Hallo all,
I have some proble
Hallo all,
I have some problems with compilation of OF1.4. It seems to be problem in new STL. Here is the top most error: + wmake libso triSurface SOURCE=triSurface/interfaces/STL/readSTLASCII.L ; flex++ -f $SOURCE ; mv lex.yy.cc Make/linuxGcc4DPDebug/readSTLASCII.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O0 -fdefault-inline -ggdb3 -DFULLDEBUG -DNoRepository -ftemplate-depth-40 -IlnInclude -I. -I/home/rafal/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude -fPIC -pthread -c Make/linuxGcc4DPDebug/readSTLASCII.C -o Make/linuxGcc4DPDebug/readSTLASCII.o In file included from /usr/lib/gcc/i686-pc-linux-gnu/4.1.1/include/g++-v4/backward/iostream.h:31, from /usr/local/include/FlexLexer.h:47, from Make/linuxGcc4DPDebug/readSTLASCII.C:234: /usr/lib/gcc/i686-pc-linux-gnu/4.1.1/include/g++-v4/backward/backward_warning.h: 32:2: warning: #warning This file includes at least one deprecated or antiquated header. Please consider using one of the 32 headers found in section 17.4.1.2 of the C++ standard. Examples include substituting the <x> header for the <x.h> header for C++ includes, or <iostream> instead of the deprecated header <iostream.h>. To disable this warning use -Wno-deprecated. /usr/lib/gcc/i686-pc-linux-gnu/4.1.1/include/g++-v4/backward/iostream.h:36: error: 'istream' is already declared in this scope lex.yy.cc: In member function 'virtual int yyFlexLexer::yylex()': lex.yy.cc:5816: warning: use of old-style cast lex.yy.cc:5816: warning: use of old-style cast lex.yy.cc:5832: warning: use of old-style cast lex.yy.cc:6003: warning: use of old-style cast lex.yy.cc:6021: error: cannot convert 'std::istream*' to 'istream*' in assignment lex.yy.cc: In member function 'int yyFlexLexer::yy_get_next_buffer()': lex.yy.cc:6252: warning: use of old-style cast lex.yy.cc:6279: warning: use of old-style cast lex.yy.cc:6292: warning: use of old-style cast lex.yy.cc:6293: warning: use of old-style cast lex.yy.cc:6314: warning: use of old-style cast lex.yy.cc: In member function 'yy_state_type yyFlexLexer::yy_get_previous_state()': lex.yy.cc:6362: warning: use of old-style cast lex.yy.cc:6362: warning: use of old-style cast lex.yy.cc: In member function 'void yyFlexLexer::yyunput(int, char*)': lex.yy.cc:6423: warning: use of old-style cast lex.yy.cc:6424: warning: use of old-style cast lex.yy.cc:6432: warning: use of old-style cast lex.yy.cc: In member function 'int yyFlexLexer::yyinput()': lex.yy.cc:6501: warning: use of old-style cast lex.yy.cc: In member function 'void yyFlexLexer::yy_load_buffer_state()': lex.yy.cc:6549: error: cannot convert 'istream*' to 'std::istream*' in assignment lex.yy.cc: In member function 'virtual yy_buffer_state* yyFlexLexer::yy_create_buffer(std::istream*, int)': lex.yy.cc:6558: warning: use of old-style cast lex.yy.cc:6567: warning: use of old-style cast lex.yy.cc: In member function 'virtual void yyFlexLexer::yy_delete_buffer(yy_buffer_state*)': lex.yy.cc:6585: warning: use of old-style cast lex.yy.cc:6588: warning: use of old-style cast lex.yy.cc:6590: warning: use of old-style cast lex.yy.cc: In member function 'void yyFlexLexer::yy_init_buffer(yy_buffer_state*, std::istream*)': lex.yy.cc:6600: error: cannot convert 'std::istream*' to 'istream*' in assignment lex.yy.cc: In member function 'void yyFlexLexer::yy_push_state(int)': lex.yy.cc:6654: warning: use of old-style cast lex.yy.cc:6658: warning: use of old-style cast lex.yy.cc:6658: warning: use of old-style cast lex.yy.cc: In function 'void* yy_flex_alloc(yy_size_t)': lex.yy.cc:6760: warning: use of old-style cast lex.yy.cc: In function 'void* yy_flex_realloc(void*, yy_size_t)': lex.yy.cc:6778: warning: use of old-style cast lex.yy.cc:6778: warning: use of old-style cast lex.yy.cc: At global scope: lex.yy.cc:5637: warning: 'yy_start_stack_ptr' defined but not used lex.yy.cc:5638: warning: 'yy_start_stack_depth' defined but not used lex.yy.cc:5639: warning: 'yy_start_stack' defined but not used lex.yy.cc:5641: warning: 'void yy_push_state(int)' declared 'static' but never defined lex.yy.cc:5644: warning: 'void yy_pop_state()' declared 'static' but never defined lex.yy.cc:5647: warning: 'int yy_top_state()' declared 'static' but never defined make: *** [Make/linuxGcc4DPDebug/readSTLASCII.o] Error 1 Additional info: - I used patch for OpenFOAM-1.4/src/triSurface/triSurface/interfaces/STL/readSTLASCII.L http://www.cfd-online.com/cgi-bin/Op...w.cgi?126/4189 - OF-1.3 compiles smoothly - I use gcc411 not 412 (but assume it doent matter) - Gentoo box (possibly all debian branch also affected with this error) It seems to be another namespace conflict, but i dont know how to correct it Please help. Any hint appreciated. rafal |
I've seen the same thing on my
I've seen the same thing on my SuSe-10.1 and ended up re-introducing foamFlex++ we had in previous versions. This was patched up to sort out similar problem with the standard flex (which does not seem to be developed any more) and it fixed my stuff.
Not sure if this will remain - still investigating in the light of Martin's RedHat suggestions. Hrv |
Hi Hrv,
Thanks for hint. I
Hi Hrv,
Thanks for hint. I will try to still foamFlex from OF1.3 and come back in case of problems. thanks rafal (BTW I didnt see anywhere information removing foamFlex, but it is missing from utils) |
Hi Hrv,
Thanks for the tip. I
Hi Hrv,
Thanks for the tip. It works. It compiles. Here is rough howto in case someone has the same problem like me: * copy ~/OpenFOAM/OpenFOAM-1.3/applications/utilities/miscellaneous/foamFlex to ~/OpenFOAM/OpenFOAM-1.4/applications/utilities/miscellaneous * add the following lines in ~/OpenFOAM/OpenFOAM-1.3/src/Allmake: cd $FOAM_APP/utilities/miscellaneous wmake exe foamFlex cp foamFlex/FlexLexer.h $FOAM_SRC/OpenFOAM/lnInclude cd $FOAM_SRC before the line (cd Pstream ; ./Allwmake) * make wmake to use foamFlex++ instead of flex++: in ~/OpenFOAM/OpenFOAM-1.4/wmake/rules/General the following files: flex++ and flex++.test change: flex++ to: foamFles++ Hope that helps to someone. Now i still do not run OF14 i hit some runtime error which I am still trying to solve. rafal PS. Now i appreciate extensive path settings in OF I can compile one version and work on the other Once again I have to say about OF - Great Piece of Code http://www.cfd-online.com/OpenFOAM_D...part/happy.gif |
I also have some proble
I also have some problems compiling 1.4.1-dev on Redhat. (64 Bits). I get the following error message: + wmake libso triSurface triSurface/interfaces/STL/readSTLASCII.L:56: error: previous declaration of `int yywrap()' with C++ linkage lex.yy.cc:5288: error: conflicts with new declaration with C linkage lex.yy.cc: In member function `int STLLexer::lex()': lex.yy.cc:5488: warning: use of old-style cast lex.yy.cc:5488: warning: use of old-style cast lex.yy.cc:5504: warning: use of old-style cast lex.yy.cc:5718: warning: use of old-style cast triSurface/interfaces/STL/readSTLASCII.L:205: warning: unused variable 'endPtr' lex.yy.cc: In member function `int yyFlexLexer::yy_get_next_buffer()': lex.yy.cc:5967: warning: use of old-style cast lex.yy.cc:5994: warning: use of old-style cast lex.yy.cc:6007: warning: use of old-style cast lex.yy.cc:6008: warning: use of old-style cast lex.yy.cc:6029: warning: use of old-style cast lex.yy.cc: In member function `yy_state_type yyFlexLexer::yy_get_previous_state()': lex.yy.cc:6077: warning: use of old-style cast lex.yy.cc:6077: warning: use of old-style cast lex.yy.cc: In member function `void yyFlexLexer::yyunput(int, char*)': lex.yy.cc:6138: warning: use of old-style cast lex.yy.cc:6139: warning: use of old-style cast lex.yy.cc:6147: warning: use of old-style cast lex.yy.cc: In member function `int yyFlexLexer::yyinput()': lex.yy.cc:6216: warning: use of old-style cast lex.yy.cc: In member function `virtual yy_buffer_state* yyFlexLexer::yy_create_buffer(std::istream*, int)': lex.yy.cc:6272: warning: use of old-style cast lex.yy.cc:6281: warning: use of old-style cast lex.yy.cc: In member function `virtual void yyFlexLexer::yy_delete_buffer(yy_buffer_state*)': lex.yy.cc:6299: warning: use of old-style cast lex.yy.cc:6302: warning: use of old-style cast lex.yy.cc:6304: warning: use of old-style cast lex.yy.cc: In member function `void yyFlexLexer::yy_push_state(int)': lex.yy.cc:6367: warning: use of old-style cast lex.yy.cc:6371: warning: use of old-style cast lex.yy.cc:6371: warning: use of old-style cast lex.yy.cc: In function `void* yy_flex_alloc(yy_size_t)': lex.yy.cc:6473: warning: use of old-style cast lex.yy.cc: In function `void* yy_flex_realloc(void*, yy_size_t)': lex.yy.cc:6491: warning: use of old-style cast lex.yy.cc:6491: warning: use of old-style cast lex.yy.cc: At global scope: lex.yy.cc:5307: warning: 'yy_start_stack_ptr' defined but not used lex.yy.cc:5308: warning: 'yy_start_stack_depth' defined but not used lex.yy.cc:5309: warning: 'yy_start_stack' defined but not used lex.yy.cc:5311: warning: 'void yy_push_state(int)' declared `static' but never defined lex.yy.cc:5314: warning: 'void yy_pop_state()' declared `static' but never defined lex.yy.cc:5317: warning: 'int yy_top_state()' declared `static' but never defined I uncommented the yywrap function in the corresponding .L file, but this gives troubles in the compiling proccess later on (as to be expected). Did anybody have the same troubles? The flex++ version is 2.5.4 |
sorry, I found a related topic
sorry, I found a related topic at
http://www.cfd-online.com/OpenFOAM_D...tml?1217020603 I replaced "int yywrap()" with "extern "C" int yywrap()" the compilation is continuing... |
