Hello OF-experts!
It should b
Hello OF-experts!
It should be pointed out at first that this is my first thread addressed to this forum. I have been using OF1.3 successful until now. I could solve all occuring difficulties by reading your questions and answers. Thanks to all of you. A few days ago I started to install OF1.5. I have been successful with the Qt4.3.2 installation. I also run my first test case of icoFoam as recommended in README file. Everything works fine until I try to complete the last step of the README, precisely 'Compiling Paraview 3.3 and the PV3FoamReader module'. I get the following error message: CMake Error: This project requires some variables to be set, and cmake can not find them. Please set the following variables: OPENGL_INCLUDE_DIR (ADVANCED) Since I am not very familiar with compiling and all related programs like cmake, make, and so on I have actually meet the limits of my linux knowledge. Hopefully, someone can tell my how to solve the problem. Some relevant information: jw@jw02:~/OpenFOAM/OpenFOAM-1.5$ qmake --version QMake version 2.01a Using Qt version 4.3.2 in /usr/local/Trolltech/Qt-4.3.2/lib jw@jw02:~$ uname -a Linux jw02 2.4.27-3-386 #1 Wed Dec 6 00:38:33 UTC 2006 i686 GNU/Linux I am using Debian Sarge (small cluster), which has been working excellent with OF1.3. I updated some packages from etch repository in order to install Qt4.3.2 correctly.Now, I need your help with ParaView3. Any hints from your side? Thanks al lot in advance. jcw |
No ideas? That's a pity. Pleas
No ideas? That's a pity. Please help, otherwise I can not use OF1.5, if I do not get ParaView running properly.
Thanks for your help. jcw |
Hi Christian!
Probably the
Hi Christian!
Probably the OpenGL-Headers are not installed on your system. Don't know in which package they'd be found on a Debian system (something like "mesa-*-devel") Bernhard |
Hi Christian,
as far as I kno
Hi Christian,
as far as I know the OpenGL packages for Debian are called xlibmesa-gl-dev and xlibmesa-glu-dev Install them with apt-get install xlibmesa-gl-dev Hope it helps Björn |
Hi Christian,
take a look at
Hi Christian,
take a look at http://packages.debian.org/lenny/paraview and compare if you have all necessary packages installed Build-Depends: cdbs , debhelper , autotools-dev, quilt , cmake , libqt4-dev , libopenmpi-dev, ffmpeg, libavformat-dev, libavutil-dev, libavcodec-dev, python-dev, chrpath, libglu1-mesa-dev, libxt-dev good luck elvis |
Hi all,
I ran into a slight
Hi all,
I ran into a slightly different problem when recompiling ParaView3.3 using "buildParaView3.3-cvs". It compiled fine, but when I start paraview, it tries to use "/usr/lib64/libstdc++.so.6" instead of the version in the gcc-4.3.1 shipped with OpenFOAM 1.5, even when I source the environment. Therefore, I get this error: "/usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.5' not found (required by [whatever paraview library requiring libstdc+.so.6])" When I recompile Paraview through "cmake, make, make install" with the right environment (manually set), everthing works fine. Platform: AMD x86_64 CentOS 5 (2.6.18-53.1.21.el5) Qt-4.3.5 Other things shipped with OpenFOAM 1.5 I can try to look into it more, but I need help with what "buildParaView" actually does (towards the end of "buildParaView3.3-cvs" -- sorry I am not too good with script-like things). Any suggestion is appreciated! Cheers, Ned |
Ned, i just got 32-bit OF1.5 w
Ned, i just got 32-bit OF1.5 working on Debian "etch" (well, i think it's working so far).
I had to rebuild paraview also. I found that I had to compile by hand 'flex' and make symbolic links to point flex to flex++ for the Allwmake to work properly. Rebuilding Paraview (follow the instructions to remove the paraview3.3-cvs) I copied all my qt4.3.5 files to /usr/lib, then had to install the python2.5 application. Then resumed the instructions to rebuild paraview, the final stage of the overall Allwmake. The BuildParaView function is basically a ./configure command and I sent all the output to a .txt file. Both CPUs ran at 100% during the build process. The clean up and ./allwmake process that followed were fairly short compared to the overall compilation of OF. |
Hi Ned,
I just got the same
Hi Ned,
I just got the same error ('GLIBCXX_3.4.5' not found) doing a rebuild on my OpenSuse10.2 machine. Found that paraview uses rpath as a link option and takes the system c++ libraries instad of using the LD_LIBRARY_PATH setting which would force it to use the OpenFOAM installed gcc-4.3.1 version. - if you already have a build: edit platforms/linuxXXXX/CMakeCache.txt and set VTK_USE_RPATH to off (VTK_USE_RPATH:BOOL=OFF) - or attached a revised bin/tools/buildParaViewFunctions which does that for you and rebuilds the whole thing http://www.cfd-online.com/OpenFOAM_D...s/mime_txt.gif buildParaViewFunctions |
Hi everyone,
Trying to inst
Hi everyone,
Trying to install OpenFOAM-1.5 and run into the same problem as Christian Wolf. When I did buildParaView3.3-cvs I get the error CMake Error: This project requires some variables to be set, and cmake can not find them. Please set the following variables: OPENGL_INCLUDE_DIR (ADVANCED) I run a 32-bit Fedora 9 system. Can anyone hint me how to install openGL, and/or whatever else is needed? Thanks in advance! |
I encounter some proble
I encounter some problems to compile Paraview. Following the README file, i get the error of Ned (July, 26) about GLIBCXX_3.4.9 (and not GLIBCXX_3.4.5). I have used the function buildParaviewFunctions given in the previous message of Mattijs Janssens but i still get the same error. Should i change something to this file seing that my error is about GLIBCXX_3.4.9 and not GLIBCXX_3.4.5 ? I have also tried to follow the advices of Ned (the same post) making cmake, make and make install. It seems to work, i don't have problems with GLIBCXX_3.4.9 anymore but later in the compilation i have an other error message saying that the 'class QString' has no member named 'toStdString'. Searching on the web, i found that it could be due to the fact that Qt is nor compiled with STL enable. However, desinstalling Qt 4.3.1 and recompiling it by ./configure -stl and then gmake does not work: In file included from shared/qdesigner_stackedbox.cpp:42: shared/orderdialog_p.h:76: error: 'Ui' has not been declared shared/orderdialog_p.h:76: error: ISO C++ forbids declaration of 'OrderDialog' with no type shared/orderdialog_p.h:76: error: expected ';' before 'ui' gmake[4]: *** [.obj/release-shared/qdesigner_stackedbox.o] Fehler 1 gmake[4]: Leaving directory `/net/ric_home/ep4/Desktop/qt-x11-opensource-src-4.3.1/tools/designer/src/lib' gmake[3]: *** [sub-lib-make_default-ordered] Fehler 2 gmake[3]: Leaving directory `/net/ric_home/ep4/Desktop/qt-x11-opensource-src-4.3.1/tools/designer/src' gmake[2]: *** [sub-src-make_default] Fehler 2 gmake[2]: Leaving directory `/net/ric_home/ep4/Desktop/qt-x11-opensource-src-4.3.1/tools/designer' gmake[1]: *** [sub-designer-make_default-ordered] Fehler 2 gmake[1]: Leaving directory `/net/ric_home/ep4/Desktop/qt-x11-opensource-src-4.3.1/tools' gmake: *** [sub-tools-make_default-ordered] Fehler 2 I would be very pleased to receive some advices. Thank you Eric |
finally, i compiled par
finally, i compiled paraview with buildParaview3.3-cvs, then cmake, make amd make install. I used the version Qt-4.4.3 by modifiying the CMakeList.txt. However i don't see anywhere a paraview application. The paraFoam command gives me the error: line 100: paraview: command not found Or ep4@wobwslx2:/net/ric_home/ep4$ type paraview bash: type: paraview: not found A check on my system gives me (after an updatedb): ep4@wobwslx2:/net/ric_home/ep4$ locate paraview /usr/local/lib/paraview-3.3 /usr/local/lib/paraview-3.3/ServerManager /usr/local/lib/paraview-3.3/ServerManager/Resources /usr/local/lib/paraview-3.3/ServerManager/Resources/utilities.xml /usr/local/lib/paraview-3.3/ServerManager/Resources/filters.xml /usr/local/lib/paraview-3.3/ServerManager/Resources/sources.xml /usr/local/lib/paraview-3.3/ServerManager/Resources/rendering.xml /usr/local/lib/paraview-3.3/ServerManager/Resources/writers.xml /usr/local/lib/paraview-3.3/ServerManager/Resources/readers.xml /usr/local/lib/paraview-3.3/doc /usr/local/lib/paraview-3.3/doc/verdict /usr/local/lib/paraview-3.3/doc/verdict/1.2.0 /usr/local/lib/paraview-3.3/doc/verdict/1.2.0/verdict_test.cpp /usr/local/lib/paraview-3.3/doc/verdict/1.2.0/Verdict.doc /usr/local/lib/paraview-3.3/doc/verdict/1.2.0/README /usr/local/lib/paraview-3.3/doc/verdict/1.2.0/Verdict.htm /usr/local/lib/paraview-3.3/libverdict.a /usr/local/include/paraview-3.3 /usr/local/include/paraview-3.3/vtkMINC.h /usr/local/include/paraview-3.3/verdict.h Does someone could help me to understand or resolve the problem? Thank you Eric |
Hi everybody,
i'am back wit
Hi everybody,
i'am back with the same problem. I had maybe suppressed a little bit too many lines in the CMakeLists.txt file. Deleting only the lines 94 to 96 i still get the same error but i receive the following message when using cmake: [root@wobwslx2 ThirdParty]# cmake ParaView3.3-cvs CMake Error: Qt 4.3.0 or greater not found. Please check the QT_QMAKE_EXECUTABLE variable. Qt was not found -- Configuring done I don't know why it says me that seing that i use the command PATH=/usr/local/Trolltech/Qt-4.4.3/bin:$PATH to indicate the version i want it uses (i also have a really old version). And i'am asking if this message could explain that i don't get any executable called paraview after the compilation. I really need help! Thank you in advance Eric |
