About FoamX
Old   September 19, 2008, 09:39
Default HI, I have installed OF1.4 on
weihong yao
ivanyao is on a distinguished road
HI,
I have installed OF1.4 on suse10.3,everything is ok!but when i type "FoamX",IT show:
ivan@linux-zctz:~> FoamX
Starting NameServer with inet:linux-zctz:1234 ...
Starting FoamX Host Browser with inet:linux-zctz:1234 ...
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : FoamXHostBrowser
Date : Sep 19 2008
Time : 21:30:13
Host : linux-zctz
PID : 16181
Root :
Case :
Nprocs : 1
HostBrowser running.....
Setting LANG to en_EN
Using jar /home/ivan/OpenFOAM/OpenFOAM-1.4/applications/utilities/preProcessing/FoamX/lib/ FoamX.jar
Using jar /home/ivan/OpenFOAM/OpenFOAM-1.4/applications/utilities/preProcessing/FoamX/lib/ jlfgr-1_0.jar
java: xcb_xlib.c:52: xcb_xlib_unlock: Assertion `c->xlib.lock' failed.
/home/ivan/OpenFOAM/OpenFOAM-1.4/bin/FoamX: line 247: 16185 give up $jdkhome/bin/java -cp "$jars" -DFoamX.SystemPath=$WM_PROJECT_DIR -DFoamX.SystemConfigPath=$FOAMX_CONFIG -DFoamX.UserConfigPath=$FOAMX_CONFIG FoamX.App $orbArgs $args
/home/ivan/OpenFOAM/OpenFOAM-1.4/bin/runFoamXHB: line 139: 16181 killed FoamXHostBrowser -ORBNamingAddr $myIOP
runFoamXHB : cleanup
runFoamXHB: Killing name server nsd(pid 16175).
/home/ivan/OpenFOAM/OpenFOAM-1.4/bin/runFoamXHB: line 66: 16175 killed nsd -ORBIIOPAddr $myIOP --ior $FOAMX_CONFIG/ns.ref < /dev/null
would someone tell me what's wrong?
ivanyao is offline   Reply With Quote
Old   September 19, 2008, 10:27
Default The current OpenFOAM version i
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
The current OpenFOAM version is 1.5 (with 1.5.x sources being available via git). FoamX has been dropped from newer versions, owning to precisely the java/corba annoyances like you've experienced.
Note that with the new dictionary expansion syntax, it is quite pleasant to edit the dictionary files.
olesen is offline   Reply With Quote
Old   September 21, 2008, 21:24
Default hi, i will try.thank you!
weihong yao
hi,
FoamX error derath OpenFOAM Pre-Processing 2 April 25, 2007 05:51
FoamX ianz8802 OpenFOAM Installation 2 March 8, 2007 23:45
FoamX does not start lucian OpenFOAM Installation 2 February 15, 2007 11:10
FoamX Issues tger003 OpenFOAM Pre-Processing 0 January 18, 2007 14:50
Run FoamX ghazi OpenFOAM Pre-Processing 7 July 9, 2006 14:48
