-   OpenFOAM Installation (http://www.cfd-online.com/Forums/openfoam-installation/)
-   -   Qt431 Download (http://www.cfd-online.com/Forums/openfoam-installation/57212-qt431-download.html)
jaudi November 3, 2008 15:09
Where can i get QT-4.3.1? i wa
Where can i get QT-4.3.1? i was looking in trolltech webpage but i did not find it. Can someone help me please?, i need these release in order to finish my installation and start with OpenFOAM.
Thanks in advanced
ep4 November 4, 2008 02:15
I think you can find what you
I think you can find what you want here: ftp://ftp.trolltech.com/qt/source
jaudi November 4, 2008 12:46
ok I got QT -4.3.1, the fact i
ok I got QT -4.3.1, the fact is i don't know nothing about Linus, Can you please help me to install QT in my system?
i have linux version 10 and i have OpenFOAM installed as the guide indicates.
I mind steeps are missing to work with OpenFOAM is install QT and compile QT and paraview.
jason November 4, 2008 13:21
Hi, Have a look at the mess
Have a look at the message I posted here.
http://www.cfd-online.com/cgi-bin/Op...how.cgi?1/9810
Just follow the instructions in the INSTALL file, it worked fine for me.
ftp://ftp.trolltech.com/qt/source/INSTALL
Just be careful to set the PATH version number correctly.
Jason
jaudi November 13, 2008 11:00
i am having an error when tryi
i am having an error when trying install Qt:
QMAKESPEC has not been seet, so configuration cannot be deduced.
Error processing project file: /tmp/qt-all-opensource-src-4.3.1/projects.pro
Can please help me to fix this issue, I wanna use OpenFoam
jaudi November 13, 2008 13:37
Sorry i forgot to mention my s
Sorry i forgot to mention my system is SUSE LINUX 10.1 (x86-64) - KERNEL \R (\L)
madad2005 November 13, 2008 13:42
jaudiel, does Suse not have a
jaudiel, does Suse not have a package manager? You should be able to search for QT v4 through that and it will automatically install it for you.
jaudi November 13, 2008 14:06
do you mean Yast ? how can ins
do you mean Yast ? how can install it ? i downloaded 4.3.1 from trolltech web?
my linux machine does not have internet connection
madad2005 November 14, 2008 07:26
Ah, if you don't have an inter
Ah, if you don't have an internet connection then you will have to install it manually, unfortunately. I may be wrong though.
gwierink November 14, 2008 08:27
Hi Jaudiel, Did you downloa
Hi Jaudiel,
Did you download the package qt-x11-opensource-src-4.3.x.tar.gz from http://trolltech.com/downloads/opens.../linux-x11-cpp ?
If you want to install that package you need to unpack it first using "tar xzf <package_name>.tar.gz" (where "<package_name>" is of course the name of the package)
Then, go in to the directory of the unpacked package and configure it by typing "./configure". After that has been done, type "gmake" and let it make the package. Then, finally type "gmake install". Then, the package should be installed.
Although I'm not sure whether you may have to use make instead of gmake on your system. Also, be sure that you have a c++ compiler installed, like gcc-c++.
Rgds, Gijsbert
jaudi November 14, 2008 13:13
i have gcc 4.3.1 version insta
i have gcc 4.3.1 version installed in my systemn
i did the installation as you indicates, however i am getting the same error: when i ran qmake i got next message:
When i ran make or gmake i get:
not target specified.
how can fix this trouble.
gwierink November 15, 2008 09:37
Does ./configure work for Qt,
Does ./configure work for Qt, or are you already stuck there? If so, do you type these commands in the right directory? After unpacking you find a directory qt-x11-opensource-src-4.3.x (or whatever your version is) in the place you unpacked it, so the you need to do "cd qt-x11-opensource-src-4.3.x" and type "./configure" there. The Qt configuration script should then tell you what to to, as in "Next, type gmake and the gmake install".
sega January 14, 2009 01:42
I can only find newer versions
I can only find newer versions of Qt (4.4.3) at the Trolltech website.
Where can I get the old one (4.3.x) needed to run OpenFOAM 1.5?
gwierink January 14, 2009 02:40
Hi Sebastian, You can find
Hi Sebastian,
You can find Qt-4.3.5 here:
ftp://ftp.trolltech.com/qt/source/qt...c-4.3.5.tar.gz
Look around in ftp://ftp.trolltech.com/qt/source/ if you're looking for a different version, but Qt-4.3.5 worked well for me.
Regards, Gijs
mcjicpm2 March 4, 2009 09:22
Hi, I have downloaded qt-x11-
I have downloaded qt-x11-opensource-src-4.4.3.tar.gz and then unzipped it, I also configured it. when I want to gmake it at the end It gave me the following error
can anyone help me please ???
Assembler messages:
Fatal error: can't create .obj/release-shared/qapplication.o: Permission denied
In file included from ../../include/QtGui/private/qt_x11_p.h:1,
from kernel/qapplication.cpp:75:
../../include/QtGui/private/../../../src/gui/kernel/qt_x11_p.h:71:22: error: X11/Xlib.h: No such file or directory
../../include/QtGui/private/../../../src/gui/kernel/qt_x11_p.h:76:23: error: X11/Xutil.h: No such file or directory
../../include/QtGui/private/../../../src/gui/kernel/qt_x11_p.h:77:21: error: X11/Xos.h: No such file or directory
../../include/QtGui/private/../../../src/gui/kernel/qt_x11_p.h:84:23: error: X11/Xatom.h: No such file or directory
../../include/QtGui/private/../../../src/gui/kernel/qt_x11_p.h:269: error: āColormapā does not name a type
gwierink March 4, 2009 13:06
Hi Parham, Do you make Qt a
Hi Parham,
Do you make Qt as root? It may be some write permission problem of your user account.
Rgds, Gijsbert
mcjicpm2 March 5, 2009 04:38
Hi yes I did it as root, but s
Hi yes I did it as root, but still have the same problem ,
Rgds, Parham
gwierink March 5, 2009 05:34
Do you perhaps miss the X11 de
Do you perhaps miss the X11 development package? In Fedora you can install the whole lot by
yum groupinstall "X11 Software Development"
If you're using Ubuntu I suppose it is something like
sudo apt-get install xorg-dev libx11-dev x11-dev
Possibly you need xlibs-dev as well.
Hope this helps.
Rgds, Gijsbert
