February 7, 2012, 07:57 |
Can't get older versions of OpenFOAM
Fabio Eduardo
Rep Power: 14 |
SourceForge files for OpenFOAM v.1.6.x and v.1.7.x and older are missing (from location: http://sourceforge.net/projects/foam/files/foam/).
I get this error dialog: "/tmp/mbzIQ9tB.bin.part could not be saved, because the source file could not be read. Try again later, or contact the server administrator." I was able to get them from Git repository, but without respective ThirdParty versions: git clone git://repo.or.cz/OpenFOAM-1.6.x.git Does anybody have a clue on why? And where else can I get these older versions of ThirdParty sw? Thanks in advance, Fabio |
February 7, 2012, 08:28 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Fabio and welcome to the forum!
The error you are getting is on your side, not on sourceforge's side. Namely, insufficient space or not enough permissions to write in "/tmp". The old instructions for 1.6.x are still available here: http://www.openfoam.org/archive/1.6/download/git.php (Almost) All of the old instructions are still available online: http://www.openfoam.org/download/archive.php Best regards, Bruno
February 7, 2012, 08:40 |
Fabio Eduardo
Rep Power: 14 |
Hi Bruno, and thanks for answering.
I gave all permissions on /tmp: sudo chmod -R 777 /tmp drwxrwxrwx 48 root root 4096 2012-02-07 11:34 tmp But still getting dialog error: http://sourceforge.net/projects/foam....gtgz/download "/tmp/tX99VF23.bin.part could not be saved, because the source file could not be read.Try again later, or contact the server administrator." http://sourceforge.net/projects/foam....gtgz/download "/tmp/yufEAOLG.bin.part could not be saved, because the source file could not be read. Try again later, or contact the server administrator." Also, I still have 7.3G on that fs, think it should be enough: fabio@fabio-desktop:~$ df -h Filesystem Size Used Avail Use% Mounted on /dev/sda5 46G 37G 7.3G 84% / none 1.7G 304K 1.7G 1% /dev none 1.7G 156K 1.7G 1% /dev/shm none 1.7G 224K 1.7G 1% /var/run none 1.7G 0 1.7G 0% /var/lock none 1.7G 0 1.7G 0% /lib/init/rw /dev/sda1 938M 105M 786M 12% /boot /dev/sdc1 932G 601G 332G 65% /media/Expansion Drive /dev/sdb2 465G 362G 104G 78% /media/DATA Thanks, Fabio |
February 7, 2012, 08:52 |
Bruno Santos
Rep Power: 128 |
Hi Fabio,
OK, then try this instead: Code:
cd $HOME/OpenFOAM wget http://downloads.sourceforge.net/foam/ThirdParty-1.6.General.gtgz?use_mirror=mesh -O ThirdParty-1.6.General.gtgz Bruno
February 7, 2012, 09:13 |
Fabio Eduardo
Rep Power: 14 |
Great, it works!
Actually, it's my firefox with problems, all downloads work fine with Chromium. Thanks again Bruno. Best regards, Fabio |
Display Modes | |
OpenFOAM 1.6.x, 1.7.0 and 1.7.x are not fully prepared to work with gcc-4.5.x | wyldckat | OpenFOAM Bugs | 18 | October 21, 2010 05:51 |
[mesh manipulation] createPatch / cyclicGgi / OpenFoam 1.5-dev | OFU | OpenFOAM Meshing & Mesh Conversion | 0 | June 16, 2010 04:36 |
Different flow pattern between OpenFOAM and CFX | AirS | OpenFOAM | 0 | January 12, 2010 07:08 |
Problem installing OpenFOAM 1.5 installation on RHEL 4. | vwsj84 | OpenFOAM Installation | 4 | April 23, 2009 04:48 |
2009 OpenFOAM Summer School in Zagreb, Croatia | hjasak | OpenFOAM Announcements from Other Sources | 0 | March 27, 2009 12:08 |
