[OpenFOAM.com] [Windows] Error about: of_create_container.exe does not work. |
March 15, 2016, 04:11 |
Zacarias Carral
Rep Power: 13 |
I have installed the OpenFOAM for Windows offered by OpenCFD:
http://www.openfoam.com/download/install-windows.php When I try to open OpenFOAM I receive an error about of_create_container.exe does not work. Has anybody installed this OpenFOAM version? |
March 21, 2016, 03:10 |
matej forman
Rep Power: 17 |
can you printscreen the error message so it is clearer what is going on? What version of Windows you have? Do you have any previous installation of Virtualbox? thanks Matej |
March 22, 2016, 03:09 |
Zacarias Carral
Rep Power: 13 |
The error says:
"of_create_container.exe does not work" I have windows 7 32 bits I do not have any previous VirtualBox installation |
August 2, 2017, 05:06 |
#4 | |
Rep Power: 8 |
Was this issue ever resolved? I am running into the same problem trying to install OpenFOAM 1612+ on a computer running 64-bit Windows 7. https://www.cfd-online.com/Forums/op...d-working.html |
August 8, 2017, 10:43 |
Pawan Ghildiyal
Rep Power: 10 |
Windows 7 32 bit is not supported with docker based OpenFOAM-v1612+
RP_Set_Integer does not work in parallel | 86lolo | Fluent UDF and Scheme Programming | 2 | July 3, 2014 11:37 |
Does CX_Interpret_String work in parallel? | 86lolo | Fluent UDF and Scheme Programming | 2 | June 30, 2014 04:36 |
Companies that lease software & hardware for cloud-based work? | Catthan | ANSYS | 0 | June 18, 2014 10:53 |
Why do the Plant library cases don't work? | Alumna | Phoenics | 6 | June 22, 2004 12:08 |
why my In-Form doesn't work? | green | Phoenics | 2 | May 27, 2004 21:03 |
