May 6, 2009, 20:00 |
Building Paraview, Redhat
Paul
Rep Power: 16 |
I am fairly new to Linux and this is my first post on cfd-online. I cannot build ParaView. Some relevant information: Red Hat Enterprise Linux Client release 5 (Tikanga) x86_64 QMake version 2.01a Using Qt version 4.3.1 in /usr/local/Trolltech/Qt-4.3.1/lib mpfr-2.4.1 gmp-4.3.0 I have installed everything manually (not familiar with rpm or apt-get). Error: [applied@linux ThirdParty]# buildParaView3.3-cvs Building ParaView3.3-cvs MPI support : OFF Python support : OFF MESA support : OFF Source : /home/achuth/OpenFOAM/ThirdParty/ParaView3.3-cvs Target : /home/achuth/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc -- Check for working C compiler: /home/achuth/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc -- Check for working C compiler: /home/achuth/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc -- broken CMake Error: The C compiler "/home/achuth/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc" is not able to compile a simple test program. It fails with the following output: /usr/bin/gmake -f CMakeFiles/cmTryCompileExec.dir/build.make CMakeFiles/cmTryCompileExec.dir/build gmake[1]: Entering directory `/home/achuth/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/CMakeFiles/CMakeTmp' /home/achuth/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux64/bin/cmake -E cmake_progress_report /home/achuth/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/CMakeFiles/CMakeTmp/CMakeFiles 1 Building C object CMakeFiles/cmTryCompileExec.dir/testCCompiler.o /home/achuth/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc -o CMakeFiles/cmTryCompileExec.dir/testCCompiler.o -c /home/achuth/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/CMakeFiles/CMakeTmp/testCCompiler.c /home/achuth/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../libexec/gcc/x86_64-unknown-linux-gnu/4.3.1/cc1: error while loading shared libraries: libmpfr.so.1: cannot open shared object file: No such file or directory gmake[1]: Leaving directory `/home/achuth/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/CMakeFiles/CMakeTmp' gmake[1]: *** [CMakeFiles/cmTryCompileExec.dir/testCCompiler.o] Error 1 gmake: *** [cmTryCompileExec/fast] Error 2 CMake will not be able to correctly generate this project. -- Configuring done make: *** No targets specified and no makefile found. Stop. done Do I need to download MPFR or GMP in the ThirdParty directory? [applied@linux ThirdParty]# ls Allwmake cmake-2.4.6 malloc openmpi-1.2.6 ParMetis-3.1 README AllwmakeLibccmio gcc-4.3.1 metis-5.0pre2 ParaView3.3-cvs ParMGridGen-1.0 zlib-1.2.3 This is my first foray with Linux. Thanks, Paul Last edited by PaulK; May 7, 2009 at 15:04. |
May 8, 2009, 17:38 |
Paul
Rep Power: 16 |
>> shared object file: No such file or directory I understand that this error tells me that the linker cannot find the mpfr dynamic libraries. [applied@linux ThirdParty]# locate libmpfr.so.1 /home/achuth/mpfr-2.4.1/.libs/libmpfr.so.1 /home/achuth/mpfr-2.4.1/.libs/libmpfr.so.1.2.0 /usr/local/lib/libmpfr.so.1 /usr/local/lib/libmpfr.so.1.2.0 I have tried modifying my LD_LIBRARY_PATH variable in .bashrc and .bash_profile with no luck: export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/lib What am I missing? It clearly has something to do with mpfr, but what else can I check? I can't get past building paraView. Thanks in advance. Paul |
May 9, 2009, 11:49 |
Gijsbert Wierink
Rep Power: 18 |
Hi Paul,
I read you have a x86_64 system. I had a similar problem on Fedora x86_64, because the installer is looking for some library in /usr/local/lib/. But since you have a 64 bit system it might be located in usr/local/lib64 (or the other way around). Copying the library file or making a symbolic link with Code:
ln -s /usr/local/lib/libmpfr.so.1 /usr/local/lib64/libmpfr.so.1 Hope this is of any help. Regards, Gijsbert |
May 9, 2009, 20:20 |
Paul
Rep Power: 16 |
Thanks for your response, Gijsbert.
I tried your advice but it did not work. I created additional links to the other libmpfr.so files as well. Here are my library directories: /usr/local/lib -- libgmp.a libgmp.so libgmp.so.3.5.0 libmpfr.la libmpfr.so.1 libgmp.la libgmp.so.3 libmpfr.a libmpfr.so libmpfr.so.1.2.0 /usr/local/lib64 -- libmpfr.so libmpfr.so.1 libmpfr.so.1.2.0 I still get the same error. Paul |
May 10, 2009, 03:05 |
#5 | |
Gijsbert Wierink
Rep Power: 18 |
Hmm, ok. I read on some blog that it may be a problem that the libraries are in /usr/local/lib... and not in /usr/lib...:
Cheers, Gijsbert |
May 14, 2009, 13:15 |
Paul
Rep Power: 16 |
After linking libraries, I get a different error:
- /home/achuth/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../libexec/gcc/x86_64-unknown-linux-gnu/4.3.1/cc1: error while loading shared libraries: libmpfr.so.1: wrong ELF class: ELFCLASS32 - I see that it is related to a 32-bit / 64-bit library confusion. - [applied@linux ThirdParty]# locate libmpfr.so.1 /home/achuth/mpfr-2.4.1/.libs/libmpfr.so.1 /home/achuth/mpfr-2.4.1/.libs/libmpfr.so.1.2.0 /usr/lib/libmpfr.so.1 /usr/lib64/libmpfr.so.1 /usr/local/lib/libmpfr.so.1 /usr/local/lib/libmpfr.so.1.2.0 /usr/local/lib64/libmpfr.so.1 /usr/local/lib64/libmpfr.so.1.2.0 - I also note that when I type echo $LD_LIBRARY_PATH, I get that it is an undefined variable. It is, however, defined when I echo $LD_LIBRARY_PATH as a regular user. Note that for the build paraview step, I need to log in as a super-user. I am still confused by this. I have seen some similar issues online but can't get past this build process. I can locate libmpfr.so.1 but cc1 cannot find it in the build process (this might help): [applied@linux ThirdParty]$ ldd -v /home/achuth/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/libexec/gcc/x86_64-unknown-linux-gnu/4.3.1/cc1 libmpfr.so.1 => not found libgmp.so.3 => /usr/lib64/libgmp.so.3 (0x0000003395000000) libc.so.6 => /lib64/libc.so.6 (0x0000003382200000) ... As seen above, I can locate libmpfr.so.1. What is going on? Thanks in advance. Last edited by PaulK; May 14, 2009 at 21:16. |
October 12, 2009, 13:01 |
builParaView3.3-cvs got following error
Nirmal
Rep Power: 16 |
When I tried to run buildParaView3.3-cvs after rmoving platforms directory, i got the following messages. [ 52%] [ 52%] Building CXX object Utilities/VTKClientServer/Graphics/CMakeFiles/vtkGraphicsCS.dir/vtkWindowedSincPolyDataFilterClientServer.o Building CXX object Utilities/VTKClientServer/Graphics/CMakeFiles/vtkGraphicsCS.dir/vtkGraphicsCSInit.o Linking CXX shared library ../../../bin/libvtkGraphicsCS.so [ 52%] Built target vtkGraphicsCS make: *** [all] Error 2 done please let me know, how can i avoid this and complete the installation? |
installation, paraview, redhat |
Building paraview | neilm | OpenFOAM Installation | 8 | October 12, 2009 13:03 |
Compilation error OF1.5-dev on Suse10.3 | darenyang | OpenFOAM Installation | 0 | April 29, 2009 04:55 |
Error building DICOMAppHelper during ParaView compilation | geoffjay | OpenFOAM Installation | 1 | May 7, 2008 13:07 |
[OpenFOAM] Both paraview and paraFoam crash on Redhat Linux WS v4 64bit | sek | ParaView | 4 | August 17, 2006 16:26 |
[OpenFOAM] Building Paraview with reader builtin instead of parafoam script | tj22 | ParaView | 2 | April 7, 2006 12:55 |
