[OpenFOAM.org] After building OF 2.3.x the motorBike-tutorial does not run |
February 17, 2015, 03:58 |
BastiL
Rep Power: 20 |
Hello all,
I have compiled OF 2.3.x successfully, everything went fine. Now I tried to run the motorbike tutorial. For this, every application (even blockMesh, surfaceFeatureExtract,...) fails: Code:
--> FOAM FATAL IO ERROR: Cannot open controlDict file: /fem7a/BL/OpenFOAM/OpenFOAM-2.3.x/etc/controlDict at line 0. Code:
ls -la /fem7a/BL/OpenFOAM/OpenFOAM-2.3.x/etc/controlDict -rw-rw-rw- 1 fem user 31268 13. Feb 10:19 /fem7a/BL/OpenFOAM/OpenFOAM-2.3.x/etc/controlDict |
February 17, 2015, 09:29 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Bastil,
My guess is that you're witnessing SELinux doing its job. A few questions:
Bruno
February 17, 2015, 09:56 |
#3 | |
BastiL
Rep Power: 20 |
yes I can open the file with a text editor and everything in there looks fine. 1. I build with user permissions 2. Code:
ls -laZ $WM_PROJECT_DIR/etc/controlDict -rw-r--r-- fem user /fem7a/BL/OpenFOAM/OpenFOAM-2.3.x/etc/controlDict |
February 17, 2015, 16:11 |
Bruno Santos
Rep Power: 128 |
Hi Bastil,
This error seems very familiar... I was almost certain this was an SELinux issue, but your system isn't even reporting anything about the SELinux context for the file. OK, the two ideas that come to mind are as follows:
Beyond this... it feels like this could be an issue related to NFS? I say this because of the strange path "/fem7a/BL", which suggests a special file-system, which is either network based or has some security measures in place. Best regards, Bruno |
February 18, 2015, 09:27 |
BastiL
Rep Power: 20 |
Thanks. I needed to rebuild because of another problem which now fails (see my other post) so this is not so important at the moment.
motorBike tutorial | Eko | OpenFOAM Running, Solving & CFD | 4 | December 20, 2017 07:34 |
Fix the fairing in the motorbike tutorial | stormspirit | OpenFOAM Running, Solving & CFD | 2 | May 4, 2016 12:49 |
[foam-extend.org] Error compiling OpenFOAM-1.6-ext | Canesin | OpenFOAM Installation | 137 | January 20, 2016 14:56 |
Compilation error OF1.5-dev on Suse10.3 | darenyang | OpenFOAM Installation | 0 | April 29, 2009 04:55 |
Cannot run Tutorial 11, please help | Harendra | Siemens | 1 | November 21, 2005 06:14 |
