Trisurface compilation error
Old   April 27, 2008, 22:50
Default I have got the following error
Nishant
nishant_hull is on a distinguished road
I have got the following error while recompiling using wmake in trisurface directory:
SOURCE=triSurface/interfaces/STL/readSTL.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IlnInclude -I. -I/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/readSTL.o
SOURCE=triSurface/interfaces/STL/readSTLASCII.L ; flex++ -f $SOURCE ; mv lex.yy.cc Make/linuxGccDPOpt/readSTLASCII.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IlnInclude -I. -I/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -pthread -c Make/linuxGccDPOpt/readSTLASCII.C -o Make/linuxGccDPOpt/readSTLASCII.o
/bin/sh: flex++: command not found
mv: cannot stat `lex.yy.cc': No such file or directory
g++: Make/linuxGccDPOpt/readSTLASCII.C: No such file or directory
g++: no input files
make: *** [Make/linuxGccDPOpt/readSTLASCII.o] Error 1
Similar error is coming when I am compiling finiteVolume directory of the source. Can anybody comment?
regards,
nishant
Thanks and regards,
Nishant
nishant_hull is offline   Reply With Quote
Old   April 28, 2008, 02:26
Default Hello Nishant, I think your p
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hello Nishant,
I think your problem (/bin/sh: flex++: command not found) is encountered very frequently on this forum. The answer is always the same:
install flex++
Dragos
dmoroian is offline   Reply With Quote
Old   April 28, 2008, 11:34
Default Thanks Dragos, In fact I h
Nishant
Thanks Dragos,
In fact I have flex++ already installed. I can see this at /usr/bin/flex++
[343880@w191-210 Desktop]$ whereis flex++
flex++: /usr/bin/flex++ /usr/share/man/man1/flex++.1.gz
Do I need to make any link for flex++ to some other location? Please suggest.
Nishant
Thanks and regards,
Nishant
Old   May 29, 2008, 04:10
Default Hi Nishant, Did you solve t
mss
Hi Nishant,
Did you solve the problem with flex++
Best regards,
Rita
UDF compilation error Hari FLUENT 0 February 22, 2008 13:40
Compilation error skabilan OpenFOAM Installation 1 September 17, 2007 13:33
Compilation error CFX 11 Beth CFX 0 July 26, 2007 19:36
Compilation error Karthick FLUENT 5 April 16, 2004 13:36
compilation error M.A. Rakib FLUENT 5 June 21, 2000 10:28
