April 9, 2008, 08:03 |
I run OpenFoam on Suse
bjoern flieger
I run OpenFoam on Suse 10 (x86_64). When I run simpleFoam in single precision option everything works fine. When want to I run it in double precision option I get the error message: simpleFoam: symbol lookup error: simpleFoam: undefined symbol: _ZN4Foam13fvsPatchFieldIdE25pathConstructorTablePt r_E Similar problem: with DPO FoamX can not connect to the CaseServer. with SPO it can do so. What can be the reson for that? Is there any difference in linking libraries between single and double? Thanks for any help! bjoern |
April 9, 2008, 12:21 |
It seems that the application
Francesco Del Citto
Rep Power: 18 |
It seems that the application is linking a wrong version of some shared library.
Try to load the DP environment in a new shell. It usually helps! |
OpenFOAM Double precision vs Single Precision | alexandrepereira | OpenFOAM Running, Solving & CFD | 1 | June 11, 2008 14:30 |
SI combustion precision? | glenn | Siemens | 0 | April 13, 2007 01:26 |
Variable precision | Felix | CFX | 7 | February 27, 2007 17:53 |
how to use double precision ? | lenson | Siemens | 8 | August 25, 2006 10:15 |
Double Precision | Wu | Siemens | 5 | May 10, 2002 13:20 |
