-   OpenFOAM Installation (http://www.cfd-online.com/Forums/openfoam-installation/)
-   -   LibPV3FoamReader_SMso and FoamReaderso missing in binary pack (http://www.cfd-online.com/Forums/openfoam-installation/57293-libpv3foamreader_smso-foamreaderso-missing-binary-pack.html)
sam October 23, 2008 06:51
Hi I'm currently installing
Hi
I'm currently installing OpenFOAM using the binary pack. The solver works right away. However, using paraFoam, paraview asks me for a reader for cavity.OpenFOAM and gives me a list to choose from.
Presumably, this has to do with PV3FoamReader. Indeed, when I checked my installation (from the binary pack) with the installation of a friend who compiled, we figured out that the library files
$FOAM_LIBBIN/libPV3FoamReader_SM.so
$FOAM_LIBBIN/libPV3FoamReader.so
are missing in the binary pack.
Is there way to get them?
thanks, samuel
ep4 October 30, 2008 06:17
Hi, i have a similar proble
i have a similar problem, when making ./Allmake to compile PV3FoamReader, it doesn't have $FOAM_LIBBIN/libPV3FoamReader_SM.so.
Moreover i can't download OpenFOAM-1.5.linux64GccDPOpt.gtgz. I already tried with different mirors but it stops each time at 74 %. Maybe it could explain my first problem?
Could someone help me? Thank you!
Eric
ep4 October 30, 2008 09:08
Here is the error i receive:
Linking CXX shared library /ric_home/ep4/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libPV3FoamReader_SM.so
/usr/bin/ld: skipping incompatible /ric_home/ep4/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so when searching for -lOpenFOAM
/usr/bin/ld: cannot find -lOpenFOAM
collect2: ld gab 1 als Ende-Status zurück
make[2]: *** [/ric_home/ep4/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libPV3FoamReader_SM.so] Fehler 1
make[1]: *** [CMakeFiles/PV3FoamReader_SM.dir/all] Fehler 2
make: *** [all] Fehler 2
I have read in other post a similar problem, not with -lOpenFoam but with -lhistory or things like that. The solution proposed was to installed some packages like readline, libreadline, liberty. After verification, there are present on my system.
Any suggestion?
Thanks
Eric
