[OpenFOAM.com] v1606+ Problems of installation on iMac |
October 21, 2016, 17:54 |
Rep Power: 9 |
Hi all,
I tried to install the new openFoam v1606 on my iMac. The instruction appear so simple that I really don't think so many problems I met. First I installed Docker and Docker toolbox, without particular problem. After that I launched installMacOpenFOAM+, but I found problem of time out of connection.... I start to search documentation about this error, and the useful suggestion is add to the DNS system the address 8.8.8.8, which solved the problem. Now the image are now installed, happy to this I have continue following the instruction "chmod +x startMacOpenFOAM+", ok and finally "./startMacOpenFOAM+ " and now other error: "Error response from daemon: Mounts denied: The path /etc/sudoers.d is not shared from OS X and is not known to Docker. You can configure shared paths from Docker -> Preferences... -> File Sharing. See https://docs.docker.com/docker-for-m...fs/#namespaces for more info. . Error: failed to start containers: of_v1606_plus You cannot attach to a stopped container, start it first" I have tried to solve this error but till now I have not found any solution. Do anyone have same problem? Any help is very appreciate. |
October 25, 2016, 10:33 |
Pawan Ghildiyal
Rep Power: 10 |
Hi
i) Make sure you have installed docker toolbox only .(Note the other docker run natively on machine but is in beta phase and script does not support it ) ii) if you have installed docker tool box , click on docker terminal toolbox and type command "docker images " and "docker ps -a" . Let me know what 's the output Also i assume , you have run following command for installation docker-machine ssh default $HOME/installMacOpenFOAM+ $HOME |
October 27, 2016, 12:56 |
Error with Docker
Rep Power: 9 |
Hi Pawan,
I have installed also Docker due to an error. Anyway I remove Docker, re-install the Docker Toolbox only, an the error that appear into the Docker Quickstart Terminal is: Cannot connect to the Docker daemon. Is the docker daemon running on this host? Any command I try to insert generate these message error. Do you have some other suggestion about? Thanks |
October 28, 2016, 06:10 |
Solved
Rep Power: 9 |
Hi all,
I have solved the problem caused by the firewall which blocks some connections. Thanks for help |
November 15, 2016, 20:22 |
[Other] Installation problems with OpenFOAM 2.3.x for Windows from cfdsupport.com | Nkl | OpenFOAM Installation | 7 | March 31, 2015 10:59 |
[PyFoam] having problems with pyfoam Installation | vitorspadetoventurin | OpenFOAM Community Contributions | 3 | December 2, 2014 07:18 |
Problems with installation | batta31 | OpenFOAM Installation | 2 | September 4, 2012 07:01 |
Installation Problems | honcho | OpenFOAM Installation | 0 | January 14, 2008 10:48 |
installation problems on upgrade from win 3.26 to | mic | Siemens | 5 | June 20, 2007 09:40 |
