FoamX Libelfso ELF file data encoding not littleendian |
April 10, 2008, 16:03 |
Hello Everybody,
i just ins
Ralf Häßler
Rep Power: 17 |
Hello Everybody,
i just installed OpenFOAM 1.4.1 under Suse Linux 10.3 64 bit running a bash shell. 'foamInstallationTest' produces no errors. Following the installation README worked perfect and also the icofoam tutorial (Blockmesh...) worked well. However i cannot get FoamX to start: ralf@Bollerhannes:~> FoamX & [1] 4642 ralf@Bollerhannes:~> Starting NameServer with inet:Bollerhannes:1234 ... nsd: error while loading shared libraries: /usr/lib64/libelf.so.0: ELF file data encoding not little-endian I have to manually kill -9 it as otherwise it won't stop. My libelf-version is: /usr/lib64/libelf.so.0 -> libelf.so.0.8.9 /usr/lib64/libelf.so.0.8.9 Is it too new/old? Is it the 32 Bit Version (i downloaded the latest 64 Bit version). Any hint is appreciated. The kindest regards, Ralf |
May 5, 2008, 16:35 |
Folks, i have found a later or
Ralf Häßler
Rep Power: 17 |
Folks, i have found a later or older version of libelf, compiled it, linked it to libelf.so.0 and guess what...?
Yessss it does start, however i get a new error message, hopefully not linked to my tweaking libelf: ralf@Bollerhannes:~> FoamX Starting NameServer with inet:Bollerhannes:1234 ... Starting FoamX Host Browser with inet:Bollerhannes:1234 ... /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.4.1 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : FoamXHostBrowser Date : May 05 2008 Time : 21:37:44 Host : Bollerhannes PID : 5027 Root : Case : Nprocs : 1 HostBrowser running..... Setting LANG to en_EN Using jar /home/ralf/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/preProcessing/FoamX/li b/FoamX.jar Using jar /home/ralf/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/preProcessing/FoamX/li b/jlfgr-1_0.jar java: xcb_xlib.c:52: xcb_xlib_unlock: Assertion `c->xlib.lock' failed. /home/ralf/OpenFOAM/OpenFOAM-1.4.1/bin/FoamX: line 244: 5035 Abgebrochen $jdkhome/bin/java -cp "$jars" -DFoamX.SystemPath=$WM_PROJECT_DIR -DFoamX.SystemConfigPath=$FOAMX_CONFIG -DFoamX.UserConfigPath=$FOAMX_CONFIG FoamX.App $orbArgs $args /home/ralf/OpenFOAM/OpenFOAM-1.4.1/bin/runFoamXHB: line 139: 5027 Getötet FoamXHostBrowser -ORBNamingAddr $myIOP runFoamXHB : cleanup runFoamXHB: Killing name server nsd(pid 5020). /home/ralf/OpenFOAM/OpenFOAM-1.4.1/bin/runFoamXHB: line 66: 5020 Getötet nsd -ORBIIOPAddr $myIOP --ior $FOAMX_CONFIG/ns.ref < /dev/null As you may notice, there are some german phrases in between, 'getötet' means 'killed', 'abgebrochen' means 'stopped'. As i mentioned before, everything else works fine, paraview is great and so on. I think i did not tweak my OS in any way. Has anyone done this with Suse 10.3 64 Bit before? Shall i rather get an older one? Thanks in advance, regards, Ralf |
May 24, 2008, 18:06 |
No response at all and i am a
Ralf Häßler
Rep Power: 17 |
No response at all and i am a little surprised.
Googling the error message above brought me to a workaround: export LIBXCB_ALLOW_SLOPPY_LOCK=1 before starting FoamX somehow helped (don't ask why). I copied the line to the FoamX-Script. That should do. Regards, Ralf |
PLOT3D ASCII solution file to MATLAB data file | Sandeep Rana | Main CFD Forum | 4 | June 11, 2010 09:48 |
FoamX error shared object file not found | mdmk | OpenFOAM Pre-Processing | 2 | June 22, 2008 05:19 |
FoamX save case file problem | rchenglong | OpenFOAM Pre-Processing | 0 | September 26, 2007 20:40 |
Creating data file | Kevin | CFX | 3 | September 8, 2004 22:47 |
Data file format | ales | FLUENT | 2 | March 2, 2001 20:46 |
