-   OpenFOAM Installation (http://www.cfd-online.com/Forums/openfoam-installation/)
-   -   My experiences about Installing OpenFOAM on OPENSUSE103 32bit (http://www.cfd-online.com/Forums/openfoam-installation/57257-my-experiences-about-installing-openfoam-opensuse103-32bit.html)
coompressor November 14, 2008 22:50
Dear guys, Even I've faced
Dear guys,
Even I've faced many of the same problems posted on this forum, but finally I've successfully compiled both the openfoam and paraview without any errors. In order to check my understanding and so called experiences, I've reinstalled the Opensuse 10.3 and openfoam today, also no erros. So I'd like to share some of the lessons with you.
Steps,
1. downloading the packages from the openfoam official website; for 32bit, I've 4 packages;
2. Decompressing these packages into the installation folder, I prefer the directory, home/<user-name>/OpenFOAM.
3. Following the readmefile in the folder and adding the line .$HOME/OpenFOAM/OpenFOAM-1.5/etc/bashrc
4. Before doing the ./Allwmake command, you should check whether you've installed the GCC and QT correctly with proper version. using gcc --version and qmake --version. Actually, if you don't want to recompile the paraview or pvm3reader, you don't need to install the gcc on system as their is a gcc package in the thirdparty folder. But if you want to solve the problem that the openfoam always asks for the reader, you need to install the gcc on your system.
5. Besides, GCC, you should be sure that all the related QT softwares are installed. You could just click the computer ico at the bottom left corner and then install system. And use "qt" as the key words for searching, then install all the searched software packages. Also, "gmp" and "mpfr" packages must be installed.
6. Those who meet the problem of asking "a reader couldn't be found" should recompile pvm3reader following the next instructions.
enter the system folder /usr/lib with root account and run this command in the terminal.
ln -s libpython2.5.so.1.0 libpython2.5.so
then log out and using your former accout,and execute these commandlines.
cd $FOAM_UTILITIES/postProcessing/graphics/PV3FoamReader
./Allwclean
./Allwmake
The lessons that I learned during this process are that all the problems are caused by improper system installation, ie. not all the packages related to QT and gmp and mpfr related to new versions of gcc are installed.
Never try the command ./Allwmake before installing the above-mentioned packages. Because the problems or errors occur during the compilation are so diversal.
Hope this help you!
Thx all the foamers who helped me on this forum.
gmc_salta November 20, 2008 08:35
Dear all and formers We follo
We followed above instructions for installation OF1.5, in SUSE10.3 for 32 bit. We install all packages (GCC, Cmake, mpfr, gmp) also we done the symbolic link for library python, as root.
When execute ./Allwmake followed message error we obtained:
make[1]: Debido a los errores, el objetivo `application' no se reconstruyó.
make[1]: se sale del directorio `/home/foam5/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing'
make: *** [postProcessing] Error 2
make: Debido a los errores, el objetivo `application' no se reconstruyó.
+ '[' '' = doc ']'
We think this error is corrected with re-build paraview.
So we followed the instructions of readme file about, compiling Paraview3.3 and PV3FoamReader module, when execute buildParaView3.3-cvs we get this message error:
[ 14%] Building CXX object VTK/Graphics/CMakeFiles/vtkGraphics.dir/vtkGraphLayoutFilter.o
[ 14%] Building CXX object VTK/Graphics/CMakeFiles/vtkGraphics.dir/vtkGridSynchronizedTemplates3D.o
/home/foam5/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Graphics/vtkGridSynchronized Templates3D.cxx: In function 'void ContourGrid(vtkGridSynchronizedTemplates3D*, int*, T*, vtkStructuredGrid*, vtkPolyData*, PointsType*, vtkDataArray*) [with T = vtkGridSynchronizedTemplates3D::ThreadedExecute::V TK_TT, PointsType = ContourGrid::VTK_TT]':
/home/foam5/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Graphics/vtkGridSynchronized Templates3D.cxx:736: internal compiler error: Violación de segmento
Please submit a full bug report,
with preprocessed source if appropriate.
See <http://gcc.gnu.org/bugs.html> for instructions.
make[2]: *** [VTK/Graphics/CMakeFiles/vtkGraphics.dir/vtkGridSynchronizedTemplates3D.o] Error 1
make[1]: *** [VTK/Graphics/CMakeFiles/vtkGraphics.dir/all] Error 2
make: *** [all] Error 2
done
So, if anybody as an idea about this error, please help us. Are missing another packages install for?
Thanks. Ana and Sonia
hellorishi November 28, 2008 07:44
Hello, The issue of a "good
The issue of a "good" Linux system has been asked often and I have tried installing OpenFOAM atleast 11 times (on a 32bit machine). So based on my experience, I would recommend the following in brief (detailed instruction/messages below):
SHORT VERSION:
1. Install OpenSuSE 10.3
DVD version comes loaded with most of the required development packages,libraries, etc. Click every software during installation (maybe except GAMES).
Only 2 packages are missing.
2. Install following packages from the DVD using YaST:
mpfr-2.2.1-45.i586.rpm
mpfr-devel-2.2.1-45.i586.rpm
3. Clean the Paraview platforms and recompile as mentioned in README.
~/OpenFOAM/ThirdParty> rm -rf ParaView3.3-cvs/platforms
~/OpenFOAM/ThirdParty> buildParaView3.3-cvs
~/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics/PV3FoamRe ader> ./Allwclean
~/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics/PV3FoamRe ader>./Allwmake
4. Ready to run first example as mentioned in Section 6(Getting Started) !
DETAILED version follows soon...
ciao
Rishi
hellorishi November 28, 2008 08:15
Sorry I missed one step betwee
Sorry I missed one step between 2 and 3.
Please follow the README file of OF-1.5 3 (Section 3 : Installation) for installation using binary files and updating bash/csh.
hellorishi November 28, 2008 08:21
********************** DETAIL
DETAILED VERSION:*****
Installing OpenFOAM-1.5 with OpensuSE 10.3-DVD version.
Log of files created and commands tested when installing OpenFOAM-1.5 with OpensuSE 10.3-DVD version.
Testing the softare versions after a clean OpenSuSE 10.3 DVD install, with all software packages
With KDE Desktop.
> qmake --version
QMake version 2.01a
Using Qt version 4.3.1 in /usr/lib
> cmake --version
cmake version 2.4-patch 7
> gcc --version
gcc (GCC) 4.2.1 (SUSE Linux)
> gmake --version
GNU Make 3.81
> make --version
GNU Make 3.81
Install OpenFOAM 1.5 as described in Section 3 of README file.
http://www.opencfd.co.uk/openfoam/doc/README.html
Guess: bash might be default shell if you installed OpenSuSE as described above.
~/OpenFOAM/OpenFOAM-1.5/bin> foamInstallationTest
Executing /home/cfd/OpenFOAM/OpenFOAM-1.5/bin/foamInstallationTest:
Checking basic setup...
Shell: bash
Host: andr001
OS: Linux version 2.6.22.5-31-default
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/cfd/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/cfd/OpenFOAM/cfd-1.5 yes no
$WM_THIRD_PARTY_DIR /home/cfd/OpenFOAM/ThirdParty yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/cfd/OpenFOAM/OpenFOAM-1.5 yes yes yes
$FOAM_APPBIN ...M-1.5/applications/bin/linuxGccDPOpt yes yes yes
$FOAM_USER_APPBIN ...d-1.5/applications/bin/linuxGccDPOpt yes yes no
$WM_DIR /home/cfd/OpenFOAM/OpenFOAM-1.5/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...nFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt yes yes yes
$FOAM_USER_LIBBIN ...d/OpenFOAM/cfd-1.5/lib/linuxGccDPOpt yes yes no
$MPI_ARCH_PATH ...penmpi-1.2.6/platforms/linuxGccDPOpt yes yes yes
Third party software
Software Version Location
gcc 4.3.1 .../OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc
gzip 1.3.12 /usr/bin/gzip
tar 1.17 /bin/tar
icoFoam 1.5 ...AM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/icoFoam
Checking networking...
Action Result Crit
Pinging_andr001 Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the OpenFOAM enviroment.
Base configuration ok.
Critical systems ok.
done.
> cd $FOAM_INST_DIR/ThirdParty
Building ParaView3.3-cvs
MPI support : OFF
Python support : OFF
MESA support : OFF
Source : /home/cfd/OpenFOAM/ThirdParty/ParaView3.3-cvs
Target : /home/cfd/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc
-- Check for working C compiler: /home/cfd/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc
-- Check for working C compiler: /home/cfd/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc -- broken
CMake Error: The C compiler "/home/cfd/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc" is not able to compile a simple test program.
It fails with the following output:
/usr/bin/gmake -f CMakeFiles/cmTryCompileExec.dir/build.make CMakeFiles/cmTryCompileExec.dir/build
gmake[1]: Entering directory `/home/cfd/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFiles/CMa keTmp'
/home/cfd/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux/bin/cmake -E cmake_progress_report /home/cfd/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFiles/CMak eTmp/CMakeFiles 1
Building C object CMakeFiles/cmTryCompileExec.dir/testCCompiler.o
/home/cfd/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc -o CMakeFiles/cmTryCompileExec.dir/testCCompiler.o -c /home/cfd/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFiles/CMak eTmp/testCCompiler.c
/home/cfd/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/../libexec/gcc/i686- pc-linux-gnu/4.3.1/cc1: error while loading shared libraries: libmpfr.so.1: cannot open shared object file: No such file or directory
gmake[1]: *** [CMakeFiles/cmTryCompileExec.dir/testCCompiler.o] Error 1
gmake[1]: Leaving directory `/home/cfd/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFiles/CMa keTmp'
gmake: *** [cmTryCompileExec/fast] Error 2
CMake will not be able to correctly generate this project.
-- Configuring done
make: *** No targets specified and no makefile found. Stop.
done
POSSIBLE SOLUTION TO PROBLEM: Install libmpfr
mpfr-devel-2.2.1-45.i586.rpm from 10.3 DVD
It Works! Output after compiling paraview
Creating paraview 3.3 soft link to /bin
Installation complete
Set environment variables:
- ParaView_INST_DIR to /home/cfd/OpenFOAM/ThirdParty/ParaView3.3-cvs
- ParaView_DIR to /home/cfd/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc
- PV_PLUGIN_PATH to /home/cfd/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt
Add /home/cfd/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/bin to PATH
done
Works! PATH output after installation and restarting bash
echo $PATH
/home/cfd/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/bin:/home/cfd/O penFOAM/ThirdParty/cmake-2.4.6/platforms/linux/bin:/home/cfd/OpenFOAM/ThirdParty /openmpi-1.2.6/platforms/linuxGccDPOpt/bin:/home/cfd/OpenFOAM/ThirdParty/gcc-4.3 .1/platforms/linux/bin:/home/cfd/OpenFOAM/cfd-1.5/applications/bin/linuxGccDPOpt :/home/cfd/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt:/home/cfd/OpenFO AM/OpenFOAM-1.5/wmake:/home/cfd/OpenFOAM/OpenFOAM-1.5/bin:/opt/kde3/bin:/home/cf d/bin:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/usr/l ib/mit/bin:/usr/lib/mit/sbin:/usr/lib/qt3/bin
Compiling PV3FoamReader module
~/OpenFOAM/ThirdParty/ParaView3.3-cvs> cd $FOAM_UTILITIES/postProcessing/graphics/PV3FoamReader
+ rm -r PV3FoamReader/Make
rm: cannot remove `PV3FoamReader/Make': No such file or directory
+ wclean libso vtkPV3Foam
wclean vtkPV3Foam
+ '[' -d /home/cfd/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc -a -r /home/cfd/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc ']'
+ case "$ParaView_VERSION" in
+ wmake libso vtkPV3Foam
wmakeLnInclude: linking include files to /home/cfd/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics/P V3FoamReader/vtkPV3Foam/lnInclude
Making dependency list for source file vtkPV3Foam.C
'/home/cfd/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libvtkPV3Foam.so' is up to date.
+ cd PV3FoamReader
+ mkdir -p Make/linuxGccDPOpt
+ cd Make/linuxGccDPOpt
+ cmake ../..
-- Check for working C compiler: /home/cfd/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc -- works
-- Check size of void*
-- Check size of void* - done
-- Check for working CXX compiler: /home/cfd/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/c++
-- Check for working CXX compiler: /home/cfd/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/c++ -- works
-- Loading ParaView CMake commands
-- Loading ParaView CMake commands - done
-- Looking for Q_WS_X11
-- Looking for Q_WS_X11 - found
-- Looking for Q_WS_MAC
-- Looking for Q_WS_MAC - not found.
-- Looking for Q_WS_WIN
-- Looking for Q_WS_WIN - not found.
-- Found Qt-Version 4.3.1
-- Configuring done
-- Generating done
-- Build files have been written to: /home/cfd/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics/P V3FoamReader/PV3FoamReader/Make/linuxGccDPOpt
+ make
[ 9%] Generating qrc_PV3FoamReader.cxx
[ 18%] Generating moc_PV3FoamReaderPluginImplementation.cxx
Scanning dependencies of target PV3FoamReader
[ 27%] Building CXX object CMakeFiles/PV3FoamReader.dir/moc_PV3FoamReaderPluginImplementation.o
[ 36%] Building CXX object CMakeFiles/PV3FoamReader.dir/PV3FoamReaderPluginImplementation.o
[ 45%] Building CXX object CMakeFiles/PV3FoamReader.dir/qrc_PV3FoamReader.o
Linking CXX shared library /home/cfd/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libPV3FoamReader.so
[ 45%] Built target PV3FoamReader
[ 54%] Generating vtkSMXML_PV3FoamReader_SM.h
-- Generate module: PV3FoamReader_SM
[ 63%] Generating vtkPV3FoamReaderClientServer.cxx
Scanning dependencies of target PV3FoamReader_SM
[ 72%] Building CXX object CMakeFiles/PV3FoamReader_SM.dir/vtkPV3FoamReader.o
[ 81%] Building CXX object CMakeFiles/PV3FoamReader_SM.dir/vtkPV3FoamReaderClientServer.o
[ 90%] Building CXX object CMakeFiles/PV3FoamReader_SM.dir/PV3FoamReader_SMInit.o
[100%] Building CXX object CMakeFiles/PV3FoamReader_SM.dir/vtkPVPluginInit_PV3FoamReader_SM.o
Linking CXX shared library /home/cfd/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libPV3FoamReader_SM.so
[100%] Built target PV3FoamReader_SM
Running first examples, as mentioned in README Section 6
mkdir -p $HOME/OpenFOAM/${USER}-${WM_PROJECT_VERSION}/run
cp -r $WM_PROJECT_DIR/tutorials $HOME/OpenFOAM/${USER}-${WM_PROJECT_VERSION}/run
cd $HOME/OpenFOAM/${USER}-${WM_PROJECT_VERSION}/run/tutorials/icoFoam/cavity
blockMesh
icoFoam
paraFoam
Everything works including paraFoam http://www.cfd-online.com/OpenFOAM_D...part/happy.gif
awacs December 24, 2008 22:45
Dear Rishi Patil, I got "FAT
Dear Rishi Patil,
I got "FATAL ERROR: OpenFOAM environment not configured" when I tried to install OF1.5 on OpenSUSE10.3 (with KDE workstop).
The softare versions are :
> qmake --version
QMake version 2.01a
> cmake --version
> gcc --version
> gmake --version
GNU Make 3.81
> make --version
GNU Make 3.81
My foamSystemCheck is ok.
I have added "$HOME/OpenFOAM/OpenFOAM-<version>/etc/bashrc"to the end of my $HOME/.bashrc file.When sourcing the $HOME/.bashrc file,I got "bash:.... permission denied".Then I typed
>> chmod -R 755 /home/OpenFOAM
>> $HOME/.bashrc
No problems were reported this time.
But when I test the installation with by executing the 'foamInstallationTest' script,it gives:
Executing /home/OpenFOAM/OpenFOAM/OpenFOAM-1.5/bin/foamInstallationTest:
FATAL ERROR: OpenFOAM environment not configured.
Please refer to the installation section of the README file:
<openfoam>/OpenFOAM-1.5/README
to source the OpenFOAM environment.
I'm a newer in linux and OpenFOAM.
Can you please suggest what should I do?
Thanks a lot.
awacs December 25, 2008 05:42
Hi Rishi Patil, I have insta
Hi Rishi Patil,
I have installed OpenFOAM-1.5 successfully under your introduction.
Thankshttp://www.cfd-online.com/OpenFOAM_D...part/happy.gif
nikola_m December 26, 2008 09:23
liu, I have the same problem a
liu, I have the same problem as you - how can I solve it???
I think Rishi gave very good instructions, but I feel I'm stuck at point 3. of README :/
coompressor January 19, 2009 19:52
For this error, the installation has given you the right hint.
I don't know why you persons didn't read the errors carefully.
The above information tells you to configure the .bashrc file and source it to tell openfoam the position of related files.
louisgag February 19, 2010 00:00
Originally Posted by coompressor (Post 206858)
Dear guys,
Thank you for these guidelines coompressor, it solved one of the issues I was having when compiling 1.6.x, which interestingly does not compile gmp nor zlib nor mpfr by default, my issue was solved when I copied those 3 compiled "folders" from a previous 1.5 installation into my 1.6.x thirdparty folder.
regards,
-Louis
