-   OpenFOAM Installation (http://www.cfd-online.com/Forums/openfoam-installation/)
-   -   Installation problems (http://www.cfd-online.com/Forums/openfoam-installation/57409-installation-problems.html)
indy April 5, 2008 15:02
Dear all, I am quite new to
Dear all,
I am quite new to OF and am experiencing some problems with the installation:
I have unpacked the source & binaries and installed in
/home/indy/OpenFOAM
I changed the .bashrc in the home/indy folder and it looks as it is sourced correctly.
However, when I run the foamInstallation test I get the following:
Executing ./foamInstallationTest:
Checking basic setup...
Shell: bash
Host: dhcppc1
OS: Linux version 2.6.22.5-31-default
User: indy
User_config: /home/indy/.bashrc
Foam_config: /home/indy/.OpenFOAM-1.4.1/bashrc sourced correctly.
FATAL ERROR Foam install directory not set.
Set correct path to installation 'WM_PROJECT_INST_DIR' in /home/indy/.foam2.3/bashrc
Checking main FOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR --------- env variable not set --------- yes
$WM_PROJECT_USER_DIR --------- env variable not set --------- no
$FOAM_JOB_DIR --------- env variable not set --------- yes
Checking the FOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR --------- env variable not set --------- yes
$FOAM_USER_APPBIN --------- env variable not set --------- no
$FOAM_APPBIN --------- env variable not set --------- yes
$WM_DIR --------- env variable not set --------- yes
$FOAMX_PATH --------- env variable not set --------- yes
$CEI_HOME --------- env variable not set --------- no
$JAVA_PATH --------- env variable not set --------- no
$MICO_ARCH_PATH --------- env variable not set --------- yes
$LAM_ARCH_PATH --------- env variable not set --------- yes
$MPICH_ARCH_PATH --------- env variable not set --------- no
Checking the FOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN --------- env variable not set --------- yes
$FOAM_USER_LIBBIN --------- env variable not set --------- no
Software versions
Software Version Location
gcc ...figure
WARNING: Conflicting installations:
foam settings: /bin/gcc
current path : /usr/bin/gcc
CRITICAL ERROR
java 1.5.0_12
foam settings: /usr/lib64/jvm/jre/bin/java
current path : /usr/bin/java
gzip 1.3.12 /usr/bin/gzip
tar 1.3.12 /bin/tar
icoFoam *** not installed ***
CRITICAL ERROR
Checking file/directory permissions...
File/directory Set Reqd Crit
Checking networking...
Action Result Crit
Pinging_dhcppc1 No_entry_for_"dhcppc1"_in_/etc/hosts yes
WARNING: CRITICAL ERROR
Pinging_localHost Successful yes
Test_rsh: Not_active* yes
Test_ssh: Not_active* yes
FATAL ERROR: No remote shell available.
Foam1.4.1 enviroment requires either ssh and/or rsh.
Contact your system administrator.
The system test has evoked 1 fatal error(s).
The foam installation contains 3 critical error(s).
Review the output for warning messages and consult
the installation guide for trouble shooting.
So my question is: How do I setup the right installation? (the error given by: Set correct path to installation 'WM_PROJECT_INST_DIR' in /home/olli/.foam2.3/bashrc)
And secondly, are the other errors dependend on the first or what would I have to do to solve this?
Thank you very much for any help !!!!!!!!
Indy
indy April 6, 2008 08:11
Hi, I somehow (dont ask me
I somehow (dont ask me why!:-)) have now made it to here, but there are still 1 fatal and 1 critical error I am struggling with...
Can anybody help me with these, or do you not need those variables when you are running on a single Linux PC???
Thanks & and sorry for the long post:!!
Shell: bash
Host: dhcppc1
User: indy
$WM_PROJECT_INST_DIR /home/indy/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/indy/OpenFOAM yes no
$FOAM_JOB_DIR /home/indy/OpenFOAM yes yes
$WM_PROJECT_DIR /home/olli/OpenFOAM yes yes yes
$FOAM_USER_APPBIN ...FOAM/OpenFOAM-1.4.1/applications/bin yes yes no
$FOAM_APPBIN ...4.1/applications/bin/linux64GccDPOpt yes yes yes
$WM_DIR /home/indy/OpenFOAM/OpenFOAM-1.4.1/wmake yes yes yes
$FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes yes yes
$JAVA_PATH ...i/OpenFOAM/linux64/j2sdk1.4.2_05/bin yes yes no
$MICO_ARCH_PATH ...ico-2.3.12/platforms/linux64GccDPOpt yes yes yes
$FOAM_LIBBIN ...M/OpenFOAM-1.4.1/lib/linux64GccDPOpt yes yes yes
$FOAM_USER_LIBBIN .../OpenFOAM-1.4.1/lib//linux64GccDPOpt yes yes no
Software versions
gcc ...figure /usr/bin/gcc
java 1.5.0_12
foam settings: /home/olli/OpenFOAM/linux64/j2sdk1.4.2_05/bin/java
tar 1.3.12 /bin/tar
icoFoam ...penFOAM-1.4.1/applications/bin/linux64GccDPOpt/icoFoam
Action Result Crit
The foam installation contains 1 critical error(s).
Thanks for any help!!
platopus April 6, 2008 09:36
Hi Indiana, note the sectio
Hi Indiana,
note the section:
I suggest you install openssh and try again. On my system it is in packages openssh-client and openssh-server. On some distributions simply installing ssh pulls both of these in.
Note that you also have a potential problem with java. I don't know if that is going to bite you.
Regards, Graeme.
indy April 6, 2008 12:01
Hi Graeme, thanks for you h
Hi Graeme,
thanks for you help,.......!
what i dont understand is, that I have openssh installed (version 4.6, came with SUSE 10.3) so it should actually be fine
I have luckily solved the java problem by pointing to the SUSE 10.3 java path which looks ok now.
I am not sure if the $LAM_ARCH_PATH has to be specified (isnt this just for parallel computing?)
Further on, I have followed the installation guide and am stuck now at the first test:
indy@dhcppc1:~/OpenFOAM/indy-1.4.1/run/tutorials> icoFoam
dotFoam(const fileName&) : Couldn't find file /home/indy//home/indy/OpenFOAM/OpenFOAM-1.4.1/controlDict or /home/indy/OpenFOAM/OpenFOAM-1.4.1//home/indy/OpenFOAM/OpenFOAM-1.4.1/controlDic t
Has this something to do with the environmental variables in the .bashrc file
Sorry again for the long post...!!
Indiana
platopus April 7, 2008 08:39
Not a problem.
That seems odd. Have you tried 'ssh dhcppc1' from a shell prompt?
Yes, I think so.
This doesn't look like any error message I've seen. It looks like you tried to run the icoFoam solver with no arguments, but when I do that I get an error message that looks quite different.
Try changing directories to the .../run/tutorials/icoFoam directory like it says in the README, and run
./Allclean
blockMesh . cavity
icoFoam . cavity
Maybe it'll behave differently.
There are some obviously wrong paths mentioned in that error message, but I don't know where they're coming from. Did you just add the line
. $HOME/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/bashrc
to the ~/.bashrc file like the README says?
It's okay.
Regards, Graeme.
indy April 7, 2008 13:59
Hi, I heard that the ssh FA
I heard that the ssh FATAL ERRROR isn't such a problem for stand alone cases, so that should be fine I hope..
I did the
./Allclean commands and it did not change anything.
I copied the tutorials to the directory as it was in the README file...
same as with the sourcing
if anybody has an idea, that would be most appreciated..
thanks
platopus April 8, 2008 10:31
I just tried icoFoam without a working sshd, and it works fine, so you're right - it isn't that.
I can't help thinking that the fact that it's looking for the controlDict in
or
has something to do with the problem - like your environment isn't set up properly. Notice the repeats and the occurrences of // - not good.
Failing that, I'm almost out of ideas.
Finally, what type of CPU do you have?
Regards, Graeme.
pistacoppu April 3, 2009 09:40
ssh
Hi ,
i had the same "fatal error",
even if i was able to run the icoFoam tutorial.
After that thread i opened synaptic packet manager, ad installed: ssh , that also automatically installed openssh-server .
I already had openssh-client installed but , the fatal error was fixed after i installed ssh .
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the Foam enviroment.
I run ubntu 8.10.
Bye
