[Other] [CFDSupport software bundles] OpenFOAM bashrc source problem
Like Tree1Likes
  • 1 Post By MagusMD
Old   October 6, 2016, 08:49
Default [CFDSupport software bundles] OpenFOAM bashrc source problem
Alper
MagusMD is on a distinguished road
I am using Ubuntu 16.04 and recently installed OpenFOAM-in-BOX-16.06 (which is OpenFOAM 3.0.x) and created an alias in the bashrc file. Everything was working perfectly until I install gconf and dconf editors.
Then the problems begins. This is the line I added to .bashrc file:
alias of='source /home/eclipse/OpenFOAM-in-Box-16.06/OpenFOAM-3.0.x/etc/bashrc'
If I active this alias in terminal and try to use gedit I get this error:
eclipse@eclipse-ubuntu:~/Desktop$ of
eclipse@eclipse-ubuntu:~/Desktop$ gedit filename
gedit: /home/eclipse/OpenFOAM-in-Box-16.06/ThirdParty-3.0.x/platforms/linux64/gcc-4.9.3/lib64/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/lib/x86_64-linux-gnu/libmirclient.so.9)
gedit: /home/eclipse/OpenFOAM-in-Box-16.06/ThirdParty-3.0.x/platforms/linux64/gcc-4.9.3/lib64/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /usr/lib/x86_64-linux-gnu/libmirclient.so.9)
gedit: /home/eclipse/OpenFOAM-in-Box-16.06/ThirdParty-3.0.x/platforms/linux64/gcc-4.9.3/lib64/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/lib/x86_64-linux-gnu/libmircommon.so.5)
gedit: /home/eclipse/OpenFOAM-in-Box-16.06/ThirdParty-3.0.x/platforms/linux64/gcc-4.9.3/lib64/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /usr/lib/x86_64-linux-gnu/libmircommon.so.5)
gedit: /home/eclipse/OpenFOAM-in-Box-16.06/ThirdParty-3.0.x/platforms/linux64/gcc-4.9.3/lib64/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/lib/x86_64-linux-gnu/libmirprotobuf.so.3)
gedit: /home/eclipse/OpenFOAM-in-Box-16.06/ThirdParty-3.0.x/platforms/linux64/gcc-4.9.3/lib64/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /usr/lib/x86_64-linux-gnu/libmirprotobuf.so.3)
gedit: /home/eclipse/OpenFOAM-in-Box-16.06/ThirdParty-3.0.x/platforms/linux64/gcc-4.9.3/lib64/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /usr/lib/x86_64-linux-gnu/libboost_system.so.1.58.0)
gedit: /home/eclipse/OpenFOAM-in-Box-16.06/ThirdParty-3.0.x/platforms/linux64/gcc-4.9.3/lib64/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /usr/lib/x86_64-linux-gnu/libprotobuf-lite.so.9)
gedit: /home/eclipse/OpenFOAM-in-Box-16.06/ThirdParty-3.0.x/platforms/linux64/gcc-4.9.3/lib64/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /usr/lib/x86_64-linux-gnu/libboost_filesystem.so.1.58.0)
What do you think the problem is?
MagusMD is offline   Reply With Quote
Old   October 6, 2016, 10:21
Default Solved it
Alper
Okay, I solved it. Here is the solution if you are interested:
I found the missing lib file here:
/usr/lib/x86_64-linux-gnu/libstdc++.so.6
and copied here:
/home/eclipse/Desktop/OpenFOAM/ThirdParty-3.0.x/platforms/linux64/gcc-4.9.3/lib64
It seems I can now use OpenFOAM command and gedit command at the same terminal.
wyldckat likes this.
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
