Trouble with installing OpenFOAM on Ubuntu
I'm a brand new user of Linux Ubuntu 8.10 (32-bit) and I'm experiencing some issues with the installation of OpenFOAM 1.5.
ParaView binaries will work only with the Qt version with which it was made, namely 4.3.x (for the 32-bit version). Now, there is a link on the official site for the repositories, but the only thing that happens when I put the URL into my Synaptic APT is "malformed line 85...", which in addition completely crashed my Synaptic. I solved that, but I still can't find a proper repository for Qt 4.3.x. Can anyone provide me with a full, appropriate APT address that has got Qt 4.3.x? Thanx a lot! |
Re: Trouble with installing OpenFOAM on any Distro
try this one http://www.linuxfromscratch.org/blfs...ble/x/qt4.html Do you know, where exactly this version of Qt should be installed so it does not interfere with the already installed distro Qt, I mean, should it be installed within the third party folder or the OpenFOAM folder? thanks and good luck
Search the OpenFOAM forum. You can find detailed steps and links on how to install OpenFOAM-1.5/paraview there (Ubuntu and OpenSUSE). phsieh2005 |
pei-ying hsieh wrote "Search the OpenFOAM forum", no comment on that, the openFoam forum has a lot of information and a new comer to OpenFOAM/Linux will definitely get confused. Have a positive reply, put a link(s) to what you consider the proper and easy procedure to solve this situation or write a few lines telling us how?
for instance, look that thread http://openfoam.cfd-online.com/cgi-b...2166#POST32166 How many have succeeded and how many have failed?
I run OpenFoam 1.5 on Ubuntu 8.10. There are two things that you need to look into.
1. Is your version of gcc higher/equal to the standard build used for openfoam 1.5 2. Check the compiler openfoam employs in the ../etc/bashrc file Qt is required for you to compile paraview and its a bit of effort to make it work. The paraview part is totally unrelated to the solvers. Also if paraview does not work you can always use foamToVTK utility and view the vtk files in paraview directly. Hope this helps. |
Thanks a lot to everyone! I'll look up all the options and let you know how I did.
Open Foam 1.5 comes with an old version of paraview that requires an old version of Qt. Here is How I solved the first part of the problem, i.e., installing qt4.3.5 within the OpenFOAM's ThirdParty folder.
1- In your home directory create a Tmp folder 2- Download into this folder the following file ftp://ftp.trolltech.com/qt/source/qt...c-4.3.5.tar.gz 3- Once the download is finished, change to that Tmp directory and issue the following two commands i- gunzip qt-x11-opensource-src-4.3.5.tar.gz ii- tar xvf qt-x11-opensource-src-4.3.5.tar now you have the folder qt-x11-opensource-src-4.3.5, so change to that folder and issue the following command ./configure -prefix /home/XXXXX/OpenFOAM/ThirdParty/QT-4.3.5 where XXXXX stands for your name, then accept the license by typing yes After few minutes you will get the following:- Qt is now configured for building. Just type "gmake" Once everything is built you must run "gmake install" Qt will be installed into /home/XXXXX/OpenFOAM/ThirdParty/Qt-4.3.5. at the end of this process (45 minutes or more) you will have qt-4.3.5 installed into the ThirdParty folder. Now the question is How to make OpenFOAM use this qt and not the already installed qt? If you have solved this question and willing to share your knowledge with us, Please write back and tell us what you did. If you plan to write "search for" or "google for", Please abstain from writing Thank you for your understanding Harish, thanks for the tip, I did not know that foamtoVTK can be used, thanks again |
The linker uses the following search paths to locate required shared libraries:
1. Any directories specified by -rpath-link options. 2. Any directories specified by -rpath options. The difference between -rpath and -rpath-link is that directories specified by -rpath options are included in the executable and used at runtime, whereas the -rpath-link option is only effective at link time. Searching -rpath in this way is only supported by native linkers and cross linkers which have been configured with the --with-sysroot option. 3. On an ELF system, for native linkers, if the -rpath and -rpath-link options were not used, search the contents of the environment variable "LD_RUN_PATH". 4. On SunOS, if the -rpath option was not used, search any directories speci- fied using -L options. 5. For a native linker, the search the contents of the environment variable "LD_LIBRARY_PATH". 6. For a native ELF linker, the directories in "DT_RUNPATH" or "DT_RPATH" of a shared library are searched for shared libraries needed by it. The "DT_RPATH" entries are ignored if "DT_RUNPATH" entries exist. 7. The default directories, normally /lib and /usr/lib. 8. For a native linker on an ELF system, if the file /etc/ld.so.conf exists, the list of directories found in that file. So, set LD_LIBRARY_PATH to the "subfolder to the OpenFOAM folder". |
Hi everyone!
I managed to do it relatively easy...it never actually crossed my mind that there could be a binary version of ParaView. Ok, so here what I did: 1. Downloaded OpenFOAM 1.5 and installed it on my Linux Ubuntu 8.10 in the manner described in detail on the official OpenFOAM website. 2. Everything's fine until the point where I needed to compile ParaView, so I DIDN'T! Here's the link to the binary version which will download ParaView 3.2.2 as a .deb file, so you just need to double-click it and it will install the ParaView 3.2.2 on your computer: http://yu.archive.ubuntu.com/ubuntu/...2.2-1_i386.deb Hope this helps! Cheers! |
more important than putting the link, is your willingness to share your experience with others Good Luck
I have ubuntu 9.04 and i did like Ahmed
1- In your home directory create a Tmp folder 2- Download into this folder the following file ftp://ftp.trolltech.com/qt/source/qt...c-4.3.5.tar.gz 3- Once the download is finished, change to that Tmp directory and issue the following two commands i- gunzip qt-x11-opensource-src-4.3.5.tar.gz ii- tar xvf qt-x11-opensource-src-4.3.5.tar now you have the folder qt-x11-opensource-src-4.3.5, so change to that folder and issue the following command ./configure -prefix /home/XXXXX/OpenFOAM/ThirdParty/QT-4.3.5 where XXXXX stands for your name, then accept the license by typing yes After few minutes you will get the following:- Qt is now configured for building. Just type "make" Once everything is built you must run "make install" Qt will be installed into /home/XXXXX/OpenFOAM/ThirdParty/Qt-4.3.5. Them i add the following lines to the ~/OpenFOAM/OpenFOAM-1.5/etc/bashrc at the very end # set QT related variables QT=~/OpenFOAM/ThirdParty/Qt-4.3.5 export PATH=$QT/bin:$PATH export LD_LIBRARY_PATH=$QT/lib:$LD_LIBRARY_PATH like in http://www.cfd-online.com/cgi-bin/Op...8466#POST28466 after that i just had to do all the compiling like in the README file of openFOAM (7.1 and 7.2) thanks for you help |
use synaptic to install g++
read the error mnessage g++ command not found |
Jandre I have ubuntu 9.04 but use OpenFOAM1.6. I want to know Is this instruction you said usefull for OpenFOAM1.6 as well as OpenFOAM1.5 and if yes after that paraview works properly?
Thanks. |
Thanks. |
| All times are GMT -4. The time now is 21:53. |
