[OpenFOAM.org] Installation of OpenFOAM 2.3.1 on RHEL 6.3 |
March 24, 2015, 01:27 |
Jack B.
Rep Power: 16 |
Is it possbile to install OpenFOAM 2.3.1 on RHEL Server 6.3? The latest upgradable GCC version for the system is 4.4.7 while OpenFOAM demands GCC 4.5.0 and above. Any help would be appreciated. Thanks, Jack |
March 24, 2015, 10:55 |
Yes, it is possible. You even have two possibilities: 1. Build newer version gcc (using makeGcc script from ThirdParty folder, http://openfoamwiki.net/index.php/In...HEL#CentOS_6.5) 2. Install newer version of Gcc using Sofware Collections (https://access.redhat.com/documentat...e_Collections/). |
March 26, 2015, 03:32 |
Hi Jack,
here comes another way I used [but before try Alexey's suggestion that is a more elegant solution] Similarly to you, I had a redhat server 6.4 Santiago, and gcc 4.4.7 without the possibility to become root. Therefore I did the following: 1) take an hard disk with some GB of space and install on it virtual box portable http://www.vbox.me/ 2) create a virtual machine installing CentOS 6.6 3) follow the instruction from http://www.openfoam.org/download/git.php 4) copy the compiled version of the virtual machine into your redhat 6.4 server 5) modify the environment variables I test some tutorials and they are running well. If you are interested in more details I copy below my diary of command executed: In the virtual machine centOS6.6: as root: Code:
yum install git Code:
cd /home/donQi/OpenFOAM Code:
git clone git://github.com/OpenFOAM/OpenFOAM-2.3.x.git cd OpenFOAM-2.3.x git pull (always as normal user) Code:
tar xzf ThirdParty-2.3.1.tgz mv ThirdParty-2.3.1 ThirdParty-2.3.x Code:
yum groupinstall 'Development Tools' yum install openmpi openmpi-devel yum-config-manager --nogpgcheck --add-repo http://dl.atrpms.net/el6-x86_64/atrpms/stable yum install --nogpgcheck qtwebkit qtwebkit-devel yum install --nogpgcheck CGAL CGAL-devel Code:
ln -s /usr/lib64/libboost_thread-mt.so /usr/lib64/libboost_thread.so Code:
gedit ~/.bashrc Code:
export PATH=/usr/lib64/openmpi/bin/:$PATH export LD_LIBRARY_PATH=/usr/lib64/openmpi/lib/:$LD_LIBRARY_PATH Code:
source ~/.bashrc mpirun --version mpirun (Open MPI) 1.8.1 then as root: Code:
yum-config-manager --nogpgcheck --add-repo http://springdale.princeton.edu/data/puias/6.5/x86_64/os yum-config-manager --nogpgcheck --add-repo http://springdale.princeton.edu/data/puias/DevToolset/6.5/x86_64 yum install --nogpgcheck devtoolset-1.1-runtime devtoolset-1.1-gcc.x86_64 devtoolset-1.1-gcc-c++.x86_64 Code:
source /opt/rh/devtoolset-1.1/enable Code:
source /opt/rh/devtoolset-1.1/enable gcc --version Code:
gcc (GCC) 4.7.2 20121015 (Red Hat 4.7.2-5) Copyright (C) 2012 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. ENVIRONMENT VARIABLES in thunder VirtualMachine where we had /home/donQi/OpenFOAM/ we have just add in ~/.bashrc : Code:
source $HOME/OpenFOAM/OpenFOAM-2.3.x/etc/bashrc foam and you should be in the directory OpenFOAM-2.3.x let's check Code:
foamSystemCheck Code:
System check: PASS Then Code:
cd $WM_PROJECT_DIR Code:
yum install zlib-static yum install glibc-static Code:
yum install --nogpgcheck zlib-static yum install --nogpgcheck glibc-static Code:
./Allwmake > make.log 2>&1 Now back to copy in our server. >> Copying the compiled openFOAM to Redhat6.4 / In the thunder VirtualMachine, copy all the files inside the OpenFOAM directory into the share directory: Code:
sudo su - cd -rL /home/donQi/OpenFOAM/* /media/sf_ShareThunder Then back to the RedHat6.4 machine: we copy the directory from the virtual machine (OpenFOAM-2.3.x, donQi-2.3.x and ThirdParty-2.3.x) into Code:
/net/lnx6/home/donQi/OpenFOAM/thunderCompiled Code:
alias OF23x='. /net/lnx6/home/donQi/OpenFOAM/thunderCompiled/OpenFOAM-2.3.x/etc/bashrc' Code:
foamInstall=/net/lnx6/home/donQi/OpenFOAM/thunderCompiled/ Code:
source ~/.bashrc OF23x tut cd incompressible/icoFoam blockMesh Code:
[1034 cavity] >> blockMesh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.3.x-c70d1f3c1beb Exec : blockMesh Date : Mar 26 2015 |
rhel 6.3 |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
RHEL 6.3 Installation problem | Turbulent | STAR-CCM+ | 0 | September 3, 2014 07:01 |
[Discussion] Restructuring the Installation page at openfoamwiki.net | wyldckat | OpenFOAM Installation | 16 | November 2, 2013 11:43 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
OpenFOAM 1.7.1 installation problem on Fedora 14 | armonica | OpenFOAM Installation | 16 | March 31, 2011 13:16 |
