Hi People,
I am a newb to
Hi People,
I am a newb to linux/openfoam and hope can get some help here. I just installed puppy 4 as the linux and installed OpenFOAM 1.4.1 according to the online guideline. However, when i typed FoamX, it says error "nsd"command not found with the FoamXHB(?) file at line 130, when i go to open and read the file, it s basically a line started with "nsd" command. is there any suggestion to fix this? also, i tried to follow the online step by step guide to run the dailyPitz but when it comes to blockMesh.cavity, it says command not found/no such command. I understand that it might be better to use command rather than FoamX but I would really like to start with FoamX and at least go through the tutorials. any help/suggestion is welcomed. cheers |
Hi Lawrence, and welcome.
Fir
First try to run icoFoam, and type: icoFoam If it prints "command not found" than it means you did not configure the environment. Do you have in your ~/.bashrc a line saying: . ~/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/bashrc ? Dragos |
Hi Dragos,
thanks for your q
Hi Dragos,
thanks for your quick reply. Sorry as i am really a newbie here, do u mean i first go into # cd ~/OpenFoam/OpenFoam-1.4.1/tutorials then type # icoFoam if so, it says command not found and as you said, i did not configure the environment.( can u provide some help on how to configure then?) for the second part, do u mean i should just #~/.bashrc and see what it says?nothing come out for the above command at the moment please bear with mi with great patience, truly appreciated. Lawrence |
hi, this is what i did,
# c
# chmod -v 555 foamSystemCheck then #["export PATH=$PATH:~/OpenFOAM/OpenFOAM-1.4.1/bin/"] it returned bash:[export PATH=/bin:/usr/bin:/sbin:/usr...usr/local/bin:/usr/X11R7/bin:/root/my-applicatio ns/bin:/opt/samba/bin:~/OpenFOAM/OpenFOAM-1.4.1/bin/]: No such file or directory i suspect the path is wrong? but how should i correct/change it? help pls.. Thanks Lawrence |
Lawrence, could you do pwd in
Lawrence, could you do pwd in the directory where foamSystemCheck is located? Are you running 32 or 64 bit linux?
Hi Lawrence,
It seems that yo
Hi Lawrence,
It seems that you need more help, so if you want drop me an e-mail and I will try to provide you with the information. Dragos |
