Ming Chang
glazejimmy is on a distinguished road
Hi
I am a beginner of OpenFOAM. I use OpenFOAM to generate waves and study coastal engineering.
Recently, I find IHFOAM that can generate several kinds of waves.
But I have some problems about the installation of IHFOAM.
May someone can tell me what the following statement means?
libs
"libIHwaveGeneration.so"
"libIHwaveAbsorption.so"
where I can find the folder and what I should do?
glazejimmy is offline   Reply With Quote
Old   January 18, 2015, 04:12
Retired Super Moderator
Bruno Santos
Greetings glazejimmy and welcome to posting on the forum!
The "libs" block is explained in the user guide: http://www.openfoam.org/docs/user/controlDict.php
List of additional libraries (on $LD_LIBRARY_PATH) to be loaded at run-time, e.g.( "libUser1.so" "libUser2.so" )
Those libraries you're asking about, if and when they have been built with success, they should be located in the folder indicated by the following command:
echo $FOAM_USER_LIBBIN
For more details, please see the User Guide as well: http://www.openfoam.org/docs/user/co...plications.php
As for installing IHFOAM, the instructions on the wiki are fairly easy to follow: http://openfoamwiki.net/index.php/Co...nd_Compilation
Best regards,
Bruno
Phicau likes this.
Old   January 21, 2015, 00:36
Chun-Ming Chang
Thanks wyldckat, I try your suggestion and run successfully.
ihfoam
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 01:27
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 05:15
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 11:19
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 17:30
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
