I am trying to insta
I am trying to install ParaView3.3 as per the latest instructions. When I launch the "buildParaView3.3-cvs" command I get the following errors: "CMake Error: Qt 4.3.0 or greater not found. Please check the QT_QMAKE_EXECUTABLE variable" then a little later on I get "Qt was not found" Now I have downloaded the qt version 4.3.1 source code ( I am running SUSE10.3) and have installed it. Seemingly without problems. it now resides in /usr/local/Trolltech/ My question is: How do I check to make sure the qt installation was genuinely succesful? Why can't cmake find it? where do I find this QT_QMAKE_EXECUTABLE to point it to the right place Thank you |
Hello again,
I have now res
Hello again,
I have now resolved that problem but I am stuck further down the line. See next post. thanks JB |
Hi Jim!
I'm facin the same pr
Hi Jim!
I'm facin the same problem with Qt4. Can you explain me how did you resolve this problem? Thank you so much! |
| All times are GMT -4. The time now is 06:24. |
