OpenFOAM-1.6 installation on Centos5.4 x86_64 Cluster
Old   April 7, 2010, 11:58
Default OpenFOAM-1.6 installation on Centos5.4 x86_64 Cluster
dhoom is on a distinguished road
Hello Friends,
By quirk of fate I am now an admin on a small univ. cluster eventhough I am a newbie with Linux and Clustering.
I am trying to install OpenFOAM-1.6 on the head-node of a cluster based on Centos5.4 x86_64. The directory in NSF shared. I downloaded the 2 source files named 1) OpenFOAM-1.6.General.gtgz and 2) ThirdParty-1.6.General.gtgz .
I have changed the bashrc and settings file to include mpi as I am using NSF shared MPICH2. I am getting error during ./Allwmake and I have attached the log file for review.
Thanks,
Dhoom
dhoom is offline   Reply With Quote
Old   April 8, 2010, 05:16
Assistant Moderator
Bernhard Gschaider
Originally Posted by dhoom View Post
Hello Friends,
Thanks,
Dhoom
Obviously the compiler doesn't find mpio.h (don't have MPICH so I can't help you where to find it). Check the wmake/rules/YourArchitecture/mpiYourImplementation that the paths there are correct.
About the second error: strange. Which g++ are you using? The one that comes with CentOS is 4.1 (which might not work with OF 1.6) BUT you can install 4.4 from the standard-repositories (but the best guess would be to use the 4.3 that comes in ThirdParty)
Bernhard
Old   April 8, 2010, 09:53
Bernhard,
I will check the paths to mpio.h are correct. I am using the third party module I guess for g++ as I have not specified anywhere to use system compilers.
Thanks for the feedback.
Old   April 12, 2010, 02:30
I have changed the settings.sh option to use Openfoam compilers and it seems I am getting a libPstream.so error and also errors in the Scotch package. Please find a log file attached.
hmm... where is my Johny Walker, I need it now...
Old   April 12, 2010, 06:41
Assistant Moderator
Bernhard Gschaider
I think it's rather obvious: mpich.a was not compiles -fPIC to make it reloacatable and therefor the linker refuses to link it.
Bernhard
Old   April 14, 2010, 02:21
any solutions?
Thanks,
D
Old   April 14, 2010, 12:39
Assistant Moderator
Bernhard Gschaider
any solutions?
Thanks,
D
Recompile MPICH or use the OpenMPI that comes with OF
Old   April 15, 2010, 01:31
Thanks, OK will do, do I need to recompile MPICH with any particular options, in the past I used ch3:ssm.
Dhoom
Old   April 15, 2010, 04:42
Assistant Moderator
Bernhard Gschaider
Keep that. The thing you have to make sure is that everything is compiled with the -fPIC-option.
This is the relevant section from your log:
/usr/bin/ld: /usr/cluster/mpich2-1.2.1/lib/libmpich.a(allreduce.o): relocation R_X86_64_32 against `a local symbol' can not be used when making a shared object; recompile with -fPIC
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 7 January 19, 2010 15:39
OpenFOAM 1.6 installation in Ubuntu 9.1 jsm OpenFOAM Installation 4 January 3, 2010 22:53
Problem installing OpenFOAM 1.5 installation on RHEL 4. vwsj84 OpenFOAM Installation 4 April 23, 2009 04:48
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
