December 9, 2008, 09:25 |
Hi everybody,
in my system
Sven Degner
Rep Power: 17 |
Hi everybody,
in my system (SUSE user) works OPenFoam great, but Im only a user in a network, with a global OpenFoam Version for all User (no permission to the OF/src files to edit) . Now, I can only use the standart solver and boundarys, and not my own. my question now, how can I add a local install of OpenFoam, beside the global installation ? thx for help |
December 9, 2008, 09:40 |
If you want to write your own
Mark Olesen
Rep Power: 40 |
If you want to write your own solvers and boundary conditions, you usually just put them together in your own ~/OpenFOAM/USER-VERSION/application/... directory structure and have them compile into
EXE = $(FOAM_USER_APPBIN)/... You shouldn't normally need to have a personal installation per se. If you really need to change the standard OpenFOAM files, you are either doing bug fixing or creating a new model/functionality, in which case deriving from an existing model is usually the better solution. |
Local residuals | chrisegerer | OpenFOAM Running, Solving & CFD | 17 | March 6, 2024 09:42 |
local age of air in starccm+ | Mike23 | Siemens | 3 | September 20, 2008 11:16 |
sum local | stephan | OpenFOAM Running, Solving & CFD | 1 | July 24, 2007 10:41 |
Local Conservativity? | Sadek | Main CFD Forum | 0 | April 13, 2006 07:32 |
Is FEM Local Conservative | R.A.Khurram | Main CFD Forum | 9 | July 2, 2003 02:47 |
