[swak4Foam] Problem in Installing swak4Foam
Like Tree1Likes
  • 1 Post By michu
Old   August 12, 2015, 08:29
Default Problem in Installing swak4Foam
Arjang Behnoud
AmirBaqa1987 is on a distinguished road
Dear friends,
I've tried to install swak4Foam on OpenFOAM 2.3, but I faced the following message:
Previously compiled for OpenFOAM 2.3.0
Reading variables from 'swakConfiguration'
swakConfiguration: line 1: python-config: command not found
swakConfiguration: line 2: python-config: command not found
swakConfiguration: line 13: [: : integer expression expected
Checking swak4Foam-version and generating file
Swak version is 0.3.2
Bison is version 2.5
Flex is version 2.5.35 (Minor version: 35)
OpenFOAM-version: Major 2 Minor 3 Patch 0 (-1 == x / 0)
No change to swak4FoamParsers/foamVersion4swak.H
'/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so' is up to date.
'/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/lib/libswakLagrangianParser.so' is up to date.
'/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/lib/libgroovyBC.so' is up to date.
'/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/lib/libswakFunctionObjects.so' is up to date.
'/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/lib/libsimpleFunctionObjects.so' is up to date.
'/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/lib/libsimpleLagrangianFunctionObjects.so' is up to date.
'/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/lib/libsimpleSearchableSurfaces.so' is up to date.
'/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/lib/libsimpleSwakFunctionObjects.so' is up to date.
'/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/lib/libswakTopoSources.so' is up to date.
'/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/lib/libswakSourceFields.so' is up to date.
Compiling swakFvOptions
'/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/lib/libswakFvOptions.so' is up to date.
'/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/lib/libgroovyStandardBCs.so' is up to date.
SWAK_PYTHON_INCLUDE not defined .... no Python-Integration. Most people are fine without it
'/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/lib/libswakChemistryModelFunctionPlugin.so' is up to date.
'/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/lib/libswakFvcSchemesFunctionPlugin.so' is up to date.
'/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/lib/libswakLagrangianCloudSourcesFunctionPlugin.so' is up to date.
'/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/lib/libswakLocalCalculationsFunctionPlugin.so' is up to date.
'/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/lib/libswakMeshQualityFunctionPlugin.so' is up to date.
'/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/lib/libswakMeshWaveFunctionPlugin.so' is up to date.
'/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/lib/libswakRadiationModelFunctionPlugin.so' is up to date.
'/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/lib/libswakRandomFunctionPlugin.so' is up to date.
'/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/lib/libswakSurfacesAndSetsFunctionPlugin.so' is up to date.
'/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/lib/libswakThermoTurbFunctionPlugin.so' is up to date.
'/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/lib/libswakTransportTurbFunctionPlugin.so' is up to date.
'/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/lib/libswakVelocityFunctionPlugin.so' is up to date.
'/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/lib/libswakCoalCloudAdaptor.so' is up to date.
If you have your own function-plugins you can specify them using the SWAK_USER_PLUGINS environment variable and they would be compiled now. If you don't know what this means: don't bother. You propably don't need it
make[1]: Entering directory `/home/amir/Desktop/swak4Foam-compiled/swak4Foam_2.x/Utilities/calcNonUniformOffsetsForMapped'
make[1]: `/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/bin/calcNonUniformOffsetsForMapped' is up to date.
make[1]: Leaving directory `/home/amir/Desktop/swak4Foam-compiled/swak4Foam_2.x/Utilities/calcNonUniformOffsetsForMapped'
make[1]: Entering directory `/home/amir/Desktop/swak4Foam-compiled/swak4Foam_2.x/Utilities/fieldReport'
make[1]: `/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/bin/fieldReport' is up to date.
make[1]: Leaving directory `/home/amir/Desktop/swak4Foam-compiled/swak4Foam_2.x/Utilities/fieldReport'
make[1]: Entering directory `/home/amir/Desktop/swak4Foam-compiled/swak4Foam_2.x/Utilities/funkyDoCalc'
make[1]: `/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/bin/funkyDoCalc' is up to date.
make[1]: Leaving directory `/home/amir/Desktop/swak4Foam-compiled/swak4Foam_2.x/Utilities/funkyDoCalc'
SWAK_PYTHON_INCLUDE not defined .... no Python-Integration. Utility funkyPythonPostproc not compiled
make[1]: Entering directory `/home/amir/Desktop/swak4Foam-compiled/swak4Foam_2.x/Utilities/funkySetBoundaryField'
make[1]: `/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/bin/funkySetBoundaryField' is up to date.
make[1]: Leaving directory `/home/amir/Desktop/swak4Foam-compiled/swak4Foam_2.x/Utilities/funkySetBoundaryField'
make[1]: Entering directory `/home/amir/Desktop/swak4Foam-compiled/swak4Foam_2.x/Utilities/funkySetFields'
make[1]: `/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/bin/funkySetFields' is up to date.
make[1]: Leaving directory `/home/amir/Desktop/swak4Foam-compiled/swak4Foam_2.x/Utilities/funkySetFields'
make[1]: Entering directory `/home/amir/Desktop/swak4Foam-compiled/swak4Foam_2.x/Utilities/funkySetLagrangianField'
make[1]: `/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/bin/funkySetLagrangianField' is up to date.
make[1]: Leaving directory `/home/amir/Desktop/swak4Foam-compiled/swak4Foam_2.x/Utilities/funkySetLagrangianField'
make[1]: Entering directory `/home/amir/Desktop/swak4Foam-compiled/swak4Foam_2.x/Utilities/funkyWarpMesh'
make[1]: `/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/bin/funkyWarpMesh' is up to date.
make[1]: Leaving directory `/home/amir/Desktop/swak4Foam-compiled/swak4Foam_2.x/Utilities/funkyWarpMesh'
make[1]: Entering directory `/home/amir/Desktop/swak4Foam-compiled/swak4Foam_2.x/Utilities/replayTransientBC'
make[1]: `/home/amir/OpenFOAM/amir-2.3.0/platforms/linux64GccDPOpt/bin/replayTransientBC' is up to date.
make[1]: Leaving directory `/home/amir/Desktop/swak4Foam-compiled/swak4Foam_2.x/Utilities/replayTransientBC'
If you want to use swakCoded-function object or compile software based on swak set the environment variable SWAK4FOAM_SRC to /home/amir/Desktop/swak4Foam-compiled/swak4Foam_2.x/Libraries (most people will be fine without setting that variable)
how can i overcome this problem?
Best Regards,
Arjang
Last edited by wyldckat; August 12, 2015 at 15:08. Reason: Added [CODE][/CODE] markers
AmirBaqa1987 is offline   Reply With Quote
Old   August 12, 2015, 12:52
Michu
michu is on a distinguished road
I was having a similar problem in my Openfoam. (Thread: http://www.cfd-online.com/Forums/ope...ate-swirl.html) but I think I managed to figure out how to fix one or two of the problems. If you look in the file swakConfiguration you will notice the first and second lines:
export SWAK_PYTHON_INCLUDE="$(python-config --cflags)"
export SWAK_PYTHON_LINK="$(python-config --ldflags)"
try to copy and paste into a terminal just:
I got a notice saying that python-config is not installed and to install it.
It fixed the error messages about Line 1 and Line 2 in the swakConfiguration.
Also if you want to do the thing at the end just enter:
export SWAK4FOAM_SRC=/home/amir/Desktop/swak4Foam-compiled/swak4Foam_2.x/Libraries
Cheers,
~Michu
AmirBaqa1987 likes this.
michu is offline   Reply With Quote
Old   August 13, 2015, 06:53
Arjang Behnoud
Cheers,
~Michu
Dear Michu,
The problem is solved.
Thanks a lot.
Old   August 13, 2015, 09:11
Michu
Hello Arjang,
Glad that helped. I was just curious how you fixed the error in line 13 or the error with swak4Foam. Do you mind sharing how you fixed the problem?
Thank you,
~Michu
Old   November 19, 2015, 13:07
Sandra
sabago is on a distinguished road
Hello all!
Anyone have an idea how to get rid of the line 13 error?
I was initially having this problem: http://www.cfd-online.com/Forums/ope...n-problem.html
And after taking a break and reinstalling, I can't seem to get past this error:
/home/sandra/OpenFOAM/sandra-2.3.0/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison)
abort: no repository found in '/home/sandra/OpenFOAM/sandra-2.3.0/swak4Foam' (.hg not found)!
./Allwmake: line 61: wmake: command not found
Requirements for Library not satisfied. I see no sense in going on
Check the README before you go on to ask. And search: Most likely your problem occured to 5 other people before and has been solved on the MessageBoard
I also tried the suggestions in this thread: http://www.cfd-online.com/Forums/ope...ate-swirl.html
Best regards,
Sandra
sabago is offline   Reply With Quote
Old   November 19, 2015, 15:43
Michu
Hello Sandra,
So technically when installing swak4foam the swakconfiguration file can be deleted. I think your problem is something else. I got this error when I didn't do another step (if memory serves). I think based on the code you provided your bison version may be out of date? Actually- what version of openfoam are you using? (and just to confirm your using swak 0.3.2 right?)
~Michu
Old   November 19, 2015, 15:54
Sandra
Hello Sandra,
Hi Michu,
Yes, Bruno did suggest that in one of the links that I cite but instead it gave an error along the lines that "swakConfiguration couldn't be found"
~Michu
I installed it by going through all the links here: https://openfoamwiki.net/index.php/I...tion/swak4Foam
which also involved a manual install of bison and m4.
Also, I had installed it successfully a couple of weeks ago but had to reinstall due to unavoidable circumstances so I'm quite familiar with the process now, I think.
And I'm using OpenFOAM-2.3.0 and swak 0.3.2.
Although I saw the last post in a thread where you seem to still be stuck with the line 13 error; did you solve it?
Sandra
Old   November 19, 2015, 16:14
Michu
Hello Sandra,
I talked to a python programming friend a while back when I was still trying to get that to work. He told me that line is actually incomplete and needs like either another number or reference to somewhere else or reference to another config file or a ; at the end. (I don't remember exactly what.) Sorry I can't be more helpful with line 13.
As a side note I am still working with swak4foam and at least for me it is working without the swakconfiguration file. And for me when I did install and was getting errors with the swakconfiguration I dont remember the
"./Allwmake: line 61: wmake: command not found"
I am currently running a simulation on my computer but when it is done Ill check out one other thing and see if that helps.
Cheers,
~ Michu
Old   November 19, 2015, 17:27
Sandra
Thanks for your input Michu!
Does anyone know how I can avoid the "swakConfiguration not found" related error when I delete the swakConfiguration files?
Do I have to delete all four (.automatic, .centos6, .debian and .examples)? If you've taken this route of ignoring Python in swak4foam, care to share at which step you deleted this files to avoid the error that insists I need the swakConfiguration file?
Best,
Sandra
Old   November 20, 2015, 12:18
Sandra
It turns out that I wasn't installing in the right folder.
The fix is here: http://www.cfd-online.com/Forums/ope...tml#post574225.
Best regards,
Sandra
Problem while installing the LEMOS-2.4.x manju819 OpenFOAM Running, Solving & CFD 1 August 8, 2016 05:38
[swak4Foam] foam-extend-3.2 installing problem: swak4Foam failed to install due to Bison lxwd OpenFOAM Community Contributions 1 March 20, 2016 16:03
[swak4Foam] fails in parallel with -otherTime? Phicau OpenFOAM Community Contributions 3 June 26, 2013 13:00
[swak4Foam] problem on installing swak4Foam navid2 OpenFOAM Community Contributions 2 May 30, 2012 04:32
[swak4Foam] compilation problem ganeshv OpenFOAM Community Contributions 5 November 11, 2011 16:39
