[OpenFOAM.org] Error in compiling in debug mode
Old   April 19, 2016, 17:34
Default Error in compiling in debug mode
Mehdi
paradox is on a distinguished road
Dear foamers
I am trying to compile in debug mode but there is some error while compiling.
some of strange output lines are :
Note: ignore spurious warnings about missing mpicxx.h headers
+ wmake libso finiteVolume
make: *** No rule to make target `fields/fvsPatchFields/basic/coupled/coupledFvsPatchFields.dep', needed by `Make/linux64GccDPDebug/dependencies'. Stop.
+ wmake libso genericPatchFields
/usr/bin/ld: cannot find -lfiniteVolume
collect2: error: ld returned 1 exit status
make: *** [/home/paradox/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPDebug/lib/libgenericPatchFields.so] Error 1
can anybody help me?
paradox is offline   Reply With Quote
Old   April 19, 2016, 18:34
Retired Super Moderator
Bruno Santos
Quick note: Looks like you omitted vital information.
The error message is pointing out that there is an entry in "src/finiteVolume/Make/files" that doesn't exists, namely:
src/finiteVolume/fields/fvsPatchFields/basic/coupled/coupledFvsPatchFields.C
Old   April 19, 2016, 19:19
Mehdi
Drear bruno,
Thanks for your quick reply.
This file already exist. but I remember one days I was reading and working on these BC files, before.
can I replace this directory "fields" by original and compile it again and get fix?
Old   April 20, 2016, 17:29
Bruno Santos
Quick answer:
Yes, it should solve at least part of the problem.
You should also run the following command before you run Allwmake:
wclean libso src/finiteVolume
so that this will make this library "finiteVolume" rebuild properly.
Old   April 21, 2016, 08:34
Mehdi
That's right.
By replacing original files and rebuilding "fininteVolume" just solve one part of problems.
Another problem is occurred.
/home/paradox/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPDebug/lib/libfiniteVolume.so: file not recognized: File truncated
I cleaned up the build of the libOpenFOAM library but this problem did not resolved.
regards.
mehdi
Old   April 21, 2016, 17:39
Bruno Santos
Quick answer: Simply run:
rm $FOAM_LIBBIN/libfiniteVolume.so
Old   April 22, 2016, 07:39
Thumbs up
Mehdi
Thanks a lot.
By removing libfiniteVolume.so, another parts of the problems go away.
I had to run the following commands to wclean applications too:
wclean all $FOAM_APP/utilities *
wclean all $FOAM_APP/solvers *
Now compiling debug mode is done, although some errors that are not important to me are occurred,
but I am able to compile and debug solvers by eclipse IDE.
Regards,
mehdi.
openfoam compile debug
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 21:00
[foam-extend.org] compiling foam-extend-4.0 after switching to debug mode failed Pfiffikus OpenFOAM Installation 2 February 9, 2018 09:00
Recursive output of Foam::word in gdb print command chengdi OpenFOAM Programming & Development 1 July 19, 2017 20:19
[PyFoam] Problems with the new PyFoam release zfaraday OpenFOAM Community Contributions 13 December 9, 2014 18:58
[PyFoam] having problems with pyfoam Installation vitorspadetoventurin OpenFOAM Community Contributions 3 December 2, 2014 07:18
