[swak4Foam] Problems with 'svn.code.sf.net' and error in installation of swak4Foam |
August 9, 2015, 11:24 |
Ehsan
Rep Power: 26 |
when I want to install swak4Foam from openfoamwiki.net page this message is appeared:
ehsan@ehsan-N56JK:~$ svn checkout svn://svn.code.sf.net/p/openfoam-extend/svn/trunk/Breeder_2.0/libraries/swak4Foam/ swak4Foam_2.x svn: E670002: Unable to connect to a repository at URL 'svn://svn.code.sf.net/p/openfoam-extend/svn/trunk/Breeder_2.0/libraries/swak4Foam' svn: E670002: Unknown hostname 'svn.code.sf.net' thanks.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
August 9, 2015, 12:09 |
an error in compile of swak4Foam:MeshDistFromPatch.H: No such file or directory
Ehsan
Rep Power: 26 |
while downloaded swak4Foam was compiling this error occurred:
FieldValueExpressionDriver.C:38:31: fatal error: MeshDistFromPatch.H: No such file or directory #include "MeshDistFromPatch.H" ^ compilation terminated. make: *** [Make/linux64GccDPOpt/FieldValueExpressionDriver.o] Error 1 Parser library did not compile OK. No sense continuing as everything else depends on it the file isn't downloaded correctly or any needed file doesn't installed? thanks a lot for helping.
August 9, 2015, 14:00 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick question: I know that you're using OpenFOAM 2.4.0, but which version of swak4Foam have you downloaded and from where?
edit: I then remembered you are using Ubuntu 14.04, which has by default bison 3.0.2, which is not compatible with swak4Foam. This is the most likely reason for this error message, therefore please follow these instructions: http://openfoamwiki.net/index.php/In...ndencies#Bison In addition, there is a page that has several details on possible problems that can occur when building swak4Foam: http://openfoamwiki.net/index.php/In...Error_Messages Last edited by wyldckat; August 9, 2015 at 14:39. Reason: see "edit:" |
