[OpenFOAM.org] CGAL/Delaunay_triangulation_2.h
Like Tree1Likes
  • 1 Post By lele
Old   July 29, 2015, 11:48
Default CGAL/Delaunay_triangulation_2.h
emanuele lombardi
lele is on a distinguished road
I'm new to OpenFOAM and I'm trying to install version 2.4.0 on my SLES11SP3 machine.
I followed the instructions found at https://openfoamwiki.net/index.php/I...nux_Enterprise
I first run Allwmake in ThirdParty-2.4.0 and then in OpenFOAM-2.4.0
The first Allwmake went went smoothly without any problem, but the Allwmake in OpenFOAM-2.4.0 is faulty. Errors are like the following one:
In file included from CGALTriangulation2Ddefs.H:44:0,
                 from CV2D.H:120,
                 from insertBoundaryConformPointPairs.C:26:
CGALTriangulation2DKernel.H:36:43: fatal error: CGAL/Delaunay_triangulation_2.h: No such file or directory
The file Delaunay_triangulation_2.h is not found by the script but there are two of them!
find . -name Delaunay_triangulation_2.h
./ThirdParty-2.4.0/CGAL-4.6/include/CGAL/Kinetic/Delaunay_triangulation_2.h
./ThirdParty-2.4.0/CGAL-4.6/include/CGAL/Delaunay_triangulation_2.h
Can anybody help me?
thankk you from Italy,
Lele
Last edited by wyldckat; August 2, 2015 at 15:38. Reason: Added [CODE][/CODE] markers and removed text formatting, the font was too small.
lele is offline   Reply With Quote
Old   August 2, 2015, 15:40
Retired Super Moderator
Bruno Santos
Greetings Lele and welcome to the forum!
Please run the following commands:
cd $WM_THIRD_PARTY_DIR
./Allwmake > make.log 2>&1
gzip < make.log > make.log.gz
pwd
And then attach the file "make.log.gz" to your next post. The file is located in the folder pointed out by the last command.
I need this file for diagnosing the problem.
Best regards,
Bruno
Old   August 3, 2015, 03:38
emanuele lombardi
Dear Bruno,
thanks for your help.
Please find the log of my Allwmake in ThirdParty.
It is the original log, the one I got when I compiled OpenFOAM.
I don't succeed in attaching the log of OpenFOAM compilation because it's too large.
Please note that I'm using gcc5.2 (since my gcc was too old and I had to build a newer one, I decided to build the latest)
Ciao,
Emanuele
Old   August 4, 2015, 17:50
Bruno Santos
Hi Emanuele,
Unfortunately I haven't had to the opportunity to test building OpenFOAM in SLE 11, which is why the instructions aren't on the wiki yet. This to say that the instructions that are meant for SLE 12 rely on the system's Boost toolbox, but the one in SLE 11 is too old to be used for building CGAL.
Nonetheless, there are some bits and pieces that you can use from these instructions: https://openfoamwiki.net/index.php/I...EL#CentOS_5.11 - namely:
  1. You will need to change the Boost version to be used, by running:
    cd $WM_PROJECT_DIR
    sed -i -e 's=boost-system=boost_1_54_0=' OpenFOAM-2.4.0/etc/config/CGAL.sh
  2. Then set-up things needed for building this Boost version:
    alias wget="wget --no-check-certificate"
    wget "https://raw.github.com/wyldckat/scripts4OpenFOAM3rdParty/master/getBoost"
    chmod +x get*
    ./getBoost
    sed -i -e 's=boost-system=boost_1_54_0=' makeCGAL
  3. In addition, Open-MPI was not built with success. This can be fixed as reported here: http://www.openfoam.org/mantisbt/view.php?id=1770#c5036 - namely by running:
    wget www.open-mpi.org/software/ompi/v1.8/downloads/openmpi-1.8.5.tar.gz
    tar -xf openmpi-1.8.5.tar.gz
  4. Then you can run once again:
    If all goes well, this should now build with success all of the desired packages that are expected to be built with this command.
Best regards,
Bruno
Old   August 5, 2015, 07:43
emanuele lombardi
Hi Bruno,
thanks to your help now I have a running system!
Since my gcc5.2 is in /usr/local I had to add /usr/local/lib64 in $LD_LIBRARY_PATH to let the installation test run.
Dear Bruno,
thanks a lot,
Emanuele
Executing /usr/local/src/OpenFOAM/OpenFOAM-2.4.0/bin/foamInstallationTest:
Checking basic setup...
Shell: tcsh
Host: giotto
OS: Linux version 3.0.101-0.47.55-default
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /usr/local/src/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /root/OpenFOAM/root-2.4.0 yes no
$WM_THIRD_PARTY_DIR /usr/local/src/OpenFOAM/ThirdParty-2.4.0 yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /usr/local/src/OpenFOAM/OpenFOAM-2.4.0 yes yes yes
$FOAM_APPBIN ...-2.4.0/platforms/linux64GccDPOpt/bin yes yes yes
$FOAM_SITE_APPBIN .../2.4.0/platforms/linux64GccDPOpt/bin no no
$FOAM_USER_APPBIN ...-2.4.0/platforms/linux64GccDPOpt/bin no no
$WM_DIR ...al/src/OpenFOAM/OpenFOAM-2.4.0/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...-2.4.0/platforms/linux64GccDPOpt/lib yes yes yes
$FOAM_SITE_LIBBIN .../2.4.0/platforms/linux64GccDPOpt/lib no no
$FOAM_USER_LIBBIN ...-2.4.0/platforms/linux64GccDPOpt/lib no no
$MPI_ARCH_PATH ...0/platforms/linux64Gcc/openmpi-1.8.5 yes yes yes
Third party software
Software Version Location
flex 2.5.35 /usr/bin/flex
gcc 5.2.0 /usr/local/bin/gcc
g++ 5.2.0 /usr/local/bin/g++
gzip 1.3.12 /bin/gzip
tar 1.26 /bin/tar
icoFoam 2.4.0 ...M/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/bin/icoFoam
Summary
Base configuration ok.
Critical systems ok.
Done
wyldckat likes this.
