May 28, 2015, 13:09 |
Segmentation Fault paraView
Rep Power: 10 |
Hello all,
I got a problem with my paraView installation (Version 4.1.0). When I try to open my OpenFoam-file I get the error message stated below. It's strange because it worked before. Anybody knows a solution? I am using Ubuntu 14.04 LTS Segmentation fault (core dumped) hendrik@hendrik-P5K-PRO:~/Desktop/349240_314492/Aufgabe1/Aufgabe1SimRe500$ paraview --> FOAM FATAL IO ERROR: "ill defined primitiveEntry starting at keyword 'version' on line 12 and ending at line 12" file: /home/hendrik/Desktop/349240_314492/Aufgabe1/Aufgabe1SimRe500/system/controlDict at line 12. From function primitiveEntry::readEntry(const dictionary&, Istream&) in file lnInclude/IOerror.C at line 132. FOAM exiting |
May 29, 2015, 18:43 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings hcl734 and welcome to the forum!
Sorry, but I'm unable to diagnose the problem without more details. There are two error messages in the output you provided, where one simply crashes and the other complains about the contents of the file "system/controlDict". Please provided more details. For example:
Beyond this, the best I can suggest is that you check this thread for ideas: http://www.cfd-online.com/Forums/ope...-paraview.html Best regards, Bruno
[OpenFOAM] Segmentation fault with paraview 3.10.1 | aot | ParaView | 5 | June 5, 2023 01:32 |
[OpenFOAM] paraview parafoam segmentation fault (core dumped) | RicardoLB | ParaView | 3 | April 28, 2020 20:07 |
[OpenFOAM.org] Paraview 5.4 in shell environment of5x - Segmentation fault (core dumped) | dslbkxd | OpenFOAM Installation | 1 | February 3, 2018 00:56 |
[General] Paraview segmentation fault | jrmuller | ParaView | 0 | December 10, 2012 12:02 |
ParaView segmentation fault only for multiphase | gwierink | OpenFOAM | 9 | March 25, 2010 07:23 |
