March 23, 2016, 04:44 |
OpenFoam run command
Rep Power: 10 |
I have installed OpenFoam-2.3.0 on Centos-6.5 according to the official guide. It is stated that the final command to run is of230, however, that command has no output.
It seems that the command should be icoFoam (and that is partially stated in the guide). Code:
mahmood@cluster:~$ cat .bashrc alias of230='module load openmpi-x86_64; source /export/apps/mechanics/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc WM_NCOMPPROCS=4 foamCompiler=ThirdParty WM_COMPILER=Gcc48 WM_MPLIB=SYSTEMOPENMPI' mahmood@cluster:~$ source .bashrc mahmood@cluster:~$ of230 mahmood@cluster:~$ icoFoam --help Usage: icoFoam [OPTIONS] options: -case <dir> specify alternate case directory, default is the cwd -noFunctionObjects do not execute functionObjects -parallel run in parallel -roots <(dir1 .. dirN)> slave root directories for distributed running -srcDoc display source code in browser -doc display application documentation in browser -help print the usage Using: OpenFOAM-2.3.0 (see www.OpenFOAM.org) Build: 2.3.0-f5222ca19ce6 --> FOAM FATAL ERROR: Invalid option: --help FOAM exiting mahmood@cluster:~$ |
March 23, 2016, 07:56 |
#2 | |||
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answers:
icoFoam --help It seems that OpenFOAM 2.3.0 is now installed without any problems. Please start reading the OpenFOAM User Guide, as stated at the end of the instructions: Quote:
March 23, 2016, 14:30 |
Rep Power: 10 |
Thank you very much. Indeed, I am not an expert in OpenFoam. Instead, as the administrator of the cluster, I installed it for the users.
One more question: Is there a big difference between 2.2 and 2.3? Are the scripts and commands compatible? I mean from 2.2 to 2.3. I will ask my next question in a new topic |
March 26, 2016, 05:47 |
#4 | |
Bruno Santos
Rep Power: 128 |
Quick answer:
What I mean is that there are some considerable changes all the way from 2.2.0 to 2.3.0, although most only affect how the simulation cases are prepared for running. You can ask your users to go through the Release Notes for each version so that they can tell you what they need. You can find a complete list of links to the release notes at the top right corner on this page: http://openfoamwiki.net/index.php/Main_Page You might want to provide OpenFOAM 3.0.1 as well to your users, given that this is the most recent version. Instructions are provided here: https://openfoamwiki.net/index.php/I...HEL#CentOS_6.7 |
March 26, 2016, 11:56 |
Rep Power: 10 |
OK thank you very much for the helps.
[OpenFOAM.org] Problems to run OpenFOAM 3.0.1 on Mac OS 10.11.4 | remidemol | OpenFOAM Installation | 2 | March 25, 2016 11:29 |
Unable to run a case with OpenFOAM 1.6-ext that works with OpenFOAM 2.3.0 | Jiricbeng | OpenFOAM Running, Solving & CFD | 15 | May 21, 2014 03:52 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
OpenFOAM15 installables are incomplete problem with paraFoam | tryingof | OpenFOAM Bugs | 17 | December 7, 2008 04:41 |
