[OpenFOAM.org] decomposePar: no available formula for scotch |
September 6, 2015, 06:25 |
Rep Power: 12 |
Dear all,
I somehow screwed my OpenFOAM installation. After installing gnuplot via homebrew I am getting the following problems when mounting the OpenFOAM sparsebundle: Code:
Last login: Sun Sep 6 10:27:14 on ttys000 kates-mbp:~ kateeisenhower$ hdiutil attach -mountpoint $HOME/OpenFOAM OpenFOAM.sparsebundle /dev/disk2 GUID_partition_scheme /dev/disk2s1 EFI /dev/disk2s2 Apple_HFS /Users/kateeisenhower/OpenFOAM kates-mbp:~ kateeisenhower$ source $HOME/OpenFOAM/OpenFOAM-2.3.1/etc/bashrc -bash: openmpi_help: command not found Using paraview in directory /Applications/paraview.app -bash: boost_help: command not found Error: No available formula for scotch kates-mbp:~ kateeisenhower$ checkMesh -help Code:
decomposePar Code:
kates-mbp:100mmhkverfeinert_symm kateeisenhower$ decomposePar dyld: Library not loaded: /usr/local/lib/libscotch.dylib Referenced from: /Users/kateeisenhower/OpenFOAM/OpenFOAM-2.3.1/platforms/darwinIntel64ClangDPOpt/lib/libscotchDecomp.dylib Reason: image not found Trace/BPT trap: 5 kates-mbp:100mmhkverfeinert_symm kateeisenhower$ Best regards, Kate |
September 7, 2015, 03:19 |
#2 | |
1. Describe in more details "...installing gnuplot via homebrew...". 2. Post output of "brew doctor". 3. (optional) Describe the reason for gnuplot installation (plot residuals?), maybe there is a way to do it without gnuplot. |
October 21, 2015, 12:49 |
#3 | |
Rep Power: 12 |
Hi Alexey,
and sorry for the late answer. 1. I tried to install it quick and dirty, that's why I can't remember the detailed steps. 2. I'll do it when I have access to this computer again. 3. Yes I am plotting residuals with gunplot (script from this forum) and use it to plot aerodynamic coefficients (custom script). Best regards, Kate Quote:
October 21, 2015, 14:33 |
Though there could be another explanation. You have installed OpenFOAM when Scotch was in homebrew repository, now it is moved to homebrew/science repository. So before installing Scotch you have to do Code:
$ brew tap homebrew/science |
October 22, 2015, 03:16 |
Rep Power: 12 |
thanks, I will try this. No, previously I didn't get this kind of error. Kate |
November 1, 2015, 08:01 |
Rep Power: 12 |
Hi Alexey,
here´s the output of brew doctor (attached file). Please notice that I am going to sell this MacBook anyhow. So it doesn't matter anymore. Of course if you want me to test anything because you are interested in these kind of problems, I can do that. Best regards, Kate |
November 1, 2015, 08:16 |
Well, you have "mixed" Homebrew and Macports, this coctail can lead to all sorts of strange behaviour. Thank you for the brew doctor output and we can close this thread with conclusion "Do not install Macport and Homebrew (unless you know what you are doing) since they both install symlinks in /usr/local/{bin, include, lib, share} folders and this can lead to VERY strange results." |
Display Modes | |
decomposePar no field transfert | Jeanp | OpenFOAM Pre-Processing | 3 | June 18, 2022 13:01 |
decomposePar for custom solvers and boundary conditions | cfdopenfoam | OpenFOAM Programming & Development | 4 | October 31, 2015 10:05 |
decomposePar 4-core warning/error? | Boloar | OpenFOAM Bugs | 23 | April 8, 2014 09:57 |
decomposePar gives errors | of_user_ | OpenFOAM | 1 | July 4, 2011 06:27 |
Benetton Formula 1 | CD adapco Group Marketing | Siemens | 13 | February 7, 2002 10:33 |
