Hi - I've been fiddling with O
Hi - I've been fiddling with OpenFOAM the last couple of days but haven't been able to find an answer to my problem (pls. tell me what else to post to help you help me http://www.cfd-online.com/OpenFOAM_D...part/happy.gif :
System is uBuntu 7.10 - OpenFOAM 1.4.1 double precision When running the 'cavity case' with icoFoam, nothing happens after the text scrolls by. Ie. no cavity.foam file is created (blockMesh ran before that) Heres the last part when I run icoFoam . cavity: Time = 0.5 Courant Number mean: 0.116925 max: 0.852134 DILUPBiCG: Solving for Ux, Initial residual = 1.89493e-07, Final residual = 1.89493e-07, No Iterations 0 DILUPBiCG: Solving for Uy, Initial residual = 4.14522e-07, Final residual = 4.14522e-07, No Iterations 0 DICPCG: Solving for p, Initial residual = 1.06665e-06, Final residual = 3.39604e-07, No Iterations 1 time step continuity errors : sum local = 5.25344e-09, global = 1.23705e-18, cumulative = -4.08805e-18 DICPCG: Solving for p, Initial residual = 5.36118e-07, Final residual = 5.36118e-07, No Iterations 0 time step continuity errors : sum local = 6.86432e-09, global = 1.37312e-18, cumulative = -2.71493e-18 ExecutionTime = 0.27 s ClockTime = 19 s End claus@kafka:~/OpenFOAM/claus-1.4.1/run/tutorials/icoFoam$ ls cavity/ 0 0.1 0.2 0.3 0.4 0.5 constant system and the foamInstallationTest: Executing /home/claus/OpenFOAM/OpenFOAM-1.4.1/bin/foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: kafka OS: Linux version 2.6.22-14-generic User: claus User_config: /home/claus/.bashrc Foam_config: /home/claus/.OpenFOAM-1.4.1/bashrc sourced correctly. ------------------------------------------------------------------------------- Checking main FOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/claus/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/claus/OpenFOAM/claus-1.4.1 yes no $FOAM_JOB_DIR /home/claus/OpenFOAM/jobControl yes yes ------------------------------------------------------------------------------- Checking the FOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/claus/OpenFOAM/OpenFOAM-1.4.1 yes yes yes $FOAM_USER_APPBIN ...1.4.1/applications/bin/linuxGccDPOpt yes yes no $FOAM_APPBIN ...1.4.1/applications/bin/linuxGccDPOpt yes yes yes $WM_DIR .../claus/OpenFOAM/OpenFOAM-1.4.1/wmake yes yes yes $FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes $CEI_HOME /usr/local/ensight/CEI no no $JAVA_PATH /opt/OpenFOAM-1.4.1/j2sdk1.4.2_05 yes yes no $MICO_ARCH_PATH .../mico-2.3.12/platforms/linuxGccDPOpt yes yes yes $LAM_ARCH_PATH --------- env variable not set --------- yes $MPICH_ARCH_PATH --------- env variable not set --------- no ------------------------------------------------------------------------------- Checking the FOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...OAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt yes yes yes $FOAM_USER_LIBBIN ...enFOAM/claus-1.4.1/lib/linuxGccDPOpt yes yes no $LAM_ARCH_PATH --------- env variable not set --------- yes ------------------------------------------------------------------------------- Software versions ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc 4.1.3 WARNING: Conflicting installations: foam settings: /home/claus/OpenFOAM/linux/gcc-4.2.1/bin/gcc current path : /usr/bin/gcc CRITICAL ERROR java 1.4.2_05 /opt/OpenFOAM-1.4.1/j2sdk1.4.2_05/bin/java gzip 1.3.12 /bin/gzip tar 1.3.12 /bin/tar icoFoam .../OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/icoFoam ------------------------------------------------------------------------------- Checking file/directory permissions... ------------------------------------------------------------------------------- File/directory Set Reqd Crit ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_kafka Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Successful yes (*) Only one of rsh or ssh is required by the Foam enviroment. ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 1 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. thx http://www.cfd-online.com/OpenFOAM_D...part/happy.gif |
It seems that the solver ran p
It seems that the solver ran properly and produced the time directories: 0.1 0.2....0.5
To see the results type: paraFoam ./ cavityin the icoFoam directory. Indeed there is an error with your installation. Type: ls /home/claus/OpenFOAM/linux/gcc-4.2.1If you don't have it, then you did not install the gcc compiler. Dragos |
Hi - thanks for responding htt
Hi - thanks for responding http://www.cfd-online.com/OpenFOAM_D...part/happy.gif
This is the console-output I get when running claus@kafka:~/OpenFOAM/claus-1.4.1/run/tutorials/icoFoam$ paraFoam ./ cavity ErrorMessage # Error or warning: There was a VTK Error in file: /home/dm2/henry/OpenFOAM/linuxSrc/paraview-2.4.4/GUI/Client/vtkPVWindow.cxx (2366) vtkPVWindow (0x829b8a8): Cannot read file information when no reader is specified. This probably means that the reader for the file with name: /home/claus/OpenFOAM/claus-1.4.1/run/tutorials/icoFoam/cavity/cavity.foam cannot be found ErrorMessage end ErrorMessage # Error or warning: There was a VTK Error in file: /home/dm2/henry/OpenFOAM/linuxSrc/paraview-2.4.4/GUI/Widgets/vtkKWApplication.cx x (1335) vtkPVApplication (0x8114518): Script: paraFoam.pvs Returned Error on line 11: invalid command name "" ErrorMessage end cavity.foam never gets created it seems. About gcc - shouldn't the gcc installed on my system be good enough? it is correctly located in /usr/bin/gcc I cannot understand why a simple 'icoFoam . cavity' does not produce the files mentioned in the tutorial. Thx http://www.cfd-online.com/OpenFOAM_D...part/happy.gif EDIT ! just tried the steps again before posting. Now it seems that a cavity.foam file is created, but it is empty and produces the error stated above - so still no go |
Did you install any third part
Did you install any third party software (paraview, java and gcc)?
I ask because now I see you have java somewhere else too! If you don't recompile anything, than you don't need the compiler. However, if you will do anything more than just tutorials, then it's most likely that you will need to modify slightly some of the solvers/utilities. In that case you have to use the compiler that comes with OpenFOAM (one of the reasons is that it is newer than the one in your linux distribution). Now I'm curious if you have installed paraview...? paraFoam is just a script that uses paraview to print results, so if you didn't install it, no wonder it doesn't run. Dragos |
well i DID install paraview -
well i DID install paraview - but im not sure I did it the right way - I extracted it in /opt/OpenFOAM-1.4.1/paraview-2.4.4 and linked the executable to /usr/local/bin along with the libs and 'include' -- paraview starts up fine with 'paraview' in a console and paraFoam succeeds in calling paraview (as the error-message states) but maybe thats not the way to do it?
But can't we agree that 'icoFoam . cavity' should create a cavity.foam file containing something? http://www.cfd-online.com/OpenFOAM_D...part/happy.gif |
Hi Claus,
No icoFoam . cavity
Hi Claus,
No icoFoam . cavity doesn't create the cavity.foam file. This is created by the paraFoam utility (I think...). I also think you have to install paraview in ~/OpenFOAM/linux/paraview-2.4.4, otherwise it will not be found. Please follow the instructions from the OpenFOAM download webpage. They are very simple, and you don't have to create any symbolic links. Dragos |
hah! that did it! http://www.c
hah! that did it! http://www.cfd-online.com/OpenFOAM_D...part/happy.gif
I looked at 'paraFoam' and it is indeed 'paraFoam' that creates cavity.foam ------------------- touch $caseName.foam paraview paraFoam.pvs rm paraFoam.pvs $caseName.foam 2>/dev/null ------------------- Well I guess Im ready to get overwhelmed by OpenFOAM by now - I'll return with other questions in the forum http://www.cfd-online.com/OpenFOAM_D...part/happy.gif thx for the help! http://www.cfd-online.com/OpenFOAM_D...part/happy.gif |
Gentlemen:
I am having the
Gentlemen:
I am having the following problem with paraView. In the documentation for the cavity tutorial, I am trying to follow the instructions for plotting a graph. On page U-35, approx 4th paragraph, we are asked to select "scatter plot", from the Plot Type menu in the Display panel. I dont see Plot Type in the display panel. Has anyone faced the same problem? I am running Paraview 3.3.0 on Suse 11.0 Thanks Musa |
