-   OpenFOAM Installation (http://www.cfd-online.com/Forums/openfoam-installation/)
-   -   Wmake ccm26ToFoam compilation problem under Ubuntu x64 810 (http://www.cfd-online.com/Forums/openfoam-installation/57304-wmake-ccm26tofoam-compilation-problem-under-ubuntu-x64-810-a.html)
kprzysowagmailcom October 5, 2008 07:09
I have problem with compiling
I have problem with compiling ccm26ToFoam under Ubuntu x64 8.10,
wmake ccm26ToFoam
SOURCE=ccm26ToFoam.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/kprzysowa/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/kprzysowa/OpenFOAM/OpenFOAM-1.5/src/meshTools/lnInclude -I/home/kprzysowa/OpenFOAM/ThirdParty/libccmio-2.6.1 -I/home/kprzysowa/OpenFOAM/ThirdParty/libccmio-2.6.1/lnInclude -IlnInclude -I. -I/home/kprzysowa/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/kprzysowa/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/ccm26ToFoam.o
In file included from /home/kprzysowa/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x 86_64-unknown-linux-gnu/4.3.1/include-fixed/syslimits.h:7,
from /home/kprzysowa/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x 86_64-unknown-linux-gnu/4.3.1/include-fixed/limits.h:11,
from /home/kprzysowa/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x 86_64-unknown-linux-gnu/4.3.1/../../../../include/c++/4.3.1/climits:48,
from /home/kprzysowa/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/label.H:38,
from /home/kprzysowa/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/labelList.H:36,
from /home/kprzysowa/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/ListOps.H:40,
from ccm26ToFoam.C:36:
/home/kprzysowa/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x 86_64-unknown-linux-gnu/4.3.1/include-fixed/limits.h:122:61: error: limits.h: No such file or directory
In file included from /home/kprzysowa/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x 86_64-unknown-linux-gnu/4.3.1/../../../../include/c++/4.3.1/x86_64-unknown-linux -gnu/bits/os_defines.h:44,
from /home/kprzysowa/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x 86_64-unknown-linux-gnu/4.3.1/../../../../include/c++/4.3.1/x86_64-unknown-linux -gnu/bits/c++config.h:40,
from /home/kprzysowa/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x 86_64-unknown-linux-gnu/4.3.1/../../../../include/c++/4.3.1/cstdlib:48,
from /home/kprzysowa/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/label.H:39,
/home/kprzysowa/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x 86_64-unknown-linux-gnu/4.3.1/include-fixed/features.h:331:25: error: sys/cdefs.h: No such file or directory
/home/kprzysowa/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x 86_64-unknown-linux-gnu/4.3.1/include-fixed/features.h:354:23: error: gnu/stubs.h: No such file or directory
in the specified location (/home/kprzysowa/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/lib/gcc/x86_64- unknown-linux-gnu/4.3.1/include-fixed) I have the limits.h file and the permissions (read/write) for it are given.
What does /../ mean?, I thought it was hidden part of the path but /platforms/linux64/bin/../lib/gcc/ in my system is /platforms/linux64/lib/gcc/. Should I have limits.h file in /platforms/linux64/bin/ location as well?
Please advise proper solution.
kprzysowagmailcom October 5, 2008 13:41
I have an update. I have manag
I have an update. I have managed to solve the problem by instlling:
build-essentials package for my system.
Unfortunately I have stacked again:
kprzysowa@larix:~/OpenFOAM/OpenFOAM-1.5/applications/utilities/mesh/conversion/Optional$ wmake ccm26ToFoam/
ccm26ToFoam.C:47:19: error: ccmio.h: No such file or directory
ccm26ToFoam.C:164: error: variable or field 'CheckError' declared void
ccm26ToFoam.C:164: error: 'CCMIOError' was not declared in this scope
ccm26ToFoam.C:164: error: expected primary-expression before 'const'
make: *** [Make/linux64GccDPOpt/ccm26ToFoam.o] Error 1
I have the ccmio.h file in:
/home/kprzysowa/OpenFOAM/ThirdParty/libccmio-2.6.1/libccmio
location.
I do not know why wmake doesn't "see" it.
Should I change any variable?
kprzysowagmailcom October 5, 2008 15:56
I have resolved the problem us
I have resolved the problem using the following post:
http://www.cfd-online.com/OpenFOAM_D...tml?1219661051
vishal October 11, 2008 08:05
hi people, I HAVE,A MODEL C
hi people,
I HAVE,A MODEL CREATED USING ccm+ 3.04 VERSION ....I MA TRYING TO IMPORT IT TO OPENFOAM BT PROBLEM IS I DIDNT FIND ANY ccm26ToFoam FOLDER IN UTEITIES/MESH/CONVERTION.... CAN ANY ONE PLEASE SEN ME THIN UTELITY FILE....
THANKS
VISHAL
kprzysowagmailcom October 11, 2008 14:52
it should be there: $HOME/Ope
it should be there:
$HOME/OpenFOAM/OpenFOAM-1.5/applications/utilities/mesh/conversion/Optional/ccm2 6ToFoam
vishal October 12, 2008 05:41
Hi, i checked it it but i d
i checked it it but i didnt get it....is there any other way to get it....can u please send ccm26tofoam folder to me....
Thanks
Vishal
vishal October 12, 2008 07:09
hi i put it there but it stll
hi i put it there but it stll says bad command.....i am using ccm 3.04 version ....do this makes any difference...and yes thanks for instant reply....actually in user guide also no infor mation is given about syntax for command...i tried folloeing syntax..
ccm26ToFoam Prism.ccm
isthis the right syntax...
Thanks
Vishal
kprzysowagmailcom November 6, 2009 05:33
You need to compile ccm26ToFoam
I am sorry I did not notice your replays.
ccm26ToFoam is not precompiled in default installation.
So you need to complile it first.
check 'wmake' keyword in user guide
