Hi everyone,
I am using OF-
Hi everyone,
I am using OF-1.3 and my OS is ubuntu 7.10. the OF-1.3 in my machine is working perfectly. To use the FSI solver(icoFsiFoam), I download OpenFOAM-1.3_11092006 and extract it in the ~/OpenFOAM to replace the one used before(which is from OpenFOAM-1.3.General). At this moment, I can still compile the icoFsiFoam solver but I can not run a case for it as I need to rebuild everything(I find this method on the discussions about the balloon case),so I use ./AllMake in the main directory to build everything(there is no error in this process). at the moment the re-build is done, I type "which g++" in the terminal, it is the one provided by OF, but when I close the terminal and re-open it, then again, I type"which g++", I get:/usr/bin/g++, and when I try to compile the modified icoFsiFoam solver, I get one error: /usr/bin/ld: cannot find -liberty I have read some posts in the board, and realise that if "which g++" give you the one provided by OpenFoam, this error will not appear. so the problem confusing me is that why the enviroment variable is changed after I just replace the orginal OpenFOAM 1.3 directory and rebuild everything and I can not use the g++(or gcc) provided by OF To find a way around it, I try to follow the buildinstructions in the website for an OF-dev, but I run into some problems: (1) now I do not need run OF in paralle, do I need to install everything recommended in the website (2) when I try to use "gmake", I was told this commond is not found, but intead I use "make", is that right? (3) when I try to type "make install", I was told somthing like "permission denied when creat directory ...usr/tmp.....". I am just getting started with OF and Linux,and some questions may sound very stupid, Could anyone pleae give me some hints on how to use/build the OpenFOAM-1.3_11092006 correctly I will really appreciate your help! jin |
My machine is 32 bit
regard
regards |
Hi Jin!
I think it is written
Hi Jin!
I think it is written somewhere else on the Board: libiberty.a is provided by some rather "esoteric" packages on some distros and therefor not always present. On my machines (RHEL/CentOS 5.x) it is provided by binutils-devel. On these distros I find out who provides this with the command "yum provides libiberty". What the equivalent command on Ubuntu would be: I don't know Bernhard |
In Ubuntu it is:
apt-cache
In Ubuntu it is:
apt-cache search libiberty It gives nothing in my Kubuntu 7.10 Regards Paulo |
I've read all the messages and
I've read all the messages and now foud the result of:
paulo@SEM:~$ apt-cache search liberty liblasso-java - Liberty ID-FF library - Java bindings liblasso3 - Liberty ID-FF library - runtime library liblasso3-dev - Liberty ID-FF library - development kit python-lasso - Liberty ID-FF library - Python bindings So maybe installing the liblasso3 package helps. Regards Paulo |
Hi Paulo
I fix this problem
Hi Paulo
I fix this problem by installing binutils-devel. Kind regards feng |
yes that worked in ubuntu 10.04 too, when I was intalling OpenFOAM-1.7.0
when I did $ ./Allwmake /usr/bin/ld: cannot find -liberty collect2: ld returned 1 exit status .... ... I installed $ sudo apt-get install binutils-dev that solved my problem ...and I was able to compile thank you dinesh IIT Kanpur |
