[OpenFOAM.org] "Host key verification failed". upgrades to OpenMPI with OpenFoam 2.3.1 |
January 6, 2016, 06:54 |
Derek Mitchell
Rep Power: 13 |
IF you have a small cluster of more than 3 nodes using SSH and are upgrading from openfoam 2.3.1 or earlier to 2.4 and later you may run into this OpenMPI problem if you have upgraded OpenMPI to later than 1.6.5
with the upgrade to openmpi then you may find the following error occurring in a previously perfectly working cluster. "Host key verification failed." This stalled me for a couple of days trying to diagnose/ research/ fix it. After version 1.6.5 Openmpi has changed the way it launches. It now launches in a binary tree fashion, you will get the above error message if you use more than 3 nodes and only have passwordless ssh from the head node to the slaves. The error occurs when one of the slaves attempts to launch another slave.There are ways to solve this
A CHEERING BAND OF FRIENDLY ELVES CARRY THE CONQUERING ADVENTURER OFF INTO THE SUNSET |
Simple supported beam, incorrect solution | optymista93 | Structural Mechanics | 0 | November 15, 2017 10:36 |
OpenFOAM 4.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 2 | October 6, 2017 05:40 |
Problem to run simpleFoam using qsub? | be_inspired | OpenFOAM | 1 | December 22, 2015 12:53 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 09:04 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
