[OpenFOAM.org] Regarding Installation Errors of OpenFOAM-2.4.x on CentOS 6.7
Old   April 19, 2016, 01:31
Default Regarding Installation Errors of OpenFOAM-2.4.x on CentOS 6.7
Atul Kumar
Location: National Centre for Combustion Research and Development
atulkjoy is on a distinguished road
Hi friends,
When Ever I try to install any new version of open Foam I am getting simmiler errors in libraries. can any one help me to fix this problem.
/home/atulkjoy/OpenFOAM/ThirdParty-2.4.x/platforms/linux64/gcc-4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/../../../../x86_64-unknown-linux-gnu/bin/ld: cannot find -lfluidThermophysicalModels
/home/atulkjoy/OpenFOAM/ThirdParty-2.4.x/platforms/linux64/gcc-4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/../../../../x86_64-unknown-linux-gnu/bin/ld: cannot find -lturbulenceModels
/home/atulkjoy/OpenFOAM/ThirdParty-2.4.x/platforms/linux64/gcc-4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/../../../../x86_64-unknown-linux-gnu/bin/ld: cannot find -lcompressibleTurbulenceModels
/home/atulkjoy/OpenFOAM/ThirdParty-2.4.x/platforms/linux64/gcc-4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/../../../../x86_64-unknown-linux-gnu/bin/ld: cannot find -lincompressibleTransportModels
/home/atulkjoy/OpenFOAM/ThirdParty-2.4.x/platforms/linux64/gcc-4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/../../../../x86_64-unknown-linux-gnu/bin/ld: cannot find -lcompressibleTwoPhaseSystem
/home/atulkjoy/OpenFOAM/ThirdParty-2.4.x/platforms/linux64/gcc-4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/../../../../x86_64-unknown-linux-gnu/bin/ld: cannot find -lcompressibleEulerianInterfacialModels
/home/atulkjoy/OpenFOAM/ThirdParty-2.4.x/platforms/linux64/gcc-4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/../../../../x86_64-unknown-linux-gnu/bin/ld: cannot find -lfiniteVolume
/home/atulkjoy/OpenFOAM/ThirdParty-2.4.x/platforms/linux64/gcc-4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/../../../../x86_64-unknown-linux-gnu/bin/ld: cannot find -lfvOptions
/home/atulkjoy/OpenFOAM/ThirdParty-2.4.x/platforms/linux64/gcc-4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/../../../../x86_64-unknown-linux-gnu/bin/ld: cannot find -lmeshTools
/home/atulkjoy/OpenFOAM/ThirdParty-2.4.x/platforms/linux64/gcc-4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/../../../../x86_64-unknown-linux-gnu/bin/ld: cannot find -lsampling
collect2: error: ld returned 1 exit status
make[1]: *** [interFoam] Error 2
make[2]: *** [/home/atulkjoy/OpenFOAM/OpenFOAM-2.4.x/platforms/linux64Gcc48DPOpt/lib/libcompressibleTwoPhaseSystem.so] Error 1
make[2]: Target `libso' not remade because of errors.
+ wmake libso interfacialModels
make[2]: *** [/home/atulkjoy/OpenFOAM/OpenFOAM-2.4.x/platforms/linux64Gcc48DPOpt/lib/libcompressibleEulerianInterfacialModels.so] Error 1
+ wmake libso phaseCompressibleTurbulenceModels
Last edited by wyldckat; May 1, 2016 at 18:15. Reason: Added [CODE][/CODE] markers
atulkjoy is offline   Reply With Quote
Old   April 19, 2016, 18:36
Retired Super Moderator
Bruno Santos
Quick answer: Run:
./Allwmake > make.log 2>&1
gzip < make.log > make.log.gz
Then attach the file "make.log.gz" to your next post. Because the error messages that you provided do not describe the actual origin of the problem.
Old   April 20, 2016, 02:26
Default Regarding error message
Atul Kumar
Thanks for the reply I am attaching my make file with the message.
Regards
Old   April 20, 2016, 07:38
Atul Kumar
Hi Dear FOMERS,
In OpenFOAM-2.4.x during installation I am getting Following Errors.
In member function ‘int STLASCIILexer::lex()’:
Make/linux64Gcc48DPOpt/STLsurfaceFormatASCII.C:5521:9: error: no match for ‘operator=’ (operand types are ‘std::istream {aka std::basic_istream<char>}’ and ‘std::istream* {aka std::basic_istream<char>*}’)
Make/linux64Gcc48DPOpt/STLsurfaceFormatASCII.C:5521:9: note: candidate is:
In file included from /home/atulkjoy/OpenFOAM/ThirdParty-2.4.0/platforms/linux64/gcc-4.8.4/include/c++/4.8.4/iostream:40:0,
                 from Make/linux64Gcc48DPOpt/STLsurfaceFormatASCII.C:95:
/home/atulkjoy/OpenFOAM/ThirdParty-2.4.0/platforms/linux64/gcc-4.8.4/include/c++/4.8.4/istream:58:11: note: std::basic_istream<char>& std::basic_istream<char>::operator=(const std::basic_istream<char>&)
     class basic_istream : virtual public basic_ios<_CharT, _Traits>
I have tried by all possible ways I know. Please send your suggetions if/any.
Regards.
Last edited by wyldckat; May 1, 2016 at 18:34. Reason: Added [CODE][/CODE] markers
Old   April 20, 2016, 17:27
Bruno Santos
Quick answer: The first error message is this one:
Make/linux64Gcc48DPOpt/STLsurfaceFormatASCII.C: In member function ‘int STLASCIILexer::lex()’:
    yyin = & std::cin;
This is a rather strange error message, that I can't remember seeing before.
I need to know two details:
  1. What does the following command give you?
    flex --version
  2. Which Linux Distribution and version are you using?
Old   April 21, 2016, 00:55
Atul Kumar
    yyin = & std::cin;
    flex --version
cat /etc/centos-release
CentOS release 6.7 (Final)
flex --version
flex 2.5.35
Old   April 21, 2016, 06:02
Atul Kumar
Dear Bruno.
Thanks for all support
I am having multiple FOAM versions but I have sepreated them in bashrc files as per your blogs. I guess it is flex erro, usually when I try to recomplie any version I get errro of libfl.so.2 and libfl.so not found. How can I fix this ?? I have used LD_LIBRARY_PATH=/usr/local/lib: already.
Old   April 21, 2016, 17:56
Bruno Santos
Hi Atul,
I suggest that you do not do that manually. That might be the reason why you're not able to build OpenFOAM properly.
Did you install flex manually (from source code) or did you install it using yum?
What do you get when you run the following command?
locate libfl.so
Best regards,
Bruno
Old   April 22, 2016, 02:43
Atul Kumar
$locate libfl.so
/home/atulkjoy/FDS/FDS6/bin/LIB64/libfl.so.2
/usr/local/lib/libfl.so
/usr/local/lib/libfl.so.2
/usr/local/lib/libfl.so.2.0.0
Yes I have tried Flex 2.6.0 by source Code for FDS but flex --version returns the same line still
$flex --version
2.5.35
I have used YUM for upgrading flex
Old   May 1, 2016, 18:36
Bruno Santos
Quick answer: Sorry for the late reply, but I only managed to take a look into this now.
The "libfl.so" is not needed for OpenFOAM. The problem you're having with Flex is really strange, but perhaps the following will solve the problem. Please run the following commands:
#Go into OpenFOAM's main source folder
cd $WM_PROJECT_DIR
#Change how the flex version is checked
find src applications -name "*.L" -type f | xargs sed -i -e 's=\(YY\_FLEX\_SUBMINOR\_VERSION\)=YY_FLEX_MINOR_VERSION < 6 \&\& \1='
Then try building OpenFOAM again, by running:
./Allwmake > log.make 2>&1
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 14:24
[OpenFOAM.org] OpenFOAM 2.3.1 installation error on CentOS 6.6 Naresh yathuru OpenFOAM Installation 2 February 16, 2015 13:14
[OpenFOAM.org] OpenFOAM Installation on Centos 6.4 unobtruse OpenFOAM Installation 3 December 14, 2014 08:44
Critical errors gcc and icoFoam during installation of 15 quartzian OpenFOAM Installation 3 December 12, 2008 12:42
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
