[OpenFOAM.org] 4.1: Bashrc file problem
Like Tree2Likes
  • 1 Post By FlyBob91
  • 1 Post By wyldckat
Old   October 14, 2016, 14:39
Talking 4.1: Bashrc file problem
FlyBob91's Avatar
FlyBob91 is on a distinguished road
Hello to everyone,
i'm trying to install the new OpenFOAM version 4.1 on Ubuntu 16.04 LTS by following the guide but i think there is a passage not explained.
I'm not installing it in /opt/ but in $home/my_name/OpenFOAM/
In the folrder OpenFOAM there are OpenFOAM-4.1 and ThirdParty-4.1
Now i'm at the point i have to add the line to the home bashrc file and i added this line always following the guide
HTML Code:
source $HOME/OpenFOAM/OpenFOAM-4.1/etc/bashrc
and this is the result on terminal
bash: /home/roby/OpenFOAM/OpenFOAM-4.x/etc/config.sh/functions: File o directory non esistente
bash: /home/roby/OpenFOAM/OpenFOAM-4.x/bin/foamEtcFile: File o directory non esistente
_foamSource: comando non trovato
_foamEval: comando non trovato
bash: /home/roby/OpenFOAM/OpenFOAM-4.x/bin/foamCleanPath: File o directory non esistente
i think i should change something in the bashrc file in the $HOME/OpenFOAM/OpenFOAM-4.1/etc/ because maybe is set up for the /opt/ installation.
Could someone explain me what to change?
Thanks a lot
FlyBob91 is offline   Reply With Quote
Old   October 14, 2016, 20:07
FlyBob91's Avatar
OK i solved the problem
As i mentioned the error was in
HTML Code:
Opened the bashrc file it's simply necessary to change
HTML Code:
export WM_PROJECT_VERSION=4.x
in
HTML Code:
export WM_PROJECT_VERSION=4.1
for the 4.1 OpenFOAM version.
i hope this could help someone
wyldckat likes this.
Old   October 16, 2016, 09:44
Retired Super Moderator
Bruno Santos
Greetings Roberto,
Many thanks for spotting this! I've reported it here: http://bugs.openfoam.org/view.php?id=2293
It should be fixed as soon as possible.
For others with the same problem, if you want to use a single command that does this fix, run the following from within the folder "OpenFOAM-4.1":
sed -i -e 's=4\.x=4.1=' etc/bashrc etc/cshrc
Best regards,
Bruno
FlyBob91 likes this.
Old   October 17, 2016, 07:32
FlyBob91's Avatar
Thanks to you and your work Bruno.
Best regards,
Roberto
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 08:06
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 21:03
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 11:32
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
