Can anybody help me to solve the list errors while compiling Openfoam 15 on Opensuse 103 32bit |
November 12, 2008, 19:53 |
The following are the messages
Chuang Gao
The following are the messages related to the possible errors while compiling
************************************************ alex@alex:~/OpenFOAM/OpenFOAM-1.5> ./Allwmake + cd . + cd wmake/src + make make: Nothing to be done for `all'. + cd /home/alex/OpenFOAM/ThirdParty + ./Allwmake + '[' -n '' ']' + '[' -n '' ']' + '[' -n '' ']' + '[' -n '' ']' + '[' -n '' ']' + wmake libso zlib-1.2.3 '/home/alex/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libz.so' is up to date. + cd malloc + ./Allwmake + wmake libso hoard '/home/alex/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libhoard.so' is up to date. + wmake libo fbsdmalloc '/home/alex/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libfbsdmalloc.o' is up to date. + case "$WM_MPLIB" in + '[' -r /home/alex/OpenFOAM/ThirdParty/openmpi-1.2.6/platforms/linuxGccDPOpt/lib/libmpi. so ']' + echo 'have OPENMPI shared library' have OPENMPI shared library + cd metis-5.0pre2 + wmake libso GKlib '/home/alex/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libGKlib.so' is up to date. + wmake libso libmetis '/home/alex/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libmetis.so' is up to date. + '[' -d /home/alex/OpenFOAM/ThirdParty/openmpi-1.2.6/platforms/linuxGccDPOpt ']' + cd ParMetis-3.1 + wmake libso METISLib '/home/alex/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/openmpi-1.2.6/libmetis-parme tis.so' is up to date. + wmake libso ParMETISLib '/home/alex/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/openmpi-1.2.6/libparmetis.so ' is up to date. + wmake libso ParMGridGen-1.0/MGridGen/IMlib '/home/alex/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libIMlib.so' is up to date. + wmake libso ParMGridGen-1.0/MGridGen/Lib '/home/alex/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libMGridGen.so' is up to date. + cd src + ./Allwmake + cd OpenFOAM + wmakeLnInclude . + cd Pstream + ./Allwmake + wmake libso dummy '/home/alex/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/dummy/libPstream.so' is up to date. + case "$WM_MPLIB" in + export WM_OPTIONS=linuxGccDPOptOPENMPI + WM_OPTIONS=linuxGccDPOptOPENMPI + set +x Note: ignore spurious warnings about missing mpicxx.h headers + wmake libso mpi '/home/alex/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/openmpi-1.2.6/libPstream.so' is up to date. + wmake libo OSspecific/Unix '/home/alex/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOSspecific.o' is up to date. + wmake libso OpenFOAM '/home/alex/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so' is up to date. + wmake libso lagrangian/basic '/home/alex/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/liblagrangian.so' is up to date. + wmake libso triSurface SOURCE=triSurface/interfaces/STL/readSTLASCII.L ; flex++ -f $SOURCE ; mv lex.yy.cc Make/linuxGccDPOpt/readSTLASCII.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/alex/OpenFOAM/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/home/alex/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/alex/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c Make/linuxGccDPOpt/readSTLASCII.C -o Make/linuxGccDPOpt/readSTLASCII.o lex.yy.cc: In member function 'int STLLexer::lex()': lex.yy.cc:5549: warning: use of old-style cast lex.yy.cc:5549: warning: use of old-style cast lex.yy.cc:5565: warning: use of old-style cast lex.yy.cc:5779: warning: use of old-style cast triSurface/interfaces/STL/readSTLASCII.L:208: warning: unused variable 'endPtr' lex.yy.cc: In member function 'int yyFlexLexer::yy_get_next_buffer()': lex.yy.cc:6027: warning: use of old-style cast lex.yy.cc:6050: warning: use of old-style cast lex.yy.cc:6063: warning: use of old-style cast lex.yy.cc:6063: warning: use of old-style cast lex.yy.cc:6084: warning: use of old-style cast lex.yy.cc: In member function 'yy_state_type yyFlexLexer::yy_get_previous_state()': lex.yy.cc:6131: warning: use of old-style cast lex.yy.cc:6131: warning: use of old-style cast lex.yy.cc: In member function 'void yyFlexLexer::yyunput(int, char*)': lex.yy.cc:6191: warning: use of old-style cast lex.yy.cc:6192: warning: use of old-style cast lex.yy.cc:6200: warning: use of old-style cast lex.yy.cc: In member function 'int yyFlexLexer::yyinput()': lex.yy.cc:6267: warning: use of old-style cast lex.yy.cc: In member function 'virtual yy_buffer_state* yyFlexLexer::yy_create_buffer(std::istream*, int)': lex.yy.cc:6345: warning: use of old-style cast lex.yy.cc:6354: warning: use of old-style cast lex.yy.cc: In member function 'virtual void yyFlexLexer::yy_delete_buffer(yy_buffer_state*)': lex.yy.cc:6376: warning: use of old-style cast lex.yy.cc:6379: warning: use of old-style cast lex.yy.cc:6381: warning: use of old-style cast lex.yy.cc: In member function 'void yyFlexLexer::yyensure_buffer_stack()': lex.yy.cc:6508: warning: use of old-style cast lex.yy.cc:6526: warning: use of old-style cast lex.yy.cc: In member function 'void yyFlexLexer::yy_push_state(int)': lex.yy.cc:6544: warning: use of old-style cast lex.yy.cc:6547: warning: use of old-style cast lex.yy.cc:6547: warning: use of old-style cast lex.yy.cc: In function 'void* yyalloc(yy_size_t)': lex.yy.cc:6627: warning: use of old-style cast lex.yy.cc: In function 'void* yyrealloc(void*, yy_size_t)': lex.yy.cc:6639: warning: use of old-style cast lex.yy.cc:6639: warning: use of old-style cast lex.yy.cc: In function 'void yyfree(void*)': lex.yy.cc:6644: warning: use of old-style cast SOURCE=triSurface/interfaces/STL/readSTLBINARY.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/alex/OpenFOAM/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/home/alex/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/alex/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/readSTLBINARY.o SOURCE=triSurface/interfaces/GTS/writeGTS.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/alex/OpenFOAM/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/home/alex/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/alex/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/writeGTS.o lex.yy.cc: In member function 'virtual int yyFlexLexer::yylex()': lex.yy.cc:12145: warning: use of old-style cast lex.yy.cc:12145: warning: use of old-style cast lex.yy.cc:12161: warning: use of old-style cast lex.yy.cc:12860: warning: use of old-style cast lex.yy.cc: In member function 'int yyFlexLexer::yy_get_next_buffer()': lex.yy.cc:13108: warning: use of old-style cast lex.yy.cc:13131: warning: use of old-style cast lex.yy.cc:13144: warning: use of old-style cast lex.yy.cc:13144: warning: use of old-style cast lex.yy.cc:13165: warning: use of old-style cast lex.yy.cc: In member function 'yy_state_type yyFlexLexer::yy_get_previous_state()': lex.yy.cc:13212: warning: use of old-style cast lex.yy.cc:13212: warning: use of old-style cast lex.yy.cc: In member function 'void yyFlexLexer::yyunput(int, char*)': lex.yy.cc:13272: warning: use of old-style cast lex.yy.cc:13273: warning: use of old-style cast lex.yy.cc:13281: warning: use of old-style cast lex.yy.cc: In member function 'int yyFlexLexer::yyinput()': lex.yy.cc:13348: warning: use of old-style cast lex.yy.cc: In member function 'virtual yy_buffer_state* yyFlexLexer::yy_create_buffer(std::istream*, int)': lex.yy.cc:13426: warning: use of old-style cast lex.yy.cc:13435: warning: use of old-style cast lex.yy.cc: In member function 'virtual void yyFlexLexer::yy_delete_buffer(yy_buffer_state*)': lex.yy.cc:13457: warning: use of old-style cast lex.yy.cc:13460: warning: use of old-style cast lex.yy.cc:13462: warning: use of old-style cast lex.yy.cc: In member function 'void yyFlexLexer::yyensure_buffer_stack()': lex.yy.cc:13589: warning: use of old-style cast lex.yy.cc:13607: warning: use of old-style cast lex.yy.cc: In member function 'void yyFlexLexer::yy_push_state(int)': lex.yy.cc:13625: warning: use of old-style cast lex.yy.cc:13628: warning: use of old-style cast lex.yy.cc:13628: warning: use of old-style cast lex.yy.cc: In function 'void* yyalloc(yy_size_t)': lex.yy.cc:13708: warning: use of old-style cast lex.yy.cc: In function 'void* yyrealloc(void*, yy_size_t)': lex.yy.cc:13720: warning: use of old-style cast lex.yy.cc:13720: warning: use of old-style cast lex.yy.cc: In function 'void yyfree(void*)': lex.yy.cc:13725: warning: use of old-style cast -- Loading ParaView CMake commands -- Loading ParaView CMake commands - done CMake Error: Error in cmake code at #ifndef _@PLUGIN_NAME@Plugin_h:458: Unknown CMake command "QT4_WRAP_CPP". CMake Error: Error in cmake code at /home/alex/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics/ PV3FoamReader/PV3FoamReader/CMakeLists.txt:44: A command failed during the invocation of macro "ADD_PARAVIEW_GUI_EXTENSION". CMake Error: Error in cmake code at #ifndef _@PLUGIN_NAME@Plugin_h:562: ADD_PARAVIEW_GUI_EXTENSION unknown error. Current CMake stack: /home/alex/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics/ PV3FoamReader/PV3FoamReader/CMakeLists.txt;/home/alex/OpenFOAM/ThirdParty/cmake- 2.4.6/platforms/linux/share/cmake-2.4/Modules/CMakeCInformation.cmake;/home/alex /OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux/share/cmake-2.4/Modules/CMakeCX XInformation.cmake CMake Error: Error in cmake code at /home/alex/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics/ PV3FoamReader/PV3FoamReader/CMakeLists.txt:44: A command failed during the invocation of macro "ADD_PARAVIEW_PLUGIN". CMake Error: Error in cmake code at /home/alex/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics/ PV3FoamReader/PV3FoamReader/CMakeLists.txt:43: ADD_PARAVIEW_PLUGIN unknown error. Current CMake stack: /home/alex/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics/ PV3FoamReader/PV3FoamReader/CMakeLists.txt;/home/alex/OpenFOAM/ThirdParty/cmake- 2.4.6/platforms/linux/share/cmake-2.4/Modules/CMakeCInformation.cmake;/home/alex /OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux/share/cmake-2.4/Modules/CMakeCX XInformation.cmake -- Configuring done + make make[3]: Entering directory `/home/alex/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics /PV3FoamReader/PV3FoamReader/Make/linuxGccDPOpt' make[3]: *** No targets specified and no makefile found. Stop. make[3]: Leaving directory `/home/alex/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics /PV3FoamReader/PV3FoamReader/Make/linuxGccDPOpt' make[2]: *** [PV3FoamReader] Error 2 + '[' -d /home/alex/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc -a -r /home/alex/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc ']' + case "$ParaView_VERSION" in make[2]: Target `application' not remade because of errors. make[2]: Leaving directory `/home/alex/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics ' make[1]: *** [graphics] Error 2 make[1]: Target `application' not remade because of errors. make[1]: Leaving directory `/home/alex/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing' make: *** [postProcessing] Error 2 |
Problems while compiling OpenFOAM15 with OpenSuse 103 | coompressor | OpenFOAM Installation | 3 | November 7, 2008 00:57 |
Dissimilarity in compiling new BC in 32bit OpenSuSE 103 versus 64bit CentOS 50 versus 64bit SLED 100 | sponiar | OpenFOAM Running, Solving & CFD | 3 | February 26, 2008 06:31 |
Compiling OpenFOAM13 on AMD64 with OpenSUSE 101 | silent_missile | OpenFOAM Installation | 5 | August 10, 2007 07:31 |
Compiling errors for OpenFOAM 13 | brucejimo | OpenFOAM Installation | 3 | October 5, 2006 00:01 |
Linked list errors | hjasak | OpenFOAM | 0 | October 7, 2005 07:14 |
