October 7, 2015, 04:31 |
wmake problem
I tried to modify the forces.C a bit, to ease the post processing. Then, when trying to wmake it, I get Code:
+ wmake libso cloud ./Allwmake: 6: ./Allwmake: wmake: not found + wmake libso field ./Allwmake: 7: ./Allwmake: wmake: not found + wmake libso forces ./Allwmake: 8: ./Allwmake: wmake: not found + wmake libso fvTools ./Allwmake: 9: ./Allwmake: wmake: not found + wmake libso IO ./Allwmake: 10: ./Allwmake: wmake: not found + wmake libso jobControl ./Allwmake: 11: ./Allwmake: wmake: not found + wmake libso systemCall ./Allwmake: 12: ./Allwmake: wmake: not found + wmake libso utilities ./Allwmake: 13: ./Allwmake: wmake: not found Code:
/usr/bin/make Code:
/opt/openfoam240/wmake/wmake |
October 8, 2015, 06:01 |
Joachim Herb
Rep Power: 21 |
Did you call
source $HOME/OpenFOAM/OpenFOAM-2.4.0/etc/bashrc Code:
which wmake |
Display Modes | |
Mesh& steptime independant: conduction-convection problem | Fati1 | Main CFD Forum | 1 | October 28, 2018 14:52 |
wmake problem: "sudo: wmake: command not found" | Luiggito | OpenFOAM Programming & Development | 1 | January 11, 2015 14:48 |
code compilation problem with wmake | bmikuz | OpenFOAM Programming & Development | 2 | October 17, 2012 10:30 |
OpenFOAM installation problem. File missing in wmake | shangzung | OpenFOAM Installation | 1 | July 8, 2010 11:57 |
Problem of compilation OF 14Allwmake command not found | erik_d | OpenFOAM Bugs | 13 | September 13, 2008 22:45 |
