Question on specify gcc compiler for OpenFOAM 15
Old   October 1, 2008, 22:21
Default Hi All, I tried to install
zlai
peterlai is on a distinguished road
Hi All,
I tried to install OpenFOAM 1.5 from source on my CentOS operation system. Following the instructions in README, I added the OpenFOAM environment setting into my shell file and sourced it. But I noticed an warning message appears which means the proper gcc compiler for OpenFOAM is missing.
" Warning in /home/zlai/LZG/projects/OpenFOAM/OpenFOAM-1.5/etc/settings.sh:
Cannot find /home/zlai/LZG/projects/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux installation.
Please install this compiler version or if you wish to use the system compiler, change the WM_COMPILER_INST setting to 'System' in this file"
Now I have installed the GCC 4.3.1 into the ThirdParty folder with a folder name gcc-4.3.1. But I got confused with how to let the setting.sh file know this version of GCC I just installed.
It looks like the path to the compiler is pointing to the " .../gcc-4.3.1/platforms/linux". But I could not find it in the GCC 4.3.1 I installed.
Does anybody can help me with this? Thanks!
peterlai is offline   Reply With Quote
Old   October 2, 2008, 04:13
Default try move your OPENFOAM folder
lin
Hua Zen
lin is on a distinguished road
try move your OPENFOAM folder from
to
/home/zlai/OpenFOAM
lin is offline   Reply With Quote
Old   October 2, 2008, 07:20
Default No, I add a path in shell file
zlai
No, I add a path in shell file for the FOAM_INT_DIR as wrote in README, so it's OK for me to put the source file in "/home/zlai/LZG/projects/OpenFOAM", while the "PROJECT_USER_DIR" will be created in #HOME.
My question is how to let OpenFOAM 1.5 use the GCC 4.3.1 I have installed in ThirdParty folder. Actually, I know the following part of script in "setting.sh" is related to the compiler choose
"case "$WM_COMPILER_INST" in
OpenFOAM)
case "$WM_COMPILER" in
Gcc)
export WM_COMPILER_DIR=$WM_THIRD_PARTY_DIR/gcc-4.3.1/platforms/$WM_ARCH$WM_COMPILER_ARC H
Gcc42)
export WM_COMPILER_DIR=$WM_THIRD_PARTY_DIR/gcc-4.2.4/platforms/$WM_ARCH$WM_COMPILER_ARC H
esac
I just don't know how to modify the directory ".../gcc-4.3.1/platforms/$WM_ARCH$WM_COMPILER_ARCH" to be my one.
Thanks you for your suggestion.
[blockMesh] CheckMesh error using a tutorial from OpenFOAM 114 with openFOAM 13 martapajon OpenFOAM Meshing & Mesh Conversion 7 January 21, 2008 12:52
Compiler in OpenFoam gulp OpenFOAM Installation 4 October 27, 2007 11:36
OpenFOAM users in Munich OpenFOAM benutzer in M%c3%bcnchen jaswi OpenFOAM 0 August 3, 2007 13:11
OpenFOAM installation on AIX 53 with gnu 40 compiler chauvin OpenFOAM Installation 3 June 15, 2006 13:12
A new Howto on the OpenFOAM Wiki Compiling OpenFOAM under Unix mbeaudoin OpenFOAM Installation 2 April 28, 2006 08:54
