[foam-extend.org] Problem encountered in installing foam-extend-3.2 to Debian Jessie
Like Tree1Likes
  • 1 Post By hjasak
Old   January 21, 2016, 10:43
Default Problem encountered in installing foam-extend-3.2 to Debian Jessie
Karnataka
sathya123 is on a distinguished road
I am new to using foam-extend, and encountered errors during the installation of foam-extend-3.2 with the ./Allwmake utility.
db/IOstreams/Pstreams/IPread.C:29:17: fatal error: mpi.h: No such file or directory
I do not know what to make of this error, as I have mpi.h in the folder /usr/include/openmpi.I have enclosed a snippet with this thread. I would appreciate any inputs or suggestions on this matter.
Thanks!
make: Nothing to be done for 'all'.
+ wmakePrintBuild -check
same version as previous build
+ wmakeLnInclude foam
+ wmakeLnInclude meshTools
+ wmakeLnInclude OSspecific/POSIX
+ wmake libo OSspecific/POSIX
'/lscratch/satcha/foam/foam-extend-3.2/lib/linux64GccDPOpt/libOSspecific.o' is up to date.
+ set +x
Note: ignore spurious warnings about missing mpicxx.h headers
+ wmake libso foam
SOURCE=global/global.Cver ; sed -e 's/VERSION_STRING/3.2/' -e 's/BUILD_STRING/3.2-b4e1b80409dd/' $SOURCE > Make/linux64GccDPOpt/global.C; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -DOMPI_SKIP_MPICXX -I/include -I/lscratch/satcha/foam/foam-extend-3.2/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/lscratch/satcha/foam/foam-extend-3.2/src/foam/lnInclude -I/lscratch/satcha/foam/foam-extend-3.2/src/OSspecific/POSIX/lnInclude -fPIC -c Make/linux64GccDPOpt/global.C -o Make/linux64GccDPOpt/global.o
SOURCE=db/IOstreams/Pstreams/Pstream.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -DOMPI_SKIP_MPICXX -I/include -I/lscratch/satcha/foam/foam-extend-3.2/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/lscratch/satcha/foam/foam-extend-3.2/src/foam/lnInclude -I/lscratch/satcha/foam/foam-extend-3.2/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/Pstream.o
SOURCE=db/IOstreams/Pstreams/PstreamGlobals.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -DOMPI_SKIP_MPICXX -I/include -I/lscratch/satcha/foam/foam-extend-3.2/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/lscratch/satcha/foam/foam-extend-3.2/src/foam/lnInclude -I/lscratch/satcha/foam/foam-extend-3.2/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/PstreamGlobals.o
SOURCE=db/IOstreams/Pstreams/IPread.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -DOMPI_SKIP_MPICXX -I/include -I/lscratch/satcha/foam/foam-extend-3.2/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/lscratch/satcha/foam/foam-extend-3.2/src/foam/lnInclude -I/lscratch/satcha/foam/foam-extend-3.2/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/IPread.o
SOURCE=db/IOstreams/Pstreams/OPwrite.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -DOMPI_SKIP_MPICXX -I/include -I/lscratch/satcha/foam/foam-extend-3.2/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/lscratch/satcha/foam/foam-extend-3.2/src/foam/lnInclude -I/lscratch/satcha/foam/foam-extend-3.2/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/OPwrite.o
SOURCE=db/Time/findTimes.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -DOMPI_SKIP_MPICXX -I/include -I/lscratch/satcha/foam/foam-extend-3.2/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/lscratch/satcha/foam/foam-extend-3.2/src/foam/lnInclude -I/lscratch/satcha/foam/foam-extend-3.2/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/findTimes.o
SOURCE=db/Time/subCycleTime.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -DOMPI_SKIP_MPICXX -I/include -I/lscratch/satcha/foam/foam-extend-3.2/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/lscratch/satcha/foam/foam-extend-3.2/src/foam/lnInclude -I/lscratch/satcha/foam/foam-extend-3.2/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/subCycleTime.o
SOURCE=db/Time/findInstance.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -DOMPI_SKIP_MPICXX -I/include -I/lscratch/satcha/foam/foam-extend-3.2/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/lscratch/satcha/foam/foam-extend-3.2/src/foam/lnInclude -I/lscratch/satcha/foam/foam-extend-3.2/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/findInstance.o
In file included from db/IOstreams/Pstreams/PstreamGlobals.C:26:0:
db/IOstreams/Pstreams/PstreamGlobals.H:39:17: fatal error: mpi.h: No such file or directory
#include "mpi.h"
compilation terminated.
#include "mpi.h"
db/IOstreams/Pstreams/OPwrite.C:29:17: fatal error: mpi.h: No such file or directory
#include "mpi.h"
db/IOstreams/Pstreams/PstreamGlobals.H:39:17: fatal error: mpi.h: No such file or directory.
sathya123 is offline   Reply With Quote
Old   January 22, 2016, 03:24
Hrvoje Jasak
Did the ThirdParty build correctly? Try
which mpirun
or rebuild third party by hand
sathya123 likes this.
Hrvoje Jasak
Old   January 23, 2016, 06:00
Karnataka
Yes I see now, it was a problem with the third party build. The issue is I could not install rpm, as I lack administrative privileges. Is there a way around this?
Old   January 23, 2016, 06:01
Karnataka
Thank you so much for the input!
[foam-extend.org] Foam Extend 3.2 in ubuntu 16.04 LTS JMosiezny OpenFOAM Installation 15 December 9, 2017 08:20
error with reactingFoam BakedAlmonds OpenFOAM Running, Solving & CFD 4 June 22, 2016 02:21
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
problem about installing FOAM linux freshman Main CFD Forum 6 November 4, 2004 10:59
