June 27, 2011, 01:33 |
[SOLVED] MPI (installation) bugs in 1.6.x
Andrew King
Rep Power: 17 |
I'm trying to install OpenFOAM-1.6-ext in debian, however I've had troubles with the ThirdParty stuff. (Note that OF-1.6.x/OF1.7.x/OF-2.0.x are all installed fine). In particular, I've needed to "patch" scotch to find the system mpi libraries. ie. during compilation (ie. CTRL-Z, patch, fg) I've had to change Code:
CCD = gcc -I$(MPI_HOME)/include Code:
CCD = gcc -I$(MPI_HOME)/include $(OPENMPI_COMPILE_FLAGS otherwise mpi.h is not found. Metis, as linked to in the current version is also missing (404) Code:
Download metis-5.0pre2.tar.gz from : http://glaros.dtc.umn.edu/gkhome/fetch/sw/metis/metis-5.0pre2.tar.gz --2011-06-27 13:22:26-- http://glaros.dtc.umn.edu/gkhome/fetch/sw/metis/metis-5.0pre2.tar.gz Resolving glaros.dtc.umn.edu... 160.94.77.162 Connecting to glaros.dtc.umn.edu|160.94.77.162|:80... connected. HTTP request sent, awaiting response... 404 Not Found 2011-06-27 13:22:27 ERROR 404: Not Found. Regards, Andrew
Dr Andrew King Fluid Dynamics Research Group Curtin University |
Windows 64-bit with Native MPI patch for OpenFOAM 1.6.x | gocarts | OpenFOAM Announcements from Other Sources | 4 | October 4, 2010 08:56 |
OF 1.6.x installation, Suse 11.2, ParaView Segementation fault | peterwy | OpenFOAM Installation | 14 | June 8, 2010 18:22 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Error using LaunderGibsonRSTM on SGI ALTIX 4700 | jaswi | OpenFOAM | 2 | April 29, 2008 10:54 |
Is Testsuite on the way or not | lakeat | OpenFOAM Installation | 6 | April 28, 2008 11:12 |
