[foam-extend.org] foam-extend 3.2 not building on Gentoo
Like Tree1Likes
  • 1 Post By wyldckat
Old   April 28, 2016, 15:00
Default foam-extend 3.2 not building on Gentoo
BastiL
bastil is on a distinguished road
Hello all,
I have issues building foam-extend 3.2 on my Gentoo-box. I have installed several OF-versions on it without any problems.
The error occurs when buidling metis. The problem is that decompositionMethod.H is not found even though the file is present.
Thanks.
bastil is offline   Reply With Quote
Old   May 1, 2016, 17:38
Retired Super Moderator
Bruno Santos
Quick answer: Without a complete output log with error listing, I'm unable to diagnose what might be the problem.
Append the following to the command you used:
> log.make 2>&1
For example:
./Allwmake > log.make 2>&1
Then please attach the compressed file, e.g. "log.make.gz":
gzip < log.make > log.make.gz
lxwd likes this.
Old   May 6, 2016, 04:30
BastiL
See attachment.
Old   May 8, 2016, 14:28
Bruno Santos
Quick answer: OK, there are few errors and hopefully the solutions are simple enough:
  1. The rpm and rpmBuild applications are not installed in your system. I don't know if Gentoo provides it.
  2. There are a few problems with the Flex version. The following commands should solve the problem:
    cd $WM_PROJECT_DIR
    find src applications -name "*.L" -type f | xargs sed -i -e 's=\(YY\_FLEX\_SUBMINOR\_VERSION\)=YY_FLEX_MINOR_VERSION < 6 \&\& \1='
Old   May 8, 2016, 14:47
BastiL
Ok, I don't think I need rpm and rpmBuild. I have all required dependencies on my System and OpenFOAM3 is able to use them without any problems. The same is true for the installed flex.
I will try to fix the flex problems as described. What is the correct way to tell foam-extend to use the system packages? Thanks.
Regards BastiL
Old   May 8, 2016, 14:59
Bruno Santos
Quick answer: Run:
foam
cp etc/prefs.sh-EXAMPLE etc/prefs.sh
Then:
  1. Manually edit the file "etc/prefs.sh";
  2. uncomment the lines respective to the packages you have in your system and don't forget to update the paths to said packages/libraries.
error with reactingFoam BakedAlmonds OpenFOAM Running, Solving & CFD 4 June 22, 2016 02:21
[foam-extend.org] Error compiling OpenFOAM-1.6-ext Canesin OpenFOAM Installation 137 January 20, 2016 14:56
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 04:55
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
