when I try to run wmake, this
when I try to run wmake, this is what I get:
SOURCE=setGammaSplashWet.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude -I/usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/src/meshTools/lnInclude -IlnInclude -I. -I/usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/setGammaSplashWet.o In file included from /usr/include/features.h:345, from /usr/include/limits.h:27, from /usr/lib64/gcc/x86_64-suse-linux/4.2.1/include/limits.h:122, from /usr/lib64/gcc/x86_64-suse-linux/4.2.1/include/syslimits.h:7, from /usr/lib64/gcc/x86_64-suse-linux/4.2.1/include/limits.h:11, from /usr/include/c++/4.2.1/climits:50, from /usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/label.H:38, from /usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/labelList.H:36, from /usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/Pstream.H:45, from /usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/OPstream.H:37, from /usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/parRun.H:4, from /usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude/fvCFD.H:4, from setGammaSplashWet.C:36: /usr/include/gnu/stubs.h:7:27: error: gnu/stubs-32.h: No such file or directory make: *** [Make/linuxGccDPOpt/setGammaSplashWet.o] Error 1 Where can I find the .rpm that holds stubs-32.h? I have been searching for it for a long time, but with no success. I have OpenFOAM installed and running perfectly on my home 32-bit PC. My 64bit machine is Hp Compaq 6820s laptop. Thank You! |
I solved the missing
I solved the missing stubs-32.h (it was in glibc-devel-32bit-2.6.1-18.x86_54.rpm), but now I have another problem: Calling wmake on my setGammaSplashWet.C results in: g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude -I/usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/src/meshTools/lnInclude -IlnInclude -I. -I/usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -pthread Make/linuxGccDPOpt/setGammaSplashWet.o -L/usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt \ -lfiniteVolume -lmeshTools -lOpenFOAM -ldl -lm -o /usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/setGammaSpl ashWet /usr/lib64/gcc/x86_64-suse-linux/4.2.1/../../../../x86_64-suse-linux/bin/ld: cannot find -lfiniteVolume collect2: ld returned 1 exit status make: *** [/usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/setGammaSp lashWet] Error 1 For this one, I don't know where to start. I'm barely a beginning Linux user, as well as OpenFOAM, so any advice is deeply appreciated. http://www.cfd-online.com/OpenFOAM_D...part/happy.gif |
The linker did not find libfin
The linker did not find libfiniteVolue.so
Check whether there is such a file in /usr/OpenFOAM/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt and it is readable for your account |
The error reason must be befor
The error reason must be before. Search the forum. Some people solve the/a libfinitevolume-problem by downgrading flex to 2.5.4a. I don't know if this is the cause of an error here, but I had that flex-problem myself - and that was also opensuse 10.3, so you might consider to try it out.
Thank You for the advice:
I
I've tried to look for the file, but found nothing. I also ran foamInstallationTest and got two new suprises(critical errors with gcc and Java). I'll search the forum and try to find the answer somewhere. |
An old post solved the problem
An old post solved the problem for me:
There was a conflict between the system gcc and the one defined by bashrc in .OpenFOAM-1.4 (and with Java too).... The conflict stated a search via a path using terms for 32-bit architecture(that's how I recognised the problem: I have x86_64 arch), so I had to export WM_64='on' before sourcing OpenFOAM's bashrc. Thank You for the advice Martin: search the forum first, ask questions later. http://www.cfd-online.com/OpenFOAM_D...part/happy.gif |
