November 10, 2008, 17:54 |
I keep getting the following 2
I keep getting the following 2 critical errors when trying to instal OpenFOAM-1.5
gcc 4.0.3 WARNING: Conflicting installations: OpenFOAM settings : /home/shuo/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc current path : /usr/bin/gcc CRITICAL ERROR gzip 1.3.5 /bin/gzip tar 1.15.1 /bin/tar icoFoam WARNING: Conflicting installations: OpenFOAM settings : /home/shuo/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/icoFoam current path : CRITICAL ERROR I have installed it in $Home/OpenFOAM and when i sournce the bash script >> . $HOME/.bashrc it tells me to modifiy WM_COMPILER_INST setting to 'System' which I did. |
November 11, 2008, 04:32 |
The bash script shouldn't tell
Ville Tossavainen
Rep Power: 17 |
The bash script shouldn't tell you to use the system compiler unless you have modified the scripts. Have you made any other modifications than changing "WM_COMPILER_INST" to "system"? Can you run "icoFoam" without any problems?
I would recommend using the c++ compiler provided in the OpenFOAM package. That's if you plan to make any mofications. |
Display Modes | |
Critical errors gcc and icoFoam during installation of 15 | quartzian | OpenFOAM Installation | 3 | December 12, 2008 12:42 |
Critical errors on gcc and icofoam | giuliano | OpenFOAM Installation | 4 | June 25, 2008 13:31 |
Help with Solving Critical Errors | andrewlindsay | OpenFOAM Installation | 0 | October 7, 2006 19:58 |
critical re | jj | Main CFD Forum | 5 | July 28, 2006 23:06 |
Critical Re value | Asok | Main CFD Forum | 0 | October 18, 2002 00:29 |
